Register | FAQ's | New Posts | Today's Posts | Extras |
» Lines to Evaporator Cold ... but not Evaporator |
![]() Model Number: FRS6RESBC Brand: Electrolux Age: 5 - 10 years
![]() Last night all of the sudden both the fridge and freezer stopped getting cold. The fans are running but nothings cold. This morning I took the panel off inside the freezer to see if the coils on the evaporator were frozen over but there was not a drop of water on them at all. I did notice that the lines leading into the evaporator fins were freezing and covered with ice, just not the evaporator it's self. Thanks for your help! Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Looks like little to no refrigerant is making it to the evaporator. This can be caused by 3 issues: a leak that has finally depleted enough that it isn't filling the evap at all, a restriction in the capillary tube that is only allowing a little of the refrigerant to pass, or a very weak compressor.
None of them are good news, but without a tap and pressure checks it is hard to tell which. On that one I'd guess it's a leak or restriction. There is a lot of steel tubing that runs through the cabinet and Frigidaire/Electrolux has had enough issues with leaks in that hot gas tube (yoder loop) that they've come up with an electric heater the repair person is supposed to suck through the whole loop and then bypass that part of the sealed system. Since it happened suddenly though a restriction might be more likely. I'd have to tap it at the compressor and see. There are a few things you can check to help narrow it down. 1) Is there any oil on the evaporator? Leaks spit out oil too so a leak in the evap or at the joint between copper and aluminum will get oily. 2) Does the compressor sound normal, and is it running continuously? 3) If you have an ammeter check the amp draw of the compressor when it starts. Also is it very hot? No matter what you are probably looking at sealed system work, which is usually $$$. Look at your owner's manual to see if it has a 10 yr sealed system warranty. That's probably the deciding factor. If you are paying parts and labor you will exceed $500 and maybe get over $700 depending on what is needed. The hot gas bypass kit technically makes nothing irreparable, and Frig/Elec will insist on it. However I've never heard of my one of my coworkers successfully install it. It's a nightmare solution that I hope to never try, as the hot gas loop runs around the edge of each door opening so is ~30ft long. It might be worth the trip charge to have a tech diagnose, but expect bad news. |
![]() Good Morning and thanks for your reply.
The compressor was making noise the other day but it stopped and everything remained cold .... I guess that was it's dying last gasps. Sounds like a new fridge is the best way to go here. I appreciate the help. Have a great day and thanks again! |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Kenmore Elite not cooling/freezing evaporator not getting cold, burn marks | nixsun | Refrigerator & Freezer Repair | 1 | 07-06-2015 05:18 PM |
Freezer cold on bottom. Evaporator. Fan works but not in freezer. | PURCHIARONI@ATT.NET | Refrigerator & Freezer Repair | 0 | 02-26-2015 12:05 PM |
Whirlpool Fridge Warm - Freezer cold - Evaporator Fan not running | khewitt24 | Refrigerator & Freezer Repair | 3 | 10-02-2014 07:23 AM |
GE Profile Fridge warm, freezer cold, replaced main board/evaporator fan | kwiasf99 | Refrigerator & Freezer Repair | 0 | 05-29-2013 12:45 PM |
Freezer cold, evaporator fan not working, frost build up in freezer | heretolearn2 | Refrigerator & Freezer Repair | 3 | 05-28-2008 02:45 PM |
