Discuss
Fridge Temp Climbs When Ice Maker is On
 in
Refrigerator & Freezer Repair
I am so thankful to come across this forum. I was about to call for a repair when I found
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Fridge Temp Climbs When Ice Maker is On
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-18-2017, 01:57 PM
Junior Member
PLNX107 is on a distinguished road
Question Fridge Temp Climbs When Ice Maker is On
Model Number: DFE29JSDASS   Brand: GE   Age: 5 - 10 years
I am so thankful to come across this forum. I was about to call for a repair when I found this group! I'm hoping someone can help.
After defrosting our fridge, I noticed the temperature jumps several degrees within a couple of hours when I turn on the ice maker. It then fluctuates between 40 and 46. With it off, it stays steady at 36. I'm not sure if this is truly an issue or if I'm just hyper aware of it now that I've recently noticed it. Ive checked the seals on the fridge and around the ice maker on the door and they seem OK. No tears or cuts and they look clean.
Some background... We started to see a sheet of ice would form under the meat and cheese drawer in the fridge which would cause water to drip along the freezer drawer then onto the floor. After clearing the ice a couple of times, we decided to allow it to defrost for a full day. After a successful defrost we plugged it back in, pushed it back into place and re-leveled it.
We noticed that it wouldn't go below 40, which we understand is a danger zone. After waiting a couple of days for the fridge to settle, we never saw it stay below 40. After reading the manual for tips, I turned off the upper ice maker as the manual says it can take longer to cool with it on. Sure enough the temperature dropped to the set point of 36 and remained there pretty consistently. I left the ice maker off for a couple of days to confirm while leaving the lower ice maker on. The temperature was consistent. Today, I turned the upper ice maker back on and within 2 hours, the temperature rose to 40 and stayed there with the fridge running to try and cool it.
Sorry for the lengthy post, but I thought it was best to provide the detail in case it helps someone help me.
Related Models
Frigidaire DFHS2313MF0 REFRIGERATOR
Frigidaire DFHS2313MF1 FRIGIDAIRE/REFRIGERATOR
Frigidaire DFHS2313MF2 REFRIGERATOR
Frigidaire DFHT1843MS0 REFRIGERATOR
Frigidaire DFHT1843MS2 REFRIGERATOR
Frigidaire DFHT1843MS3 REFRIGERATOR
Frigidaire DFHT1843MW0 REFRIGERATOR
Frigidaire DFHT1843MW2 REFRIGERATOR
Frigidaire DFHT1843MW3 REFRIGERATOR
Maytag DFNF17 FREEZER- VERTICAL
Amana DFS11E COMMERCIAL MICROWAVES
Menu Master DFS11EA COMMERCIAL MICROWAVES
Menu Master DFS18E COMMERCIAL MICROWAVES
General Electric DFSF9VKBABB BOTTOM MOUNT REFRIGERATOR
General Electric DFSF9VKBAWW BOTTOM MOUNT REFRIGERATOR
Amana DFU17 FREEZER- VERTICAL
Amana DFU17L FREEZER- VERTICAL
Amana DFU18 FREEZER- VERTICAL
Amana DFU18L FREEZER- VERTICAL
Maytag DG100 DRYER- GAS
Maytag DG100PN1 MANUAL, PARTS (DRYER GAS)
Maytag DG101 DRYER- GAS
Maytag DG102 DRYER- GAS
Amana DG1030 WASHER-TOP LOADING
Amana DG1031 WASHER-TOP LOADING
Maytag DG105 DRYER- GAS
Maytag DG106 DRYER- GAS
Maytag DG107 DRYER- GAS
Maytag DG110 DRYER- GAS
Maytag DG16CA MANUAL, PARTS (DRYER GAS)
Maytag DG16CM MANUAL, PARTS (DRYER GAS)
Maytag DG16CT MANUAL, PARTS (DRYER GAS)
Maytag DG18CA MAYTAG LAUNDRY (DRYER GAS)
Maytag DG18CM MAYTAG LAUNDRY (DRYER GAS)
Maytag DG18CS MAYTAG LAUNDRY (DRYER GAS)
Maytag DG18CT MAYTAG LAUNDRY (DRYER GAS)
Admiral DG18F2AM DRYER- GAS
Admiral DG18F2HW DRYER- GAS
Admiral DG18F2WN DRYER- GAS
Admiral DG18F2WW DRYER- GAS
Maytag DG19CD MAYTAG LAUNDRY (DRYER GAS)
Maytag DG19CS MANUAL, PARTS (DRYER GAS)
Maytag DG19CT MANUAL, PARTS (DRYER GAS)
Frigidaire DG2000DL1 Frg(v1) / Gas Dryer
Frigidaire DG2000DW1 Frg(v2) / Gas Dryer
Magic Chef DG20F5AM DRYER- GAS
Magic Chef DG20F5FA DRYER- GAS
Magic Chef DG20F5HW DRYER- GAS
Magic Chef DG20F5WG DRYER- GAS
Magic Chef DG20F5WW DRYER- GAS
