Discuss
Maytag french door fridge compressor wouldnt start. 3n1 hard start fixed. now loudish
 in
Refrigerator & Freezer Repair
engineer/multi property manager and (diy) appliance repair person here...thanks in advance for any advice... 2010 Maytag french door refrigerator/bottom freezer
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Maytag french door fridge compressor wouldnt start. 3n1 hard start fixed. now loudish
  #1 (permalink)
Old 08-19-2017, 01:31 PM
Junior Member
jbradley is on a distinguished road
Default Maytag french door fridge compressor wouldnt start. 3n1 hard start fixed. now loudish
Model Number: mff2558VEM4   Brand: Maytag   Age: 5 - 10 years
2010 Maytag french door refrigerator/bottom freezer from sears - sticker inside says it is whirlpool made. sticker says 5 oz R134A 7.1A (lock up amps?)
compressor sticker in lower rear - Brazil made Embraco EM2Z 60HLT 10.5 LRA (1/5 hp?)
came home from trip wife reported fridge was warm. it was totally room temp inside all had melted in freezer.
took off lower rear panel - fan was running - compressor was very hot to touch - not running. unplugged, etc. replugged - compressor would start/run briefly a few seconds - then a loud 'click' and it would stop - then repeated this every few minutes. vacuumed all coils in rear and beneath - had done this periodically in past so it wasn't super clogged with dust.
did some research - and checked ohms on 3 compressor terminals - seemed within good range- and no shorts to ground. then removed start device/capacitor and direct wired compressor - and bumped start terminal - and it ran and cooled. then it would not restart after attempting to repeat this procedure.
then i orderred Supco RCO810 3n1 hard start mechanism then wired it up and the compressor started right up - albeit was fairly loud to start - then got quieter. it has now been running for a week cycling normally - with loudish starts - gradually less loud - but definitely louder than before the buzzing is louder and the 'phase wobble sound' is louder - but it is cooling well/freezing well.
looks like it is running and drawing about 2.35amps right now - after running at 2.58 amps after it started. at start it peaked briefly at 7 amps. have it plugged into a kill-a-watt meter to give me amps. (also have amp meter which i used when rear was open).
i assume compressor is having some issues/failing/on its way to failing so the normal start device couldn't handle it - but the hard start is able to start it? perhaps this new status can give me weeks or months? to find a replacement?
any thoughts appreciated.
Related Models
Maytag MFF2558VEM4 REFRIGERATOR
Maytag MFF2558VEQ1 REFRIGERATOR
Maytag MFF2558VEQ10 REFRIGERATOR
Maytag MFF2558VEQ2 REFRIGERATOR
Maytag MFF2558VEW1 REFRIGERATOR
Maytag MFF2558VEW10 REFRIGERATOR
Maytag MFF2558VEW2 REFRIGERATOR
Frigidaire MFF312BFWB Frg(v1) / Electric Range
Frigidaire MFF312BFWC Frg(v2) / Electric Range
Frigidaire MFF312BFWE Frg(v3) / Electric Range
Frigidaire MFF312BSF ELECTRIC RANGE
Frigidaire MFF312HSC ELECTRIC RANGE
Frigidaire MFF318BGDA Wwh(v1) / Electric Range
Frigidaire MFF318BGWA Wwh(v2) / Electric Range
Frigidaire MFF351BCWC Frg(v1) / Electric Range
Frigidaire MFF351BCWD Frg(v2) / Electric Range
Frigidaire MFF351BCWE Frg(v3) / Electric Range
Maytag MFI2067AEB REF - BOTTOM MOUNTS
Maytag MFI2067AEB12 REFRIGERATOR
Maytag MFI2067AEB13 REFRIGERATOR
Maytag MFI2067AEB4 REFRIGERATOR
Maytag MFI2067AEB5 REFRIGERATOR
Maytag MFI2067AEQ REF - BOTTOM MOUNTS
Maytag MFI2067AEQ12 REFRIGERATOR
Maytag MFI2067AEQ13 REFRIGERATOR
Maytag MFI2067AEQ4 REFRIGERATOR
Maytag MFI2067AES REF - BOTTOM MOUNTS
Maytag MFI2067AES12 REFRIGERATOR
Maytag MFI2067AES13 REFRIGERATOR
Maytag MFI2067AES4 REFRIGERATOR
Maytag MFI2067AES5 REFRIGERATOR
Maytag MFI2067AES6 REFRIGERATOR
