Discuss
Refrigerator Cooling Rate
 in
Refrigerator & Freezer Repair
Hi, I'm a little concerned that my refrigerator may be going bad. It is cooling but seems to be slow
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator Cooling Rate
  #1 (permalink)
Old 07-09-2017, 01:10 AM
Junior Member
dorkus is on a distinguished road
Default Refrigerator Cooling Rate
Brand: -brand-   Age: 5 - 10 years
I'm a little concerned that my refrigerator may be going bad. It is cooling but seems to be slow and not sure how slow it's supposed to be.
For example, when I get wake up in the morning and the fridge has been closed all night, the temp is very cold (usually 33 to 36 F)...However, when I open it a few times, even if only for a few seconds, the temp quickly jumps up to the 43 to 46F range and takes several hours of being closed for it to re-cool back to under 40 degrees...Sometimes it will stay in the 42 to 44 range for 4 to 6 hours before it finally getting back to 40 or below...Is this normal or is that cooling too slowly?
Based on the food safety guidelines that food should not be above 40 degrees for more than 2 hours, I assume mine is cooling too slowly? The freezer seems to maintain 0 degrees.
As a side note, I have noticed the past few months that when the unit first turns on after a defrost cycle, it makes a strange vibration/motor-racing sound for about the first 10 seconds. Not very loud, but enough to notice it from across the room. Is that a sign of something?
Thanks for any help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator/Freezer stops cooling, then starts cooling, then stops cooling angiebritt Refrigerator & Freezer Repair 4 05-16-2016 05:31 AM
tumblers don't spin at the same rate kauaiguy Washer Repair 0 01-12-2012 02:42 PM
Inlet Valve Flow Rate ynyng Dishwasher Repair 0 11-24-2011 11:10 AM
Slow fill rate atcapecod Dishwasher Repair 0 04-26-2010 09:10 AM