Admiral DG20F8AM DRYER- GAS
Admiral DG20F8HW DRYER- GAS
Admiral DG20F8WW DRYER- GAS
Maytag DG210 DRYER- GAS
Maytag DG212 DRYER- GAS
Maytag DG21CA MAYTAG LAUNDRY (DRYER GAS)
Maytag DG21CM MAYTAG LAUNDRY (DRYER GAS)
Maytag DG21CS MAYTAG LAUNDRY (DRYER GAS)
Maytag DG21CT MAYTAG LAUNDRY (DRYER GAS)
Maytag DG22CA MANUAL, PARTS (DRYER GAS)
Maytag DG22CS MANUAL, PARTS (DRYER GAS)
Maytag DG22CT MANUAL, PARTS (DRYER GAS)
Maytag DG23CD MAYTAG LAUNDRY (DRYER GAS)
Maytag DG24CA MAYTAG LAUNDRY (DRYER GAS)
Maytag DG24CM MAYTAG LAUNDRY (DRYER GAS)
Maytag DG24CS MAYTAG LAUNDRY (DRYER GAS)
Maytag DG24CT MAYTAG LAUNDRY (DRYER GAS)
Frigidaire DG250EXD1 Wwh(v1) / Gas Dryer
Frigidaire DG250EXD4 Wwh(v2) / Gas Dryer
Frigidaire DG250EXD5 Wwh(v3) / Gas Dryer
Frigidaire DG250EXF1 Wwh(v4) / Gas Dryer
Frigidaire DG250EXF4 Wwh(v5) / Gas Dryer
Frigidaire DG250EXF5 Wwh(v6) / Gas Dryer
Frigidaire DG250EXH1 Wwh(v7) / Gas Dryer
Frigidaire DG250EXH4 Wwh(v8) / Gas Dryer
Frigidaire DG250EXH5 Wwh(v9) / Gas Dryer
Frigidaire DG250EXV1 Wwh(v10) / Gas Dryer
Frigidaire DG250EXV4 Wwh(v11) / Gas Dryer
Frigidaire DG250EXV5 Wwh(v12) / Gas Dryer
Frigidaire DG250EXW1 Wwh(v13) / Gas Dryer
Frigidaire DG250EXW4 Wwh(v14) / Gas Dryer
Frigidaire DG250EXW5 Wwh(v15) / Gas Dryer
Frigidaire DG250JXD1 Wwh(v1) / Gas Dryer
Frigidaire DG250JXF1 Wwh(v2) / Gas Dryer
Frigidaire DG250JXH1 Wwh(v3) / Gas Dryer
Frigidaire DG250JXV1 Wwh(v4) / Gas Dryer
Frigidaire DG250JXW1 Wwh(v5) / Gas Dryer
Frigidaire DG250KXD1 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG250KXD2 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG250KXD3 Wwh(v3) / 27 " Gas Dryer
Frigidaire DG250KXD4 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXH1 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXH2 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXH3 Wwh(v2) / 27 " Gas Dryer
Frigidaire DG250KXW1 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG250KXW2 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG250KXW3 Wwh(v1) / 27 " Gas Dryer
Frigidaire DG250KXW4 Wwh(v1) / 27 " Gas Dryer
Maytag DG25CS MAYTAG LAUNDRY (DRYER GAS)
Maytag DG26CA MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag DG26CD MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag DG26CS MANUAL, PARTS (DRYER GAS)
Maytag DG26CT MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Frigidaire DG27A5WAFA Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WAFB Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WVFA Gib(v3) / 27 " Gas Dryer
Frigidaire DG27A5WVFX Gib(v3) / 27 " Gas Dryer
Frigidaire DG27A5WXFC Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WXFD Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WXFE Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A5WXFF Gib(v2) / 27 " Gas Dryer
Frigidaire DG27A7WVFA Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WVFX Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFB Gib(v1) / 27 " Gas Dryer
Frigidaire DG27A7WXFC Gib(v1) / 27 " Gas Dryer
  #2 (permalink)
Old 08-18-2017, 02:10 PM
Junior Member
Default
Something else I just noticed is the LED lights only dim when the doors are closed. I placed my phone in the fridge on time lapse and found that while the lights dim, they don't turn off. This is the case with the ice maker both on and off so I'm not sure this is the problem, but I thought it was worth mentioning. Are they supposed to turn off or just dim? Anyone know?
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer temp good, Fridge temp warm tacktack Refrigerator & Freezer Repair 3 05-30-2017 10:12 PM
GE Freezer not holding temp lower temp in Fridge CDupont Refrigerator & Freezer Repair 0 12-05-2013 10:11 AM
sxs, fridge 60 degrees crispers, room temp above, freezer 32 lower, room temp upper brillo Refrigerator & Freezer Repair 0 08-20-2012 02:46 AM
Freezer Temp low, Fridge Temp okay alan18 Refrigerator & Freezer Repair 1 01-08-2012 04:34 AM
Monogram fridge inconsistent fridge temp eldonixon Refrigerator & Freezer Repair 0 07-04-2011 05:15 PM
