Discuss
Fridge OK Freezer Not Cold Enough
 in
Refrigerator & Freezer Repair
I have a 15 year old GE side by side that can keep the fridge side at 35F but the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Fridge OK Freezer Not Cold Enough
  #1 (permalink)
Old 08-12-2017, 11:38 PM
Junior Member
Jonrg is on a distinguished road
Angry Fridge OK Freezer Not Cold Enough
Model Number: GSS25JFMCCC   Brand: GE   Age: More than 10 years
I have a 15 year old GE side by side that can keep the fridge side at 35F but the freezer side never gets below 20F. Mostly it hovers around 24F.
An allegedly trained repair technician diagnosed it and said to replace the main control board. Did that and it didn't help. That technician couldn't even find the circuit diagram. I found it in 4 minutes.
The thermistors measured low, so I replaced the two in the freezer compartment. The evaporator coils started clogging with ice and I discovered the new main board had burnt out the defrost heater, so I replaced it. It no longer ices up. I replaced the overheat thermostat because I was running out of things that could possibly be broken. No change.
Here's what I know is working: the damper door between the fridge and freezer sections operates fine, and opens or closes in response to the fridge side front panel setting. Both the evaporator and condenser fans are operating fine, visibly spinning. The compressor operates fine, though it's a little bit noisy because it has a little more coolant in it than it should. The low pressure line in the back outside of the freezer compartment partially ices up. The ice maker works fine, though ice more than a few days old partially melts and clumps up because the freezer compartment is never cold enough. The water and ice dispensers work fine. It's on its third ice dispenser door solenoid, the first two having rusted solid. The door seals and ice dispenser door seal are perfectly intact, and the recess heater loop that keeps the freezer door from frosting up in the dispenser recess works fine and don't seem to be too hot. All of the lights, both interior and exterior work fine, and shut off when the door switches are closed.
The only things I haven't replaced are the thermistor in the fridge side and the small circuit board behind the temperature control knobs, both of which appear to be fine because of the fridge side temperature and the behavior of the damper door in response to changes in the settings.
What could possibly be wrong that prevents the freezer from getting down to the -3 to 3F it's supposed to be? I'm at my wits end, and ready to strip all the parts out of it and junk it and never buy another GE appliance again.
Any help that isn't a regurgitation of the top 5 things that go wrong with fridges would be appreciated.
Related Models
General Electric GSS25JFMCCC Refrigerator
General Electric GSS25JFMCWW Refrigerator
General Electric GSS25JFMDCC Refrigerator
General Electric GSS25JFMDWW Refrigerator
General Electric GSS25JFPACC Refrigerator
General Electric GSS25JFPAWW Refrigerator
General Electric GSS25JFPBBB Refrigerator
General Electric GSS25JFPBCC Refrigerator
General Electric GSS25JFPBWW Refrigerator
General Electric GSS25JFPCCC Refrigerator
General Electric GSS25JFPCWW Refrigerator
General Electric GSS25JFPDBB Refrigerator
General Electric GSS25JFPDCC Refrigerator
General Electric GSS25JFPDWW Refrigerator
General Electric GSS25JFPEBB Refrigerator
General Electric GSS25JFPECC Refrigerator
General Electric GSS25JFPEWW Refrigerator
General Electric GSS25JFPHBB Refrigerator
General Electric GSS25JFPHCC Refrigerator
General Electric GSS25JFPHWW Refrigerator
General Electric GSS25JFPJBB Refrigerator
General Electric GSS25JFPJCC Refrigerator
General Electric GSS25JFPJWW Refrigerator
General Electric GSS25JFPKBB Refrigerator
General Electric GSS25JFPKWW Refrigerator
General Electric GSS25JSRESS Refrigerator
General Electric GSS25JSRFSS Refrigerator
General Electric GSS25KGMAAA Refrigerator
General Electric GSS25KGMABB Refrigerator
General Electric GSS25KGMACC Refrigerator
General Electric GSS25KGMAWW Refrigerator
General Electric GSS25KGMBAA Refrigerator
General Electric GSS25KGMBBB Refrigerator
General Electric GSS25KGMBCC Refrigerator
General Electric GSS25KGMBWW Refrigerator
General Electric GSS25KGMCAA Refrigerator
General Electric GSS25KGMCBB Refrigerator
General Electric GSS25KGMCCC Refrigerator
General Electric GSS25KGMCWW Refrigerator
General Electric GSS25KGMDBB Refrigerator
General Electric GSS25KGMDCC Refrigerator
General Electric GSS25KGMDWW Refrigerator
General Electric GSS25KGPABB Refrigerator
General Electric GSS25KGPACC Refrigerator
General Electric GSS25KGPAWW Refrigerator
General Electric GSS25KGPCBB Refrigerator
General Electric GSS25KGPCCC Refrigerator
