Discuss
Thumping noise and no power
 in
Refrigerator & Freezer Repair
My husband and I have a 7 year old Samsung french door refrigerator with a drawer freezer. The fridge has
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Thumping noise and no power
  #1 (permalink)
Old 07-07-2017, 07:03 PM
Junior Member
flickf9234 is on a distinguished road
Default Thumping noise and no power
Model Number: rfg298aapn/xaa   Brand: Samsung   Age: 5 - 10 years
My husband and I have a 7 year old Samsung french door refrigerator with a drawer freezer. The fridge has worked awesome since day one, despite hearing how many people have had issues with their's. On Sunday morning, I was awakened by the fridge making a steady thumping noise that seemed to be coming from the top of the fridge cabinet and small spurts of water coming from the water dispenser. The control panel on the front was completely blank and when I opened the fridge and freezer compartments, there were no lights whatsoever and I could tell that everything was warmer than it should be. My husband had just gotten his lunch out for work just a few hours earlier and it was working absolutely fine. I'm leaning towards a bad control board which I don't mind replacing since the fridge has worked so well for us over the years but I want to make sure that's the problem before I tear it completely apart. Samsung has been less than helpful and I don't really want to spend the money on a tech to come out and tell me something I might be able to take care of myself. Thanks for the help!
Related Models
Amana RFS10 COMMERCIAL MICROWAVES
Amana RFS10B COMMERCIAL MICROWAVES
Amana RFS10MP COMMERCIAL MICROWAVES
Amana RFS10MP2 COMMERCIAL MICROWAVES
Amana RFS10S COMMERCIAL MICROWAVES
Amana RFS10SE COMMERCIAL MICROWAVES
Amana RFS10SW2 COMMERCIAL MICROWAVES
Amana RFS10SW2A COMMERCIAL MICROWAVES
Amana RFS11B COMMERCIAL MICROWAVES
Amana RFS11BT COMMERCIAL MICROWAVES
Amana RFS11LW COMMERCIAL MICROWAVES
Amana RFS11LWT COMMERCIAL MICROWAVES
Amana RFS11MP2 COMMERCIAL MICROWAVES
Amana RFS11MP2T COMMERCIAL MICROWAVES
Amana RFS11MPLW COMMERCIAL MICROWAVES
Amana RFS11MPLWT COMMERCIAL MICROWAVES
Amana RFS11SW2 COMMERCIAL MICROWAVES
Amana RFS11SW2T COMMERCIAL MICROWAVES
Amana RFS12MPS COMMERCIAL MICROWAVES
Amana RFS12MPSA COMMERCIAL MICROWAVES
Amana RFS12S COMMERCIAL MICROWAVES
Amana RFS12SW2 COMMERCIAL MICROWAVES
Amana RFS12SW2A COMMERCIAL MICROWAVES
Amana RFS18G COMMERCIAL MICROWAVES
Amana RFS18MPS COMMERCIAL MICROWAVES
Amana RFS510SE COMMERCIAL MICROWAVES
Amana RFS511 COMMERCIAL MICROWAVES
Amana RFS511MP COMMERCIAL MICROWAVES
Amana RFS511SW2 COMMERCIAL MICROWAVES
Amana RFS511SW2A COMMERCIAL MICROWAVES
Amana RFS518S COMMERCIAL MICROWAVES
Amana RFS57SE COMMERCIAL MICROWAVES
Amana RFS58MP COMMERCIAL MICROWAVES
Amana RFS58SE COMMERCIAL MICROWAVES
Amana RFS59MP COMMERCIAL MICROWAVES
Amana RFS6 COMMERCIAL MICROWAVES
Amana RFS8 COMMERCIAL MICROWAVES
Amana RFS8B COMMERCIAL MICROWAVES
Amana RFS8MP COMMERCIAL MICROWAVES
Amana RFS8MPK COMMERCIAL MICROWAVES
Amana RFS8SE COMMERCIAL MICROWAVES
Amana RFS8SW COMMERCIAL MICROWAVES
Amana RFS8SW1 COMMERCIAL MICROWAVES
Amana RFS9B COMMERCIAL MICROWAVES
Amana RFS9B2 COMMERCIAL MICROWAVES
Amana RFS9LW COMMERCIAL MICROWAVES
Amana RFS9MP COMMERCIAL MICROWAVES
Amana RFS9MP2 COMMERCIAL MICROWAVES
Amana RFS9MPH COMMERCIAL MICROWAVES
Amana RFS9MPK COMMERCIAL MICROWAVES
Amana RFS9MPLW COMMERCIAL MICROWAVES
Amana RFS9SW2 COMMERCIAL MICROWAVES
Maytag RFU1500AAW FREEZER- VERTICAL
Maytag RFU2000AAW FREEZER- VERTICAL
Maytag RFU200FAAW FREEZER- VERTICAL
Admiral RFUA120AAW FREEZER- VERTICAL
Admiral RFUA150AAW FREEZER- VERTICAL
Admiral RFUA200AAW FREEZER- VERTICAL
Admiral RFUA20FAAW FREEZER- VERTICAL
  #2 (permalink)
Old 07-07-2017, 10:34 PM
Senior Member
PNWDrew is on a distinguished road
Default
Sounds like you are right, the noise is probably the water valve opening and closing as the board resets. It'll be the main board probably, not the front display. There's 2 boards on the back, the main and the inverter, my guess is the main is repeatedly resetting. There's some question left as to why it is resetting, but it may just be internally failing.
