Discuss
Kitchenaid Fridge Lights, Ice, and Water not working
 in
Refrigerator & Freezer Repair
Our Kitchen Aid fridge began having issues yesterday. My mother in law tripped a ground fault circuit that is before
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kitchenaid Fridge Lights, Ice, and Water not working
  #1 (permalink)
Old 07-11-2017, 06:15 AM
Junior Member
Biglurr54 is on a distinguished road
Default Kitchenaid Fridge Lights, Ice, and Water not working
Brand: Kitchen Aid   Age: 1 - 5 years
Our Kitchen Aid fridge began having issues yesterday. My mother in law tripped a ground fault circuit that is before the fridge while I was at work. I came home and reset the circuit and the fridge started back up. When it started back up, the interior lights would not work. They are all LED so its not a bulb socket issue. Also the Ice dispenser did not work, the water dispenser didn't work and the controls on the door were all lit up and would respond to touch but then they would quickly default back within 3 seconds.
I couldnt make any changed on any settings. I unplugged the fridge and gave it a bit and plugged it back in. It didnt change anything.
I pulled out the Ice bin and it was jammed up with a hunk of ice. I remember earlier that morning, i tried to get ice out and the motor spun but it couldnt get the ice out and it seemed jammed. I put everything back together and nothing changed.
I noticed this morning that everything on the control panel is lit up. Normally they turn off when its not being used.
I cant find the model number for the fridge. There is nothing on the doors or inside the fridge. It is similar and could be KRMF706ESS. It looks the same as that one.
1. Where can I find the tag that has the actual model number?
2. How do I reset the computer?
3. How can i check the error codes?
4. Any other ideas of things I can do/try.
Thank you all for your assistance.
  #2 (permalink)
Old 01-16-2018, 04:47 PM
Junior Member
sunbdunn18436 is on a distinguished road
Default Kitchenaid 5-door
Hi - I'm having the exact same issue. Fridge was working fine. Opened the door and no LED lights on for any of the doors. Front control panel lights up, but no water or ice. Fridge and freezer appear to be cooling properly. Any ideas?
Thanks,
Bobby
  #3 (permalink)
Old 04-19-2018, 09:51 PM
Junior Member
Jamel is on a distinguished road
Default Lights,ice/water not working
Hi friends,if you a wondering why the light in your kitchenaid 5 door refrigerator goes out. It has something to do with the meat,beverage, cheese drawer display plug.i have spent two hour trouble shooting this problem all lights out and water and ice inoperable. Just unplug the plug behind the door and all light and water will work I am still trying to figure out what part is causing this but all light and water is working. Hope this help😊
  #4 (permalink)
Old 04-19-2018, 09:57 PM
Junior Member
Hi friends,if you a wondering why the light in your kitchenaid 5 door refrigerator goes out. It has something to do with the meat,beverage, cheese drawer display plug.i have spent two hour trouble shooting this problem all lights out and water and ice inoperable. Just unplug the plug behind the door and all light and water will work I am still trying to figure out what part is causing this but all light and water is working. Hope this help�� I will post the part needed soon once I look into this further.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid fridge ice and water dispensers not working Jim G42 Refrigerator & Freezer Repair 0 07-02-2017 06:34 PM
KSCS25FTMS - Kitchenaid Fridge Lights/IceMaker Not Working - But Fridge/Freezer Work cgsauer Refrigerator & Freezer Repair 1 04-19-2015 06:48 PM
Kitchenaid Double Oven Lights Not Working curlw Oven Repair (including Ranges and Cooktops) 1 05-08-2013 02:17 AM
Kitchenaid Lights not working but still cooling Ltorres Refrigerator & Freezer Repair 0 05-11-2011 02:49 PM
Kitchenaid Lights not working after latch repaired catsam Dishwasher Repair 4 06-30-2010 01:55 PM
