Discuss
Evap motor 12v or 9.75v?
 in
Refrigerator & Freezer Repair
GE evap motors --- When Testing the circuits for these motors, they are driven by 4, 8, or 12 vdc,
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Evap motor 12v or 9.75v?
  #1 (permalink)
Old 08-11-2017, 05:58 PM
Junior Member
DaaBoss is on a distinguished road
Default Evap motor 12v or 9.75v?
Model Number: psi23ngmbbb   Brand: GE   Age: More than 10 years
GE evap motors --- When Testing the circuits for these motors, they are driven by 4, 8, or 12 vdc, depending on how fast they are supposed to be driven at that time.
PROBLEM I don't understand that the ratings all say 9.75 Vdc for MY spec'ed Panasonic motor, which is model WR60X10185 for the GE refrig model psi23ngmbbb ---
SO, is the 9.75 vdc instead of 12vdc a nominal voltage rating, but you can drive it with 12vdc??
Seems VERY odd, but I know I'm seeing a little over 12vdc and I know this is the specified part. SOLVE this mystery spec issue?
Why I care --- I'm replacing the motor, once i have it apart no matter what. However, the part I use will be just using wire nuts and likely NOT the specific model motor. Since they are all Panasonic motors, SEEMS to me that if the specs are the same, ie, 9.75 v 3.3 W, it should work. BUT, I'm bothered even replacing it with the proper one, if the voltages are that different.
After I've repaired the problem--REPORT --- The voltages running the motor are indeed 12v (on high speed). The motor IS a 9.75, just as the spec says it should be. In my case, I did NOT replace the motor. Instead of a slow motor, I found that the fan's friction attachment had reamed out the hole, and it was laying on the motor. It turned, but much slower than it should have, and inconsistently. I inserted a fairly thin wire, in beside the shaft. This made it so tight it was hard to seat it onto the motor. Now, it is cooling properly.
Before, when the switch was depressed, you could hear the fan come on. But, unless you are paying attention to the sound, it was not quite as loud as it should have been. (It IS fairly loud when switch is held in, while the door is open.)
TIPS / WARNINGS ---
When disassembling, make sure you remove those brackets BEFORE you disconnect the Molex plugs. When they finally come out, your hand will, or can get cut from impacting that bracket. It's also a lot easier to get those plugs out.
Removing the "tabs" on the sides, holding some of the shelves up. -- I've seen suggestions that you can simply pop them up from the bottom. Not mine! In my case, I used a wrench to twist them around a few times, and pliers the finally extract them. They were held in with BOTH heavy goppy glue AND a huge staple, that my wrench bent enough to come out. I bent the staple back and it mostly went back in, and will stay in place. What a crappy design though!
Related Models
General Electric PSI23NGMBBB Refrigerator
General Electric PSI23NGMBCC Refrigerator
General Electric PSI23NGMBWW Refrigerator
General Electric PSI23NGMCBB Refrigerator
General Electric PSI23NGMCCC Refrigerator
General Electric PSI23NGMCWW Refrigerator
General Electric PSI23NGMDBB Refrigerator
General Electric PSI23NGMDCC Refrigerator
General Electric PSI23NGMDWW Refrigerator
General Electric PSI23NGNABB Refrigerator
General Electric PSI23NGNACC Refrigerator
General Electric PSI23NGNAWW Refrigerator
General Electric PSI23NGPABB Refrigerator
General Electric PSI23NGPACC Refrigerator
General Electric PSI23NGPAWW Refrigerator
General Electric PSI23NGPBBB Refrigerator
General Electric PSI23NGPBCC Refrigerator
General Electric PSI23NGPBWW Refrigerator
General Electric PSI23NGPCBB Refrigerator
General Electric PSI23NGPCCC Refrigerator
General Electric PSI23NGPCWW Refrigerator
General Electric PSI23NGRCBV Refrigerator
General Electric PSI23NGRCCV Refrigerator
General Electric PSI23NGRCWV Refrigerator
General Electric PSI23NGRDBV Refrigerator
General Electric PSI23NGRDCV Refrigerator
General Electric PSI23NGRDWV Refrigerator
General Electric PSI23NGTABV Refrigerator
General Electric PSI23NGTAWV Refrigerator
General Electric PSI23NGTCBV Refrigerator
General Electric PSI23NGTCCV Refrigerator
General Electric PSI23NGTCWV Refrigerator
General Electric PSI23NGTDBV Refrigerator
General Electric PSI23NGTDCV Refrigerator
General Electric PSI23NGTDWV Refrigerator
General Electric PSI23NGTEBV Refrigerator
General Electric PSI23NGTECV Refrigerator
