So I have a side by side where the fridge is too cold and the freezer is too warm. So my first thought was the damper ( GE WR09X10050 Damper and Gasket Assembly - AppliancePartsPros.com) when I took the cover off I saw the damper was closed. And afterhaving the fridge opened for a bit, I then closed it and checked back and the damper was open. So it does not seem to be a physical issue... could it be another issue that is causing the damper to open too much?
