Discuss
Control motor not opening door after electronic defrost timer replacement
 in
Refrigerator & Freezer Repair
Electronic defrost timer was just replaced! The new one required replacement of wiring harness, (which came with the new timer)
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Control motor not opening door after electronic defrost timer replacement
  #1 (permalink)
Old 08-31-2017, 01:23 AM
Junior Member
doc_holiday is on a distinguished road
Angry Control motor not opening door after electronic defrost timer replacement
Model Number: FRS6LF7J   Brand: Frigidaire   Age: 5 - 10 years
Electronic defrost timer was just replaced! The new one required replacement of wiring harness, (which came with the new timer) The new timer fixed the original problem, but created a new one! The control motor doesn't open the door and let the cold air into the refrigerator from the freezer! It is making sounds, sometimes that would lead you to believe it's open, but it is not! The old wiring harness had two connectors on the control box motor!! But the new wiring harness only had one connector, with the instructions saying to connect to the foam side switch, that the motor side switch would no longer be used with the #IV defrost timer! Anyone ran into this problem before! Or anyone understand what's happening, and can tell me what I need to do to fix the problem so I can add my butter knife that's holding the door open, back to my silverware set!!! Thank you, and all information will be greatly appreciated!!!
Related Models
Frigidaire FRS6LF7JB0 REFRIGERATOR
Frigidaire FRS6LF7JB1 REFRIGERATOR
Frigidaire FRS6LF7JB2 REFRIGERATOR
Frigidaire FRS6LF7JB3 REFRIGERATOR
Frigidaire FRS6LF7JB5 REFRIGERATOR
Frigidaire FRS6LF7JB6 REFRIGERATOR
Frigidaire FRS6LF7JM0 REFRIGERATOR
Frigidaire FRS6LF7JM1 REFRIGERATOR
Frigidaire FRS6LF7JM2 REFRIGERATOR
Frigidaire FRS6LF7JM3 REFRIGERATOR
Frigidaire FRS6LF7JM5 REFRIGERATOR
Frigidaire FRS6LF7JM6 REFRIGERATOR
Frigidaire FRS6LF7JQ0 REFRIGERATOR
Frigidaire FRS6LF7JS0 REFRIGERATOR
Frigidaire FRS6LF7JS2 REFRIGERATOR
Frigidaire FRS6LF7JS3 REFRIGERATOR
Frigidaire FRS6LF7JS5 REFRIGERATOR
Frigidaire FRS6LF7JS6 REFRIGERATOR
Frigidaire FRS6LF7JS7 REFRIGERATOR
Frigidaire FRS6LF7JW0 REFRIGERATOR
Frigidaire FRS6LF7JW2 REFRIGERATOR
Frigidaire FRS6LF7JW3 REFRIGERATOR
Frigidaire FRS6LF7JW5 REFRIGERATOR
Frigidaire FRS6LF7JW6 REFRIGERATOR
Frigidaire FRS6LF8FS0 Frigidaire/refrigerator
Frigidaire FRS6LF8FS1 Frigidaire/refrigerator
Frigidaire FRS6LF8FS2 Frigidaire/refrigerator
Frigidaire FRS6LR5EB2 Frigidaire/refrigerator
Frigidaire FRS6LR5EB3 Frigidaire/refrigerator
Frigidaire FRS6LR5EB6 Frigidaire/refrigerator
Frigidaire FRS6LR5EB7 Frigidaire/refrigerator
Frigidaire FRS6LR5EM0 Frigidaire/refrigerator
Frigidaire FRS6LR5EM2 Frigidaire/refrigerator
Frigidaire FRS6LR5EM3 Frigidaire/refrigerator
Frigidaire FRS6LR5EM5 Frigidaire/refrigerator
Frigidaire FRS6LR5EM6 Frigidaire/refrigerator
Frigidaire FRS6LR5EM7 Frigidaire/refrigerator
Frigidaire FRS6LR5EM8 Frigidaire/refrigerator
Frigidaire FRS6LR5EQ2 Frigidaire/refrigerator
Frigidaire FRS6LR5EQ3 Frigidaire/refrigerator
Frigidaire FRS6LR5EQ4 Frigidaire/refrigerator
Frigidaire FRS6LR5ES2 Frigidaire/refrigerator
Frigidaire FRS6LR5ES3 Frigidaire/refrigerator
Frigidaire FRS6LR5ES5 Frigidaire/refrigerator
Frigidaire FRS6LR5ES6 Frigidaire/refrigerator
Frigidaire FRS6LR5ES7 Frigidaire/refrigerator
Frigidaire FRS6LR5EW2 Frigidaire/refrigerator
Frigidaire FRS6LR5EW3 Frigidaire/refrigerator
Frigidaire FRS6LR5EW5 Frigidaire/refrigerator
