My question is on the cutter grid performance. The grid cuts the ice and just barely finishes the cut on one slab before the next slab enters the grid. My grid shows 7 ohms and when the machine is “on” shows 1.85 AMPs @ ~ 9 VAC. I’ve read where it should be around 2.0 AMPs. Is that normal or is the transformer weak? Thanks in advance for your time.
