Discuss
Evaporator fan mounting - repair or replace? And Black Goop?
 in
Refrigerator & Freezer Repair
We have been having problems with the temperature in our 5yo Samsung refrigerator fluctuating and being too high. Based on
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Evaporator fan mounting - repair or replace? And Black Goop?
  #1 (permalink)
Old 08-05-2017, 01:02 PM
Junior Member
SoftwareGuy is on a distinguished road
Default Evaporator fan mounting - repair or replace? And Black Goop?
Model Number: RS265TDRS   Brand: Samsung   Age: 5 - 10 years
We have been having problems with the temperature in our 5yo Samsung refrigerator fluctuating and being too high. Based on Internet research, all signs pointed to freezing over or other issue with the evaporator fan, so I took the back lower panel off to see what I could find. There was indeed a large block of ice there.
Unfortunately, the ice had frozen onto the styrofoam frame that sits between the back of the fridge (around the evaporator coil) and the exposed panel. When I removed the panel, I broke off a piece of the stryofoam frame. The pictures show the frame put back together, and the broken chunk.
My question is, do I need to buy a whole new panel assembly ($125)? Or can I get away with a bit of glue to solidify the frame and put everything back together?
Finally, there is was some kind of black goop (3rd picture) mixed in with the ice that was on the back of the fridge above the evaporator coil. It has a rubbery consistency like some kind of putty... not totally rigid, but pretty solid at room temperature. It did not appear in the various videos I watched to figure out what I needed to do, and it looks almost like it dripped down from the tube above it. Should I worry about it?
Thanks for any advice you have!
Related Models
 RS2666SL REF - SXS
 RS2666SW REF - SXS
 RS267LABP REF - SXS
 RS267LABP/XAA REF - SXS
 RS267LASH REF - SXS
 RS267LASH/XAA REF - SXS
 RS269LARS REF - SXS
 RS2777SL REF - SXS
Hoover RS27D011 REF - SXS/I&W
Amana RS30 MWAVE- CNTRTP / STAND ALONE
Whirlpool RS3025XBN0 30" ELECTRIC SLIDE-IN RANGE STANDARD CLEAN OVEN
Whirlpool RS3025XBN1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS3025XBW0 30" ELECTRIC SLIDE-IN RANGE STANDARD CLEAN OVEN
Whirlpool RS3025XBW1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS310PXBH0 30" ELECTRIC SLIDE-IN RANGE STANDARD CLEAN OVEN
Whirlpool RS310PXEB0 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS310PXEB1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS310PXGN0 ELECTRIC RANGE
Whirlpool RS310PXGW0 ELECTRIC RANGE
Whirlpool RS313PXTT0 Ranges, Electric*
Whirlpool RS313PXYH0 Ranges, Electric*
Whirlpool RS313PXYH2 Ranges, Electric*
Whirlpool RS333PXTT0 Ranges, Electric
Frigidaire RS33BFL0 Frg(v2) / Electric Range
Frigidaire RS33BFL1 Frg(v4) / Electric Range
Frigidaire RS33BFL2 Frg(v2) / Electric Range
Frigidaire RS33BFW0 Frg(v1) / Electric Range
Frigidaire RS33BFW1 Frg(v3) / Electric Range
Frigidaire RS33BFW2 Frg(v1) / Electric Range
Frigidaire RS33BNL1 Frg(v2) / Electric Range
Frigidaire RS33BNL2 Frg(v2) / Electric Range
Frigidaire RS33BNL3 Frg(v2) / Electric Range
Frigidaire RS33BNW1 Frg(v1) / Electric Range
Frigidaire RS33BNW2 Frg(v1) / Electric Range
Frigidaire RS33BNW3 Frg(v1) / Electric Range
Frigidaire RS34BFL0 Frg(v2) / Electric Range
Frigidaire RS34BFL1 Frg(v4) / Electric Range
Frigidaire RS34BFL2 Frg(v2) / Electric Range
Frigidaire RS34BFW0 Frg(v1) / Electric Range
Frigidaire RS34BFW1 Frg(v3) / Electric Range
Frigidaire RS34BFW2 Frg(v1) / Electric Range
Frigidaire RS35BAA2 Frg(v4) / Electric Range
Frigidaire RS35BAA3 Frg(v9) / Electric Range
