Discuss
GE side-by-side replace water line
 in
Refrigerator & Freezer Repair
My GE Side-by-side refrigerator water line had damage where it entered the freezer door hinge. This particular model of GE
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE side-by-side replace water line
  #1 (permalink)
Old 07-10-2017, 08:22 AM
Junior Member
richbenson is on a distinguished road
Default GE side-by-side replace water line
Brand: GE   Age: 1 - 5 years
My GE Side-by-side refrigerator water line had damage where it entered the freezer door hinge. This particular model of GE did not have a serviceable waterline, until now. If you have a damaged waterline, it will need to be removed from the freezer door. Here are the steps to replace the water line.
-Turn off water supply line and unplug refrigerator.
-Remove the kick plate, remove the 1/4 waterline from the union adapter by pushing in on the adapter ring, and pulling the hose simultaneously.
-Remove the plate from top of freezer door hinge, remove 2 screws and disconnect electric connector.
-Pull up on freezer door to lift door above bottom hinge and the door can be removed and placed on the floor.
-Under the hole for the ice dispenser, on the inside of the freezer door, I used a cutting wheel (or dremel) to cut 12” width, and 24” length rectangle out of plastic door out.
-Excavate foam insulation to expose water line (which is fused and taped to door) under the foam. ***Be sure to excavate most of the insulation surrounding the water line so it can be dislodged, and pulled out of the door.
-Replace the water line with ” tubing from hardware store. Feed the water line back up thru the door hinge and pull into door, and feed hose into water dispenser tube holder.
-Use can of spray foam to re-insulate door, while foam is beginning to set - replace the cut out piece of plastic back into place so foam can fuse to it. Use tape to hold plastic pieces until foam sets.
-Replace freezer door back onto bottom hinge and tighten screws, reconnect electric connector
-Reconnect water line to union adapter (in my case I replaced water line with ” tube and used a ” union adapter to reconnect water line.
-Use bathroom caulk (white) to fill the areas/gaps where the cut out plastic plate was removed to help make a nice seal.
-Restore power to refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
how do I replace water line in freezer door of whirlpool side by side Todd Overton Refrigerator & Freezer Repair 35 08-09-2016 06:40 PM
Side by side, water line frozen, melted switch from hair dryer daninmd Refrigerator & Freezer Repair 2 02-27-2012 08:56 AM
How do I replace the water line in freezer door of GE side by side? bthoma121 Refrigerator & Freezer Repair 4 08-11-2011 03:40 AM
how do I replace water line in freezer door of an Amana side by side clubberlang88 Refrigerator & Freezer Repair 1 03-31-2010 12:18 AM
how do I replace water line in freezer door of an Amana side by side clubberlang88 Refrigerator & Freezer Repair 0 03-21-2010 09:04 PM
