Discuss
Amana Upright Frostfree Freezer Issue
 in
Refrigerator & Freezer Repair
Food is starting to thaw and temperature around 40. Here is what I have done: 1). Diagnostics came back with
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana Upright Frostfree Freezer Issue
  #1 (permalink)
Old 07-15-2017, 02:39 PM
Junior Member
ram5thwheel is on a distinguished road
Question Amana Upright Frostfree Freezer Issue
Model Number: AZF33X20DW00   Brand: Amana   Age: 1 - 5 years
1). Diagnostics came back with no fault code.
2). Removed evaporator cover and top coils totally iced up restricting air flow
3). Removed all ice build up and allowed to come to room temp. Cleaned drip pan of water buildup.
4). Reassembled and turned on to default temp condition. Compressor ran approximately 1 minute and then shut down.
5). Diagnostics still no fault code.
6). Installed new control board/unit. Diagnostics showed evaporator thermistor code. Measured resistance and is not open. (not sure what value should be at room temp)
7). Checked wiring from control unit to thermistor and appears not open. Ran diagnostics again and now no fault code.
8). Put in diagnostic mode again and turned on compressor. (waiting to see if it gets cold)
Not sure where to go from here. If unit freezes with compressor only in diagnostic mode then would suspect problem with defrost circuit. Looking for suggestions. Electronics technician but not good with refrigeration.
Unit only 2 years almost to date.
ram5thwheel
Related Models
General Electric AZR206DBV1 Zoneline
General Electric AZR206DBV2 Zoneline
General Electric AZR206DBV3 Zoneline
General Electric AZR206DBV4 Room air conditioner
General Electric AZR206EDV2 Zoneline
General Electric AZR206EDV4 Zoneline
General Electric AZR206EDV5 Room air conditioner
General Electric AZR209DBV1 Zoneline
General Electric AZR209DBV2 Zoneline
General Electric AZR209DBV3 Zoneline
General Electric AZR209DBV4 Room air conditioner
General Electric AZR209EDV2 Zoneline
General Electric AZR209EDV3 Zoneline
General Electric AZR209EDV4 Room air conditioner
General Electric AZR212DBV1 Zoneline
General Electric AZR212DBV2 Zoneline
General Electric AZR212DBV3 Zoneline
General Electric AZR212DBV4 Room air conditioner
General Electric AZR212EDV2 Zoneline
General Electric AZR212EDV3 Zoneline
General Electric AZR212EDV4 Room air conditioner
General Electric AZR215DBV1 Zoneline
General Electric AZR215DBV2 Zoneline
General Electric AZR215DBV3 Zoneline
General Electric AZR215DBV4 Room air conditioner
General Electric AZR215EDV2 Zoneline
General Electric AZR215EDV3 Zoneline
General Electric AZR215EDV4 Room air conditioner
General Electric AZR306DBV1 Zoneline
General Electric AZR306DBV2 Zoneline
General Electric AZR306EDV1 Zoneline
General Electric AZR306EDV4 Zoneline
General Electric AZR309DBV1 Zoneline
General Electric AZR309DBV2 Zoneline
General Electric AZR309EDV1 Zoneline
General Electric AZR309EDV2 Zoneline
General Electric AZR312DBV1 Zoneline
General Electric AZR312DBV2 Zoneline
General Electric AZR312EDV1 Zoneline
General Electric AZR312EDV2 Zoneline
General Electric AZR315DBV1 Zoneline
General Electric AZR315DBV2 Zoneline
General Electric AZR315EDV1 Zoneline
General Electric AZR315EDV2 Zoneline
Admiral AZS22000 REF - SXS
General Electric AZW206DBV1 Zoneline
General Electric AZW209DBV1 Zoneline
General Electric AZW212DBV1 Zoneline
General Electric AZW215DBV1 Zoneline
General Electric AZW306DBV1 Zoneline
General Electric AZW306DBV2 Zoneline
General Electric AZW306DBV3 Room air conditioner
General Electric AZW309DBV1 Zoneline
General Electric AZW309DBV2 Zoneline
General Electric AZW309DBV3 Room air conditioner