Samsung DA41-00620B Pba MAIN;09 Aw Tim-Pj - AppliancePartsPros.com
  #3 (permalink)
Old 07-12-2017, 10:29 AM
Junior Member
Default
I finally got the chance to pull off the back panel and despite everything looking fine on the board I'm still leaning towards that being my problem. I plugged it back in to see if it would do anything and it remains silent and the only thing it does is the lights above the dispenser are flashing. Zero power evidenced anywhere else and no noise, no fan, no display panel, nothing. I did find a fuse and look at it and it seems completely normal. My only worry is if I buy a board and that doesn't fix it. My local parts store won't let me return it if it doesn't fix the problem.
  #4 (permalink)
Old 07-12-2017, 11:01 AM
Senior Member
Default
If you want to be a little more adventurous you can try disconnecting plugs 1 by 1 on the mainboard and see if anything changes. I'd start with the high voltage circuits which will be the thicker wires. Unplug the machine between tries.
The downside of doing that is that you will probably generate error codes due to the unplugged parts if the board is able to power up. The up the upside is that it may tell you that there is a shorted-out component elsewhere causing the problem. I will take a look at a wiring diagram and see if I can help you identify what goes where because I do not think that Samsung labels their boards with anything other than a plug number.
You would want to check with this site first but I believe their parts are returnable. In many cases local shops will not accept returns on electrical parts as they cannot test them and many people will attempt that scam when it comes to a $300 board. Often people immediately replace the main control board as soon as anything goes wrong and are not correct.
  #5 (permalink)
Old 07-12-2017, 11:21 AM
Senior Member
Default
Sorry about the split, it was illegible if not enlarged.
Try pulling the AC plugs labeled CN72 to 74 on left bottom one at a time (while unplugged) and see what happens. The board has what they called an inrush protection circuit that is designed to avoid damage to the board when it is first pluggeg in. It may be that a shorted component triggers that circuit.
  #6 (permalink)
Old 07-12-2017, 02:05 PM
Junior Member
Default
I just had a dummy moment. While checking the boards, I finally realized it had a LED bulb that flashed twice. According to the chart on the back of my refrigerator it is a defective inverter PCB. Does this mean I need to replace the whole upper board?
  #7 (permalink)
Old 07-12-2017, 02:12 PM
Senior Member
Default
That is probably your issue then. You can try disconnecting that board from the main board and seeing if other functions return. If so that's it. If I was looking at it I would connect everything properly and it might be worth also disconnecting the plug that goes down to the compressor from the inverter board to verify that the compressor isn't the actual problem.
  #8 (permalink)
Old 07-12-2017, 02:14 PM
Junior Member
Default
I'll give that a try! Thank you so very much for the help. I'll let you know what happens.
  #9 (permalink)
Old 07-13-2017, 05:53 AM
Junior Member
Default
I unplugged everything from the board and not a single thing started working, just the lights above the dispenser flashing again. After unplugging it from the outlet and connecting everything again I plugged it into the outlet again and sat there for a while to see if the compressor at least got hot. It didn't but after a few minutes it did starting making the noise again. Whatever it is it is strong enough to shake the entire fridge and it seems to come from the top of the fridge rather than the bottom. It's getting extremely frustrating.
  #10 (permalink)
Old 07-13-2017, 06:59 AM
Senior Member
Default
Darn. I thought we had it with that inverter code.
I can't think of anything up high on that unit that would make that much noise unless it is just the water valve opening and pressurizing the line going up to the water feed for the ice maker.
I don't usually like to tell people to consider replacing it because sometimes the fix is cheap enough that it would make more sense but I can understand the annoyance of this continual problem. Factor in the age of the machine and you may want to consider either simply replacing it or calling a repair person.
I will give it some thought today in my free time. Perhaps lightning will strike and I'll have a good idea.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
thumping noise stacyangle Dryer Repair 4 10-19-2011 04:09 PM
thumping noise antelope Dryer Repair 1 03-30-2011 04:19 PM
Thumping or Grinding Noise johnroof1965 Dryer Repair 8 01-17-2011 06:23 AM
Thumping noise Rover1 Dryer Repair 3 09-25-2009 07:14 AM
Thumping noise sixpack Dryer Repair 4 02-24-2008 10:53 PM