General Electric PSI23NGTEWV Refrigerator
General Electric PSI23NGWABV REFRIGERATOR W SERIES
General Electric PSI23NGWACV REFRIGERATOR W SERIES
General Electric PSI23NGWAWV REFRIGERATOR W SERIES
General Electric PSI23NGWCBV REFRIGERATOR W SERIES
General Electric PSI23NGWCWV REFRIGERATOR W SERIES
General Electric PSI23NGWDBV REFRIGERATOR W SERIES
General Electric PSI23NGWDWV REFRIGERATOR W SERIES
General Electric PSI23NSTASV Refrigerator
General Electric PSI23NSTCSV Refrigerator
General Electric PSI23NSTESV Refrigerator
General Electric PSI23NSTFSV REFRIGERATOR T SERIES
General Electric PSI23NSWASV REFRIGERATOR W SERIES
General Electric PSI23SCMAFBS Refrigerator
General Electric PSI23SCNAFBS Refrigerator
General Electric PSI23SCPABS Refrigerator
General Electric PSI23SCRASV Refrigerator
General Electric PSI23SCRBSV Refrigerator
General Electric PSI23SCRCSV Refrigerator
General Electric PSI23SCRDSV Refrigerator
General Electric PSI23SCRESV Refrigerator
General Electric PSI23SCRGSV Refrigerator
General Electric PSI23SCRHSV REFRIGERATOR R SERIES
General Electric PSI23SGMAFBS Refrigerator
General Electric PSI23SGMBFBS Refrigerator
General Electric PSI23SGMCFBS Refrigerator
General Electric PSI23SGMDFBS Refrigerator
General Electric PSI23SGNAFBS Refrigerator
General Electric PSI23SGPABS Refrigerator
General Electric PSI23SGRASV Refrigerator
General Electric PSI23SGRBSV Refrigerator
General Electric PSI23SGRCSV Refrigerator
General Electric PSI23SGRDSV Refrigerator
General Electric PSIC3RGXAFBV REFRIGERATOR X SERIES
General Electric PSIC3RGXAFCV REFRIGERATOR X SERIES
General Electric PSIC3RGXAFWV REFRIGERATOR X SERIES
General Electric PSIC3RGXCFBV REFRIGERATOR X SERIES
General Electric PSIC3RGXCFCV REFRIGERATOR X SERIES
General Electric PSIC3RGXCFWV REFRIGERATOR X SERIES
General Electric PSIC5RGXAFBV REFRIGERATOR X SERIES
General Electric PSIC5RGXAFCV REFRIGERATOR X SERIES
General Electric PSIC5RGXAFWV REFRIGERATOR X SERIES
General Electric PSIC5RGXCFBV REFRIGERATOR X SERIES
General Electric PSIC5RGXCFCV REFRIGERATOR X SERIES
General Electric PSIC5RGXCFWV REFRIGERATOR X SERIES
General Electric PSJC5YGXBFBV REFRIGERATOR X SERIES
General Electric PSJC5YGXBFWV REFRIGERATOR X SERIES
General Electric PSJC5YGXCFBV REFRIGERATOR X SERIES
General Electric PSJC5YGXCFWV REFRIGERATOR X SERIES
General Electric PSK25MGRBCCC Refrigerator
General Electric PSK25MGSBCCC Refrigerator
General Electric PSK25MGSDCCC Refrigerator
General Electric PSK25MGSECCC REFRIGERATOR S SERIES
General Electric PSK25MGWACCC REFRIGERATOR W SERIES
General Electric PSK25MGWHCCC REFRIGERATOR W SERIES
General Electric PSK25MGWICCC REFRIGERATOR W SERIES
General Electric PSK25NGMACCC Refrigerator
General Electric PSK25NGMACWW Refrigerator
General Electric PSK25NGNCCCC Refrigerator
General Electric PSK25NGNDCCC Refrigerator
General Electric PSK25NGNDCWW Refrigerator
General Electric PSK25NGNECWW Refrigerator
General Electric PSK25NGSACCC Refrigerator
General Electric PSK25NGSACWW Refrigerator
General Electric PSK25NGSBCCC Refrigerator
General Electric PSK25NGSBCWW Refrigerator
General Electric PSK25NGSCCCC Refrigerator
General Electric PSK25NGSCCWW Refrigerator
General Electric PSK25NGSDCCC Refrigerator
General Electric PSK25NGSDCWW Refrigerator
General Electric PSK25NGSECCC REFRIGERATOR S SERIES
General Electric PSK25NGSECWW REFRIGERATOR S SERIES
General Electric PSK25NGWACCC REFRIGERATOR W SERIES
General Electric PSK25NGWACWW REFRIGERATOR W SERIES
General Electric PSK25NGWHCWW REFRIGERATOR W SERIES
General Electric PSK25NGWICWW REFRIGERATOR W SERIES
General Electric PSK25TGXACCC REFRIGERATOR X SERIES
General Electric PSK25TGXBCCC REFRIGERATOR X SERIES
General Electric PSK25VGXACCC REFRIGERATOR X SERIES
General Electric PSK27MGMACCC Refrigerator
General Electric PSK27MGNCCCC Refrigerator
General Electric PSK27MGNDCCC Refrigerator
General Electric PSK27MGSBCCC Refrigerator
Last edited by DaaBoss : 08-22-2017 at 05:19 PM. Reason: adding AFTER fully repaired
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Evap Fan Motor jpsims Refrigerator & Freezer Repair 1 06-23-2015 05:54 PM
Evap Fan Motor RichardH Refrigerator & Freezer Repair 1 09-20-2011 04:55 AM
Is it the evap fan motor? ryansmom Refrigerator & Freezer Repair 0 12-26-2010 12:26 AM
Evap Fan Motor thumbrfg Refrigerator & Freezer Repair 0 04-08-2009 02:02 PM
evap fan motor MMCMUSNRET Refrigerator & Freezer Repair 1 10-11-2008 12:45 PM