General Electric AZW312DBV1 Zoneline
General Electric AZW312DBV2 Zoneline
General Electric AZW312DBV3 Room air conditioner
General Electric AZW315DBV1 Zoneline
General Electric AZW315DBV2 Zoneline
General Electric AZW315DBV3 Room air conditioner
Whirlpool B113B AIR CONDITIONER
Magic Chef B11GA-1 RANGE- F/S STD GAS
Hardwick B11GA-2W RANGE- F/S STD GAS
Magic Chef B11GN-1 RANGE- F/S STD GAS
Hardwick B11GN-2W RANGE- F/S STD GAS
Magic Chef B11GY-1 RANGE- F/S STD GAS
Hardwick B11GY-2W RANGE- F/S STD GAS
Amana B12C3EV ROOM AIR CONDITIONER
Amana B12C3EW ROOM AIR CONDITIONER
Amana B12C3HES ROOM AIR CONDITIONER
Amana B12C3HEW ROOM AIR CONDITIONER
Amana B12C3S ROOM AIR CONDITIONER
Amana B12C3V ROOM AIR CONDITIONER
Amana B12C3W ROOM AIR CONDITIONER
Amana B12M22PA ROOM AIR CONDITIONER
Amana B12M22PC ROOM AIR CONDITIONER
Amana B12M32PAE ROOM AIR CONDITIONER
Amana B12M32PAEH ROOM AIR CONDITIONER
Amana B12M32PCE ROOM AIR CONDITIONER
Amana B136CAL1 REF - BOTTOM MOUNTS
Amana B136CAL3 REF - BOTTOM MOUNTS
Amana B136CAR1 REF - BOTTOM MOUNTS
Amana B136CAR3 REF - BOTTOM MOUNTS
Maytag B15A-2RNTP REF - TOP MOUNT
Frigidaire B15D0 Frg(v0) / Freezer
Frigidaire B15E0 Frg(v0) / Freezer
Frigidaire B15H0 Frg(v0) / Freezer
Maytag B15N-2RNTP REF - TOP MOUNT
Frigidaire B15S0 Frg(v0) / Freezer
Frigidaire B15W0 Frg(v0) / Freezer
Maytag B15Y-2RNTP REF - TOP MOUNT
Maytag B17A-2RNTP REF - TOP MOUNT
Maytag B17N-2RNTP REF - TOP MOUNT
Maytag B17Y-2RNTP REF - TOP MOUNT
Amana B18C3EV ROOM AIR CONDITIONER
Amana B18C3HES ROOM AIR CONDITIONER
Amana B18C3HEW ROOM AIR CONDITIONER
Amana B18M33PAE ROOM AIR CONDITIONER
Amana B18M33PAEH ROOM AIR CONDITIONER
Amana B18M33PCE ROOM AIR CONDITIONER
Amana B18M33PCEH ROOM AIR CONDITIONER
Frigidaire B30LSPSC0 Frg(v0) / Upright Freezer
Frigidaire B30LSPSC1 Frg(v0) / Freezer
Magic Chef B31FA-2KW RANGE- F/S STD GAS
  #2 (permalink)
Old 07-16-2017, 05:30 AM
Junior Member
Default Update to problem
Freezer ran overnight and maintaining zero degree temperature. This seems to be an intermittent problem. Curious as to why the fault code appeared after replacing the control board but then disappeared. Thought that there may be an issue with one of the two conductors running from control board to the thermister or connector reliability. Put conductive grease on two connectors and worked connectors several times.
Powered down unit and going to re-verify wiring. Would be great help if someone could respond with resistance measurements at room temperature or whatever for thermister (part # W10383615). I do know that it is not open.
Thanks in advance for help,
ram5thwheel
  #3 (permalink)
Old 07-23-2017, 05:07 AM
Junior Member
Thumbs down Solved
Solved the problem but not with any help or should I say, responses to my problem.
Evaporator thermistor resistance measured approximately 150 ohms when measured out of circuit. After checking with an appliance store tech and having them look up on their engineering site the typical resistance of the replacement part (2,700 +/- 3% ohms) I ordered the replacement part and system is back up and running without issues.
Question why the diagnostics did not repeatedly show a diagnostic code with a definite defective part. In any case, closed!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice in Frostfree Upright Freezer ronjin Refrigerator & Freezer Repair 1 05-29-2014 01:25 AM
Kenmore Upright Freezer Temperature Control Issue billo45 Refrigerator & Freezer Repair 7 02-18-2013 10:44 PM
3 Year Old Frigidaire Upright Freezer Defrost Issue rankins66 Refrigerator & Freezer Repair 6 11-06-2012 12:27 PM
Frigidaire upright freezer issue kimorfreds Refrigerator & Freezer Repair 5 12-18-2010 08:01 PM
