Discuss
Soda Dispensing Mini-fridge Won't Get Cold
 in
Refrigerator & Freezer Repair
Hello All, First I'd like to say "Hi." This is my first post. I joined hoping to get some help
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Soda Dispensing Mini-fridge Won't Get Cold
  #1 (permalink)
Old 07-06-2017, 07:41 PM
Junior Member
dark_nemesis is on a distinguished road
Question Soda Dispensing Mini-fridge Won't Get Cold
Brand: -brand-   Age: 1 - 5 years
Hello All,
First I'd like to say "Hi." This is my first post. I joined hoping to get some help with the my mini fridge. I have a soda dispensing mini-fridge, the kind that when you press a button on the front a can is pops out the front. I'm not sure if it really matters the type of fridge, however I figure the more details now, the less I will have to add later. I just purchased it, and the gentleman that I bought it off of said that it wouldn't get cold when he got it, so he ended up sticking one of those 3 N' 1 relays in it. He said that he wasn't sure if he wired it correctly (as it turns out he did). When I got the fridge home, I got my multimeter out to test the compressor. (I learned how to test it on youtube) This is where I run into problems though. Does the compressor have to be hook into the fridge, and the fridge plugged in in order for me to be able to test it? I ask because the compressor is hooked into the fridge, but when the fridge into plugged into the wall, I do not get any readings what so ever on the multimeter. When it is plugged in, when testing the com and run pins, I get a reading. When testing the com and the start pins, I get a reading (both of the aforementioned readings are roughly about the same). Now when I try to get readings from the run and the start pins, I do not get anything. Any ideas? Do I need a new compressor? or is it the relay? Oh and not sure if it matters, but I have the relay connected to the compressor when I am doing my readings with my multimeter.
  #2 (permalink)
Old 07-07-2017, 07:34 PM
Junior Member
Default Bump
Any Takers?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need help with GE mini fridge Feanux Refrigerator & Freezer Repair 7 10-23-2014 11:57 PM
Frigidaire Mini Fridge doesn't get cold after Rain and circuit breaker! Duce Refrigerator & Freezer Repair 16 02-27-2012 08:03 PM
mini-fridge fan help Bmeyer2 Refrigerator & Freezer Repair 1 08-24-2011 03:02 PM
wet mini fridge pdcarter Refrigerator & Freezer Repair 1 07-25-2011 06:47 AM