General Electric GSS25KGPCWW Refrigerator
General Electric GSS25KGPDBB Refrigerator
General Electric GSS25KGPDCC Refrigerator
General Electric GSS25KGPDWW Refrigerator
General Electric GSS25KGPEBB Refrigerator
General Electric GSS25KGPECC Refrigerator
General Electric GSS25KGPEWW Refrigerator
General Electric GSS25KGPHBB Refrigerator
General Electric GSS25KGPHCC Refrigerator
General Electric GSS25KGPHWW Refrigerator
General Electric GSS25KGPJBB Refrigerator
General Electric GSS25KGPJCC Refrigerator
General Electric GSS25KGPJWW Refrigerator
General Electric GSS25KGSABB Refrigerator
General Electric GSS25KGSACC Refrigerator
General Electric GSS25KGSAWW Refrigerator
General Electric GSS25KGSBBB Refrigerator
General Electric GSS25KGSBCC Refrigerator
General Electric GSS25KGSBWW Refrigerator
General Electric GSS25KGSCBB Refrigerator
General Electric GSS25KGSCCC Refrigerator
General Electric GSS25KGSCWW Refrigerator
General Electric GSS25KGTABB Refrigerator
General Electric GSS25KGTAWW Refrigerator
General Electric GSS25KGTBBB Refrigerator
General Electric GSS25KGTBWW Refrigerator
General Electric GSS25KGTEBB Refrigerator
General Electric GSS25KGTEWW Refrigerator
General Electric GSS25KSTASS Refrigerator
General Electric GSS25KSTBSS Refrigerator
General Electric GSS25KSTESS Refrigerator
General Electric GSS25KSWASS REFRIGERATOR W SERIES
General Electric GSS25KSWCSS REFRIGERATOR W SERIES
General Electric GSS25LGMABB Refrigerator
General Electric GSS25LGMACC Refrigerator
General Electric GSS25LGMAWW Refrigerator
General Electric GSS25LGMBBB Refrigerator
General Electric GSS25LGMBCC Refrigerator
General Electric GSS25LGMBWW Refrigerator
General Electric GSS25LGMEBB Refrigerator
General Electric GSS25LGMECC Refrigerator
General Electric GSS25LGMEWW Refrigerator
General Electric GSS25LGMFBB Refrigerator
General Electric GSS25LGMFCC Refrigerator
General Electric GSS25LGMFWW Refrigerator
General Electric GSS25LGPABB Refrigerator
General Electric GSS25LGPACC Refrigerator
General Electric GSS25LGPAWW Refrigerator
General Electric GSS25LGTABB Refrigerator
General Electric GSS25LGTACC Refrigerator
General Electric GSS25LGTAWW Refrigerator
General Electric GSS25LGTBBB Refrigerator
General Electric GSS25LGTBCC Refrigerator
General Electric GSS25LGTBWW Refrigerator
General Electric GSS25LGTCBB Refrigerator
General Electric GSS25LGTCCC Refrigerator
General Electric GSS25LGTCWW Refrigerator
General Electric GSS25LGTDBB Refrigerator
General Electric GSS25LGTDCC Refrigerator
General Electric GSS25LGTDWW Refrigerator
General Electric GSS25LGTEBB Refrigerator
General Electric GSS25LGTECC Refrigerator
General Electric GSS25LGTEWW Refrigerator
General Electric GSS25LSMABS Refrigerator
General Electric GSS25LSMBBS Refrigerator
General Electric GSS25LSMEBS Refrigerator
General Electric GSS25LSMFBS Refrigerator
General Electric GSS25LSPABS Refrigerator
General Electric GSS25LSQASS Refrigerator
General Electric GSS25LSTASS Refrigerator
General Electric GSS25LSTBSS Refrigerator
General Electric GSS25LSTCSS Refrigerator
General Electric GSS25LSTDSS Refrigerator
  #2 (permalink)
Old 08-13-2017, 11:02 PM
Member
Dean Haustead is on a distinguished road
Default Freezer Problem
It may be occurred due to variable electric supply to your refrigerator. At first you should check this, if the problem does not solve then you should complain to your freezer dealer or company from where you bought it and describe your freezer problem.
  #3 (permalink)
Old 08-14-2017, 12:26 AM
Junior Member
Default
Power in the house is exceedingly stable and good quality. I have multiple uninterruptible power supplies feeding computers in the house, including one commercial grade supply. They monitor power quality, and alarm when there's any deviation. The commercial grade supply even knows how to email me if it senses a problem with line power. There have been no incidents.
I bought it from Sears. They want to charge me money to even talk to me, never mind diagnose it. I've already paid money for a diagnosis that was wrong. I'm searching for a little wisdom of the crowds here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Any assistance is appreciated - Very Cold Freezer and cold Fridge Pjrs Refrigerator & Freezer Repair 0 05-26-2016 10:02 PM
Freezer & Fridge not cold - coils cold, evap fan works but not running bootpdx Refrigerator & Freezer Repair 2 01-07-2015 08:52 AM
Freezer Cold But Not Freezing; Fridge Compartment Cold & Seems Fine ChuckM12 Refrigerator & Freezer Repair 1 08-29-2012 07:51 AM
Kernmore fridge/freezer.. Freezer fine fridge too cold poolsidepaul Refrigerator & Freezer Repair 7 04-19-2011 03:16 PM
Fridge & Freezer Cycle Cold To Warm Back To Cold terkel Refrigerator & Freezer Repair 1 09-25-2007 02:58 AM