Frigidaire FRS6LR5EW6 Frigidaire/refrigerator
Frigidaire FRS6R2FB0 REFRIGERATOR
Frigidaire FRS6R2FB1 REFRIGERATOR
Frigidaire FRS6R2FB2 REFRIGERATOR
Frigidaire FRS6R2FB3 REFRIGERATOR
Frigidaire FRS6R2FB4 REFRIGERATOR
Frigidaire FRS6R2FB5 REFRIGERATOR
Frigidaire FRS6R2FB6 REFRIGERATOR
Frigidaire FRS6R3EW0 Frigidaire/refrigerator
Frigidaire FRS6R3EW1 Frigidaire/refrigerator
Frigidaire FRS6R3EW2 Frigidaire/refrigerator
Frigidaire FRS6R3EW3 Frigidaire/refrigerator
Frigidaire FRS6R3EW4 Frigidaire/refrigerator
Frigidaire FRS6R3EW5 Frigidaire/refrigerator
Frigidaire FRS6R3EW6 Frigidaire/refrigerator
Frigidaire FRS6R3EW7 Frigidaire/refrigerator
Frigidaire FRS6R3EW8 Frigidaire/refrigerator
Frigidaire FRS6R3EW9 Frigidaire/refrigerator
Frigidaire FRS6R3JB0 REFRIGERATOR
Frigidaire FRS6R3JB1 REFRIGERATOR
Frigidaire FRS6R3JB2 REFRIGERATOR
Frigidaire FRS6R3JB3 REFRIGERATOR
Frigidaire FRS6R3JB4 REFRIGERATOR
Frigidaire FRS6R3JB5 REFRIGERATOR
Frigidaire FRS6R3JB6 REFRIGERATOR
Frigidaire FRS6R3JB7 REFRIGERATOR
Frigidaire FRS6R3JW0 REFRIGERATOR
Frigidaire FRS6R3JW1 REFRIGERATOR
Frigidaire FRS6R3JW2 REFRIGERATOR
Frigidaire FRS6R3JW3 REFRIGERATOR
Frigidaire FRS6R3JW4 REFRIGERATOR
Frigidaire FRS6R3JW5 REFRIGERATOR
Frigidaire FRS6R3JW6 REFRIGERATOR
Frigidaire FRS6R3JW7 REFRIGERATOR
Frigidaire FRS6R4EB0 Frigidaire/refrigerator
Frigidaire FRS6R4EB1 Frigidaire/refrigerator
Frigidaire FRS6R4EB2 Frigidaire/refrigerator
Frigidaire FRS6R4EB3 Frigidaire/refrigerator
Frigidaire FRS6R4EB4 Frigidaire/refrigerator
Frigidaire FRS6R4EB5 Frigidaire/refrigerator
Frigidaire FRS6R4EB6 Frigidaire/refrigerator
Frigidaire FRS6R4EB7 Frigidaire/refrigerator
Frigidaire FRS6R4EB9 Frigidaire/refrigerator
Frigidaire FRS6R4EBA Frigidaire/refrigerator
Frigidaire FRS6R4EBB Frigidaire/refrigerator
Frigidaire FRS6R4EBC Frigidaire/refrigerator
Frigidaire FRS6R4EBD Frigidaire/refrigerator
Frigidaire FRS6R4EQ0 Frigidaire/refrigerator
Frigidaire FRS6R4EQ1 Frigidaire/refrigerator
Frigidaire FRS6R4EQ2 Frigidaire/refrigerator
Frigidaire FRS6R4EQ3 Frigidaire/refrigerator
Frigidaire FRS6R4EQ4 Frigidaire/refrigerator
Frigidaire FRS6R4EQ5 Frigidaire/refrigerator
Frigidaire FRS6R4EQ6 Frigidaire/refrigerator
Frigidaire FRS6R4EQ7 Frigidaire/refrigerator
Frigidaire FRS6R4EQA Frigidaire/refrigerator
Frigidaire FRS6R4EQB Frigidaire/refrigerator
Frigidaire FRS6R4EQC Frigidaire/refrigerator
Frigidaire FRS6R4EW0 Frigidaire/refrigerator
Frigidaire FRS6R4EW1 Frigidaire/refrigerator
Frigidaire FRS6R4EW2 Frigidaire/refrigerator
Frigidaire FRS6R4EW3 Frigidaire/refrigerator
Frigidaire FRS6R4EW4 Frigidaire/refrigerator
Frigidaire FRS6R4EW5 Frigidaire/refrigerator
Frigidaire FRS6R4EW6 Frigidaire/refrigerator
Frigidaire FRS6R4EW7 Frigidaire/refrigerator
Frigidaire FRS6R4EW9 Frigidaire/refrigerator
Frigidaire FRS6R4EWA Frigidaire/refrigerator
Frigidaire FRS6R4EWB Frigidaire/refrigerator
Frigidaire FRS6R4EWC Frigidaire/refrigerator
Frigidaire FRS6R5EMB0 Frigidaire/refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
clicking electronic defrost control board canz4me Refrigerator & Freezer Repair 0 08-24-2014 08:20 PM
rFreezer Fine, Fridge Warm- Electronic defrost timer pwsunglass Refrigerator & Freezer Repair 1 05-10-2011 04:21 AM
How do you force defrost with electronic timer? kamac Refrigerator & Freezer Repair 1 03-11-2011 04:01 AM
Electronic Timer Control DSTEALT@AOL.COM Oven Repair (including Ranges and Cooktops) 4 12-14-2009 03:09 AM
electronic control replacement babyavis2008 Oven Repair (including Ranges and Cooktops) 1 09-26-2008 01:03 PM
