Discuss
Amana sidebyside...door controls not working
 in
Refrigerator & Freezer Repair
Was working on Mom's fridge because freezer wasn't freezing. Took freezer apart and found loose wire on evap motor and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana sidebyside...door controls not working
  #1 (permalink)
Old 05-15-2017, 12:02 PM
Junior Member
slevy951 is on a distinguished road
Default Amana sidebyside...door controls not working
Model Number: ARS9167AB   Brand: Amana   Age: 5 - 10 years
Was working on Mom's fridge because freezer wasn't freezing. Took freezer apart and found loose wire on evap motor and coils froze over. Hooked wire back up and defrosted coils and it's cooling as it should now. BUT, now nothing on the door works. I mean nothing. No lights. It won't dispense ice/water. No reaction from any buttons. It is making ice, bucket is full. Is there a reset button combo? Did I kill the door control board?
TIA,
Scott
Related Models
Amana ARS9167AB REF - SXS/I&W
Amana ARS9167AC REF - SXS/I&W
Amana ARS9167AS REF - SXS/I&W
Amana ARS9167AW REF - SXS/I&W
Amana ARS9168AB REF - SXS/I&W
Amana ARS9168AC REF - SXS/I&W
Amana ARS9168AS REF - SXS/I&W
Amana ARS9168AW REF - SXS/I&W
Amana ARS9169AS REF - SXS/I&W
Amana ARS9265BB REF - SXS/I&W
Amana ARS9265BC REF - SXS/I&W
Amana ARS9265BW REF - SXS/I&W
Amana ARS9266BS REF - SXS/I&W
Amana ARS9268BB REF - SXS/I&W
Amana ARS9268BC REF - SXS/I&W
Amana ARS9268BW REF - SXS/I&W
Amana ARS9269BS REF - SXS/I&W
Amana ARSE664BB REF - SXS/I&W
Amana ARSE664BC REF - SXS/I&W
Amana ARSE664BS REF - SXS/I&W
Amana ARSE664BW REF - SXS/I&W
Amana ARSE665BB REF - SXS/I&W
Amana ARSE665BC REF - SXS/I&W
Amana ARSE665BS REF - SXS/I&W
Amana ARSE665BW REF - SXS/I&W
Amana ARSE667BB REF - SXS/I&W
Amana ARSE667BC REF - SXS/I&W
Amana ARSE667BS REF - SXS/I&W
Amana ARSE667BW REF - SXS/I&W
Amana ARSE66MBB REF - SXS/I&W
Amana ARSE66MBC REF - SXS/I&W
Amana ARSE66MBW REF - SXS/I&W
Amana ARSE66ZBB REF - SXS/I&W
Amana ARSE66ZBC REF - SXS/I&W
Amana ARSE66ZBS REF - SXS/I&W
Amana ARSE66ZBW REF - SXS/I&W
Amana ARSE67RBB REF - SXS/I&W
Amana ARSE67RBC REF - SXS/I&W
Amana ARSE67RBS REF - SXS/I&W
Amana ARSE67RBW REF - SXS/I&W
Amana ART1805BC REF - TOP MOUNT
Amana ART1805BW REF - TOP MOUNT
Amana ART2105BB REF - TOP MOUNT
Amana ART2105BC REF - TOP MOUNT
Amana ART2105BW REF - TOP MOUNT
Amana ART2107BB REF - TOP MOUNT
Amana ART2107BC REF - TOP MOUNT
Amana ART2107BS REF - TOP MOUNT
Amana ART2107BW REF - TOP MOUNT
Amana ART2127AB REF - TOP MOUNT
Amana ART2127AC REF - TOP MOUNT
Amana ART2127AS REF - TOP MOUNT
Amana ART2127AW REF - TOP MOUNT
Amana ART2129ABR REF - TOP MOUNT
Amana ART2129ACR REF - TOP MOUNT
Amana ART2129ASR REF - TOP MOUNT
Amana ART2129AWR REF - TOP MOUNT
Amana ART2527AB REF - TOP MOUNT
Amana ART2527AC REF - TOP MOUNT
Amana ART2527AW REF - TOP MOUNT
Amana ART5400L RANGE- STD MWAVE ELE
Amana ART5400W RANGE- STD MWAVE ELE
Amana ART6000L RANGE- S/C S/I DDRAFT GAS
Amana ART6000W RANGE- S/C S/I DDRAFT GAS
Amana ART6001L RANGE- S/C S/I DDRAFT GAS
Amana ART6001W RANGE- S/C S/I DDRAFT GAS