Frigidaire RS35BAA4 Frg(v4) / Electric Range
Frigidaire RS35BAF2 Frg(v3) / Electric Range
Frigidaire RS35BAF3 Frg(v8) / Electric Range
Frigidaire RS35BAF4 Frg(v3) / Electric Range
Frigidaire RS35BAH2 Frg(v5) / Electric Range
Frigidaire RS35BAH3 Frg(v10) / Electric Range
Frigidaire RS35BAH4 Frg(v5) / Electric Range
Frigidaire RS35BAL1 Frg(v14) / Free Standing Electric Range
Frigidaire RS35BAL2 Frg(v2) / Electric Range
Frigidaire RS35BAL3 Frg(v7) / Electric Range
Frigidaire RS35BAL4 Frg(v2) / Electric Range
Frigidaire RS35BAW1 Frg(v15) / Free Standing Electric Range
Frigidaire RS35BAW2 Frg(v1) / Electric Range
Frigidaire RS35BAW3 Frg(v6) / Electric Range
Frigidaire RS35BAW4 Frg(v1) / Electric Range
Whirlpool RS363BXTT0 Ranges, Electric*
Whirlpool RS363BXTT1 Ranges, Electric*
Whirlpool RS363BXTT2 Ranges, Electric*
Whirlpool RS363PCYW1 Ranges, Electric*
Whirlpool RS363PXYH0 Ranges, Electric*
Whirlpool RS363PXYH2 Ranges, Electric*
Whirlpool RS363PXYQ0 Ranges, Electric*
Whirlpool RS363PXYQ2 Ranges, Electric*
Whirlpool RS373PXW3 ELECTRIC DOWNDRAFT SELF CLEAN OVEN
Whirlpool RS373PXWT0 30" ELECTRIC DOWNDRAFT SELF-CLEAN OVEN
Whirlpool RS373PXWT1 30" ELECTRIC DOWNDRAFT SELF-CLEAN OVEN
Whirlpool RS373PXWT2 ELECTRIC DOWNDRAFT SELF-CLEAN OVEN
Whirlpool RS373PXWW0 30" ELECTRIC DOWNDRAFT SELF-CLEAN OVEN
Whirlpool RS385PCBN0 30" ELECTRIC SLIDE-IN RANGE SELF-CLEAN OVEN
Whirlpool RS385PCBN1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS385PCBN2 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS385PCBW0 30" ELECTRIC SLIDE-IN RANGE SELF-CLEAN OVEN
Whirlpool RS385PCBW1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS385PCBW2 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS385PXBH0 30" ELECTRIC SLIDE-IN RANGE SELF-CLEAN OVEN
Whirlpool RS385PXBQ0 30" ELECTRIC SLIDE-IN RANGE SELF-CLEAN OVEN
Whirlpool RS385PXEB0 ELECTRIC RANGE
Whirlpool RS385PXEB1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS385PXEQ0 ELECTRIC RANGE
Whirlpool RS385PXEQ1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS386PXBB0 30" ELECTRIC SLIDE-IN RANGE SELF-CLEAN OVEN
Whirlpool RS386PXBB1 30" ELECTRIC SLIDE-IN RANGE SELF-CLEAN OVEN
Whirlpool RS386PXBQ0 30" ELECTRIC SLIDE-IN RANGE SELF-CLEAN OVEN
Whirlpool RS386PXBQ1 30" ELECTRIC SLIDE-IN RANGE SELF-CLEAN OVEN
Whirlpool RS386PXEB0 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS386PXEB1 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS386PXEQ0 30" ELECTRIC SLIDE-IN RANGE
Whirlpool RS386PXEQ1 30" ELECTRIC SLIDE-IN RANGE
Amana RS40 MWAVE- CNTRTP / STAND ALONE
Amana RS414T MWAVE- CNTRTP / STAND ALONE
Amana RS415T MWAVE- CNTRTP / STAND ALONE
General Electric RS42*02 Electric range
General Electric RS42*03 Electric range
General Electric RS42*J1 Electric range
General Electric RS42*J2 Electric range
General Electric RS42*J3 Electric range
General Electric RS42*J4 Electric range
General Electric RS42*J5 Electric range
General Electric RS42*J6 Electric range
Amana RS457P MWAVE- CNTRTP / STAND ALONE
Amana RS458P MWAVE- CNTRTP / STAND ALONE
General Electric RS46*03 Electric range
General Electric RS46*04 Electric range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Should I replace my evaporator motor tylerhead24 Refrigerator & Freezer Repair 1 12-03-2012 05:26 AM
replace evaporator or condencer bhvacr Refrigerator & Freezer Repair 1 01-27-2012 03:34 AM
Evaporator Repair Steveor Refrigerator & Freezer Repair 1 01-04-2010 02:29 AM
Black Glasstop repair for my Range rcpjma Oven Repair (including Ranges and Cooktops) 1 01-05-2009 04:22 AM
maytag wont spin after installing a Mounting stem repair kit grouse Washer Repair 1 10-07-2008 02:55 AM
