The problem was that the freezer and fridge was not getting cold enough. Freezer go from 15 to 20 degrees. Fridge part is around 40-45. The fan runs all the time. Sometimes the temps get closer to where they need to be but not for long. Things I have checked. Has a new defrost timer. defrost Heater works. tested the defrost thermostat. The damper is working. the bottom plug is clear on fridge side. All fans are working. I checked the seal around it. Coils are clean under fridge. Transamguy attached the following image(s):