Amana ART6002L RANGE- S/C S/I DDRAFT GAS
Amana ART6002L Range - S/c S/i Ddraft Gas
Amana ART6002W RANGE- S/C S/I DDRAFT GAS
Amana ART6002W Range - S/c S/i Ddraft Gas
Amana ART6021C RANGE- S/C S/I DDRAFT GAS
Amana ART6021L RANGE- S/C S/I DDRAFT GAS
Amana ART6021W RANGE- S/C S/I DDRAFT GAS
Amana ART6100E RANGE- S/C S/I DDRAFT GAS
Amana ART6100LL RANGE- S/C S/I DDRAFT GAS
Amana ART6100WW RANGE- S/C S/I DDRAFT GAS
Amana ART6110E RANGE- S/C S/I DDRAFT ELE
  #2 (permalink)
Old 05-15-2017, 10:21 PM
Senior Member
PNWDrew is on a distinguished road
Default
Verify proper operation of the door light switch. If the unit thinks the door is open it will disable dispenser. Usually that also stops evap fan motor but that unit might go into emergency cool and run the fan 100% if temps get too high. If you can get the switch out of it's hole you can jump across the terminals to simulate the closed switch
Did you remove the door to do the work, maybe left it unplugged? I'm not sure if the wiring comes through the top or bottom hinge on that one, but it's worth checking, if you removed the door. I think it is the bottom hinge behind toekick.
  #3 (permalink)
Old 05-16-2017, 05:07 AM
Junior Member
Default
Yep, both door switches work. I opened freezer door, manually actuated the switch, light goes on/off with switch. Did the same on refridge side.
  #4 (permalink)
Old 05-16-2017, 05:12 AM
Junior Member
Default
Oh, no, I didn't take the door off.
  #5 (permalink)
Old 05-24-2017, 08:44 PM
Senior Member
Default
Sorry to leave you hanging; work has been rough recently.
If the light switches work things get more complex.
Too loose the whole dispenser function would lead me to start looking for connection issues. Find where the harness for the door joins the cabinet, through either top or bottom hinge. If nothing obvious then we'd need to start electrical checks.
I don't have a schematic for this unit but I'd like to know if the dispenser board is getting power. In general if a board is powered and not functioning it's dead but that's not always the case so it's worth checking.
If I can get a free moment tomorrow I'll try to remember to take a look at a wiring diagram.
  #6 (permalink)
Old 05-25-2017, 05:42 AM
Junior Member
Default
Thanks for getting back. I looked on the bottom and the condenser coil was covered in dust. I cleaned it but the freezer failed to cool again. With this issue combined with the door control, we just got a new one.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
The controls on the door not working, not compressor on d_swif Refrigerator & Freezer Repair 3 08-09-2015 01:51 PM
fridgedair sidebyside icemaker runs when you shut freezer door markpetrak Refrigerator & Freezer Repair 1 01-13-2014 04:30 PM
Replace door stop part for sidebyside frig. Jane Revell Refrigerator & Freezer Repair 1 01-20-2011 11:58 AM
Amana Oven controls dead taccount Oven Repair (including Ranges and Cooktops) 0 08-22-2010 07:50 AM
JennAir Refrig Door Controls - Ice Dispenser Door Solenoid Valve kwlex Refrigerator & Freezer Repair 0 12-07-2009 01:09 PM
