Discuss
KitchenAid kssc36mhs00 freezer intermittent
 in
Refrigerator & Freezer Repair
Hi everyone. New to the forum and hope someone can give me some much needed guidance. So I have a
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » KitchenAid kssc36mhs00 freezer intermittent
  #1 (permalink)
Old 08-21-2017, 08:40 PM
Junior Member
Nj323ci is on a distinguished road
Default KitchenAid kssc36mhs00 freezer intermittent
Model Number: kssc36mhs00   Brand: Kitchen Aid   Age: More than 10 years
So I have a kitchen aid side by side built in refrigerator /freezer. It has been acting up for a few months now. I've been trouble shooting it on and off and have replaced some parts. Here is what it is doing.
It will run fine for a day, sometimes 2 and then the freezer starts to warm up and everything melts. If I advance the defrost timer slightly and turn the refrigerator off for about 5 minutes and back on, it usually starts to work again. I would say this process works about 80% of the time. First thing I did was replaced the overload relay. Next I replaced the defrost timer, finally I replaced the freezer thermostat. I even went ahead and replaced the defrost timer a 2nd time. All with no luck. In the last few months troubleshooting, I noticed that when the refrigerator stops working, the defrost timer stops advancing as well. It is almost never in the defrost mode however. It normally stops advancing after it kicks back on after defrost mode. The compressor runs properly from what I can tell and continues to run until I turn the fridge off.
Any ideas? I spoke to a local appliance repair person who gave me some tips but is baffled. I'm also on some other forums and folks are baffled there too.
I'm under the impression that the defrost timer should continue advancing as long as there is power on the pin correct? I checked for continuity on the different pins upon defrost and regular mode and those seem fine. What would cause the defrost timer to stop moving while the freezer is starting to warm? I never see any frost/ice build up on the back wall of the freezer, but I haven't removed the freezer back wall cover yet.
Any help/direction you can give me is highly appreciated.
Thanks!
Related Models
Whirlpool KSSC36MHS00
Whirlpool KSSC36QKS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC36QKS01 BUILT IN REFRIGERATOR
Whirlpool KSSC36QKS02 36" BUILT IN REFRIGERATOR
Whirlpool KSSC36QMS00 36" BUILT IN REFRIGERATOR
Whirlpool KSSC36QMS01 36" BUILT IN REFRIGERATOR
Whirlpool KSSC36QMS02 36" BUILT IN REFRIGERATOR
Whirlpool KSSC36QMS03 36" BUILT IN REFRIGERATOR
Whirlpool KSSC36QTS00 36" BUILT IN REFRIGERATOR
Whirlpool KSSC36QTS02 36" BUILT IN REFRIGERATOR
Whirlpool KSSC36QTS03 36" BUILT IN REFRIGERATOR
Whirlpool KSSC36QTS04 36" BUILT-IN REFRIGERATOR
Whirlpool KSSC42FJB00 BUILT-IN REFRIGERATOR
Whirlpool KSSC42FJS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC42FJT00 BUILT-IN REFRIGERATOR
Whirlpool KSSC42FJW00 BUILT-IN REFRIGERATOR
Whirlpool KSSC42FKB00 BUILT-IN REFRIGERATOR
Whirlpool KSSC42FKB01 BUILT IN REFRIGERATOR
Whirlpool KSSC42FKB02 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42FKS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC42FKS01 BUILT IN REFRIGERATOR
Whirlpool KSSC42FKS02 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42FMS00 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42FMS01 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42FMS02 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42FMS03 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42FTS00 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42FTS02 36" BUILT IN REFRIGERATOR
Whirlpool KSSC42FTS03 36" BUILT IN REFRIGERATOR
Whirlpool KSSC42FTS04 36" BUILT IN REFRIGERATOR
Whirlpool KSSC42MFS05 BUILT-IN REFRIGERATOR
Whirlpool KSSC42MHS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC42QKS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC42QKS01 BUILT IN REFRIGERATOR
Whirlpool KSSC42QKS02 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QMS00 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QMS01 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QMS02 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QMS03 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QMU00 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QMU01 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QTS00 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QTS02 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QTS03 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QVS00 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QVS01 42" BUILT IN REFRIGERATOR
Whirlpool KSSC42QVS02 42" BUILT IN REFRIGERATOR
KitchenAid KSSC48FJB00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48FJS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48FJT00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48FJW00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48FKB00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48FKB01 BUILT IN REFRIGERATOR
Whirlpool KSSC48FKB02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FKS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48FKS01 BUILT IN REFRIGERATOR
Whirlpool KSSC48FKS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FMS00 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FMS01 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FMS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FMS03 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FTS00 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FTS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FTS03 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48FTS04 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48MFS05 BUILT-IN REFRIGERATOR
Whirlpool KSSC48MHS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48QKS00 BUILT-IN REFRIGERATOR
Whirlpool KSSC48QKS01 BUILT IN REFRIGERATOR
Whirlpool KSSC48QKS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QMS00 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QMS01 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QMS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QMS03 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QTS00 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QTS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QTS03 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QVS00 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QVS01 48" BUILT IN REFRIGERATOR
Whirlpool KSSC48QVS02 48" BUILT IN REFRIGERATOR
Whirlpool KSSO36FMX00 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36FMX01 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36FMX02 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36FMX03 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36FTX00 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36FTX02 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36FTX03 36" BUILT IN REFRIGERATOR
KitchenAid KSSO36FTX04 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMB00 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMB01 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMB02 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMB03 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMW00 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMW01 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QMX02 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QTB00 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QTB02 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QTB03 36" BUILT IN REFRIGERATOR
KitchenAid KSSO36QTB04 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QTX00 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QTX02 36" BUILT IN REFRIGERATOR
Whirlpool KSSO36QTX03 36" BUILT IN REFRIGERATOR
KitchenAid KSSO36QTX04 36" BUILT IN REFRIGERATOR
Whirlpool KSSO42FMX00 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FMX01 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FMX02 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FMX03 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FTX00 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FTX02 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FTX03 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42FTX04 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMB00 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMB01 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMB02 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMB03 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMW00 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMW01 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMX01 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QMX02 42" BUILT IN REFRIGERATOR
Whirlpool KSSO42QTB00 42" BUILT IN REFRIGERATOR
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
KitchenAid Oven, intermittent lighting ryancfields Oven Repair (including Ranges and Cooktops) 0 03-27-2016 09:15 AM
KitchenAid Icemaker intermittent issue dmhoot Refrigerator & Freezer Repair 0 03-11-2016 10:17 AM
Kitchenaid: intermittent, slow icemaker TigerDriver Refrigerator & Freezer Repair 13 07-12-2012 04:10 PM
Kitchenaid intermittent cycle problems Superburner Dishwasher Repair 0 04-11-2011 08:31 PM
Intermittent starting of KitchenAid Dishwasher Howward Dishwasher Repair 4 09-18-2008 10:35 AM