Maytag MFI2067AEW REF - BOTTOM MOUNTS
Maytag MFI2067AEW12 REFRIGERATOR
Maytag MFI2067AEW13 REFRIGERATOR
Maytag MFI2067AEW4 REFRIGERATOR
Maytag MFI2266AEB10 REFRIGERATOR
Maytag MFI2266AEB11 REFRIGERATOR
Maytag MFI2266AEQ10 REFRIGERATOR
Maytag MFI2266AEQ11 REFRIGERATOR
Maytag MFI2266AES10 REFRIGERATOR
Maytag MFI2266AES11 REFRIGERATOR
Maytag MFI2266AEU10 REFRIGERATOR
Maytag MFI2266AEU11 REFRIGERATOR
Maytag MFI2266AEW10 REFRIGERATOR
Maytag MFI2266AEW11 REFRIGERATOR
Maytag MFI2269VEA1 REFRIGERATOR
Maytag MFI2269VEA10 REFRIGERATOR
Maytag MFI2269VEB1 REFRIGERATOR
Maytag MFI2269VEB10 REFRIGERATOR
Maytag MFI2269VEB2 REFRIGERATOR
Maytag MFI2269VEM1 REFRIGERATOR
Maytag MFI2269VEM10 REFRIGERATOR
Maytag MFI2269VEM2 REFRIGERATOR
Maytag MFI2269VEM3 REFRIGERATOR
Maytag MFI2269VEQ1 REFRIGERATOR
Maytag MFI2269VEQ10 REFRIGERATOR
Maytag MFI2269VEW1 REFRIGERATOR
Maytag MFI2269VEW10 REFRIGERATOR
Maytag MFI2568AEB REF - BOTTOM MOUNTS
Maytag MFI2568AEB12 REFRIGERATOR
Maytag MFI2568AEB13 REFRIGERATOR
Maytag MFI2568AEQ REF - BOTTOM MOUNTS
Maytag MFI2568AEQ12 REFRIGERATOR
Maytag MFI2568AEQ13 REFRIGERATOR
Maytag MFI2568AES REF - BOTTOM MOUNTS
Maytag MFI2568AES12 REFRIGERATOR
Maytag MFI2568AES13 REFRIGERATOR
Maytag MFI2568AEW REF - BOTTOM MOUNTS
Maytag MFI2568AEW12 REFRIGERATOR
Maytag MFI2568AEW13 REFRIGERATOR
Maytag MFI2569VEA1 REFRIGERATOR
Maytag MFI2569VEA10 REFRIGERATOR
Maytag MFI2569VEB1 REFRIGERATOR
Maytag MFI2569VEB10 REFRIGERATOR
Maytag MFI2569VEB2 REFRIGERATOR
Maytag MFI2569VEM1 REFRIGERATOR
Maytag MFI2569VEM10 REFRIGERATOR
Maytag MFI2569VEM2 REFRIGERATOR
Maytag MFI2569VEM3 REFRIGERATOR
Maytag MFI2569VEQ1 REFRIGERATOR
Maytag MFI2569VEQ10 REFRIGERATOR
Maytag MFI2569VEW1 REFRIGERATOR
Maytag MFI2569VEW10 REFRIGERATOR
Maytag MFI2665XEB0 REFRIGERATOR
Maytag MFI2665XEM0 REFRIGERATOR
Maytag MFI2665XEW0 REFRIGERATOR
Maytag MFI2670XEB0 REFRIGERATOR
Maytag MFI2670XEM0 REFRIGERATOR
Maytag MFI2670XEW0 REFRIGERATOR
Maytag MFR18MCAAS MANUAL, PARTS (WASHER)
Maytag MFR18MCAVS MANUAL, PARTS (WASHER)
Maytag MFR18PCAAS MANUAL, PARTS (WASHER)
Maytag MFR18PCAVS MANUAL, PARTS (WASHER)
Maytag MFR18PDAAS MAYTAG LAUNDRY (WASHER)
Maytag MFR18PDAVS MAYTAG LAUNDRY (WASHER)
Maytag MFR18PDCWS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFR25MCATS MANUAL, PARTS (WASHER)
Maytag MFR25MCAVS MANUAL, PARTS (WASHER)
Maytag MFR25PCATS MANUAL, PARTS (WASHER)
Maytag MFR25PCAVS MANUAL, PARTS (WASHER)
Maytag MFR25PDATS MAYTAG LAUNDRY (WASHER)
Maytag MFR25PDAVS MAYTAG LAUNDRY (WASHER)
Maytag MFR25PDCWS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFR30PDCTS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFR30PNCTS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MFR35MCATS MANUAL, PARTS (WASHER)
Maytag MFR35MCAVS MANUAL, PARTS (WASHER)
Maytag MFR35MNATS MANUAL, PARTS (COMMERCIAL) (WASHER)
Maytag MFR35MNAVS MANUAL, PARTS (COMMERCIAL) (WASHER)
Maytag MFR35PCATS MANUAL, PARTS (WASHER)
Maytag MFR35PCAVS MANUAL, PARTS (WASHER)
Maytag MFR35PDATS MAYTAG LAUNDRY (WASHER)
Maytag MFR35PDAVS MAYTAG LAUNDRY (WASHER)
Maytag MFR35PNAVS MANUAL, PARTS (WASHER)
Maytag MFR35PNBVS MAYTAG LAUNDRY (WASHER)
Maytag MFR40PDCTS MAYTAG LAUNDRY CATALOG (WASHER)
Maytag MFR40PNCTS MAYTAG LAUNDRY CATALOG (WASHER)
Maytag MFR50MCATS MANUAL, PARTS (WASHER)
Maytag MFR50MCAVS MANUAL, PARTS (WASHER)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag French Door compressor runs but not cooling Djs922 Refrigerator & Freezer Repair 5 05-04-2014 01:16 AM
compressor hard start jakelaker Refrigerator & Freezer Repair 5 01-19-2012 01:35 PM
Maytag French Door Fridge OD. knittingtrains Refrigerator & Freezer Repair 4 11-11-2010 02:09 PM
Maytag hard start defineran Dryer Repair 1 09-07-2008 11:33 AM
maytag freNch door fridge martinezc2006 Refrigerator & Freezer Repair 19 02-27-2008 05:34 PM
