Discuss
Thermostat problem with mini fridge
 in
Refrigerator & Freezer Repair
If I remove the temperature control and connect the black and white wires, the refrigerator runs and cools, but I
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Thermostat problem with mini fridge
  #1 (permalink)
Old 11-03-2009, 10:59 AM
Edogyip Edogyip is offline
Junior Member
Edogyip is on a distinguished road
Default Thermostat problem with mini fridge
Model Number: GMR02BANCBB   Brand: GE   Age: 5 - 10 years
If I remove the temperature control and connect the black and white wires, the refrigerator runs and cools, but I cannot get the new thermostat to kick on the refrigerator. I have a C, L, and two ground terminals, so where do I install the black, white, and green wires?
Related Models
General Electric GMR02BANCBB Refrigerator
General Electric GMR02BANCWW Refrigerator
General Electric GMR02BANDBB Refrigerator
General Electric GMR02BANDWW Refrigerator
General Electric GMR02CANBWW Refrigerator
General Electric GMR03DAMAWW Refrigerator
General Electric GMR04AAMABB Refrigerator
General Electric GMR04AAMAWW Refrigerator
General Electric GMR04BANABB Refrigerator
General Electric GMR04BANAWW Refrigerator
General Electric GMR04BANBBB Refrigerator
General Electric GMR04BANBWW Refrigerator
General Electric GMR04BANCBB Refrigerator
General Electric GMR04BANCWW Refrigerator
General Electric GMR04BANDBB Refrigerator
General Electric GMR04BANDWW Refrigerator
General Electric GMR04BARABS Refrigerator
General Electric GMR04BARBBS Refrigerator
General Electric GMR04BARCBS Refrigerator
General Electric GMR04HANBBS Refrigerator
General Electric GMR04HANCBS Refrigerator
General Electric GMR04HANDBS Refrigerator
General Electric GMR04HASACS Refrigerator
General Electric GMR04HASBCS Refrigerator
General Electric GMR06AAMARWW Refrigerator
General Electric GMR06AAMBRWW Refrigerator
General Electric GMR06AAPBB Refrigerator
General Electric GMR06AAPWW Refrigerator
General Electric GMS10AAMALWW Refrigerator
General Electric GMS10AAMARWW Refrigerator
Frigidaire GMT1670AS0 Frigidaire/washer
Frigidaire GMWS1339CS0 Frigidaire/washer
General Electric GN1S15CBL Uc filtration-carbon
Norge GN31113WAM Range - F/s Std Gas
Norge GN31113WAV Range - F/s Std Gas
Norge GN3177WUA Range - F/s Std Gas
Norge GN3177WUW Range - F/s Std Gas
Norge GN3277XUA Range - F/s Std Gas
Norge GN3277XUW Range - F/s Std Gas
Norge GN3531WUA Range - F/s Std Ele
Norge GN3531WUW Range - F/s Std Ele
General Electric GNCF02H Home cond
General Electric GNCF04H Home cond
Thermador GNG12M
Thermador GNG12MW
General Electric GNPR40L00 Softners
General Electric GNPR48L00 Softners
General Electric GNRP40L00 Softners
General Electric GNRP48L00 Softners
International GNS20M82 Ref - Sxs
General Electric GNSF18Z01 Uc filtration-carbon
General Electric GNSF23Z01 Uc filtration-carbon
General Electric GNSF35Z01 Uc filtration-carbon
General Electric GNSF35Z02 Water softeners
General Electric GNSF35Z03 Water softeners
General Electric GNSF35Z04 Softners
General Electric GNSF39A01 Uc filtration-carbon
General Electric GNSF48A01 Uc filtration-carbon
General Electric GNSH45E01 Water softeners
General Electric GNSH45E02 Softners
General Electric GNSH45E03 Softners
General Electric GNSL05CBL Uc filtration-carbon
General Electric GNSL60FBL Wh filt sys
General Electric GNSM48F02 Softners
General Electric GNSM48F03 Softners
General Electric GNSR3150H0WW Washer
General Electric GNSV25CBL Uc filtration-carbon
General Electric GNSV30CCC Uc filtration-carbon
General Electric GNSV30CWW Uc filtration-carbon
General Electric GNSV70FBL
General Electric GNSV70FBL01 Wh filt sys
General Electric GNSV75FWW Wh filt sys
General Electric GNSV75WW01 Wh filt sys
International GNT15M42 Ref - Top Mount
International GNT15M42A Ref - Top Mount
International GNT15M42L Ref - Top Mount
International GNT15M42LA Ref - Top Mount
International GNT15M4XA Ref - Top Mount
International GNT15M4XH Ref - Top Mount
International GNT15M82 Ref - Top Mount
International GNT17M42 Ref - Top Mount
International GNT17M42A Ref - Top Mount
International GNT17M4XA Ref - Top Mount
International GNT17M4XH Ref - Top Mount
International GNT17M92 Ref - Top Mount
International GNT19M4XA Ref - Top Mount
International GNT19M4XH Ref - Top Mount
General Electric GNUL30B01 Uc filtration-carbon
General Electric GNUL30Z01 Uc filtration-carbon
General Electric GNUT03A Uc filtration-carbon
General Electric GNUT03B01 Uc filtration-carbon
General Electric GNUT05B01 Uc filtration-carbon
General Electric GNUT05Z01 Uc filtration-carbon
General Electric GNUV10Z01 Uc filtration-carbon
General Electric GNWH08C Uc filtration-carbon
General Electric GNWH38F Softners
Jenn-Air GO106 Electric Grill Outdoor
  #2 (permalink)
Old 11-04-2009, 06:03 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Getting tech info on GE is difficult to say the least. They like to keep it a secret.
I would think that the C would be the wire that goes to the compressor, the L would go to Line (power in).
Am not sure where the grounds should go unless the thermostat has a connection to it's metal body.
Hopefully someone will jump in who has worked on one of these and remembers the hook up.
__________________
  #3 (permalink)
Old 11-04-2009, 07:28 AM
Junior Member
Default
I hooked it up in every possible fashion and nothing. As of right now I have both hooked to the 2 grounds, so it is just acting as a jumper. I switch it on and off by the power strip, so now I'm the thermostat.
  #4 (permalink)
Old 11-04-2009, 07:38 AM
Senior Expert
APP Volunteer
Default
Could be that you have a bad thermostat.
Sometimes parts are defective right out of the box.
Remove it from the unit, set it at mid point in its rotation and check the connectors with a meter. Should be 0 ohms (closed).
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Mini fridge freezer frosting over Insaneman1731 Refrigerator & Freezer Repair 0 08-23-2009 02:27 PM
Montgomery wards mini fridge sambonnie Refrigerator & Freezer Repair 2 08-12-2009 08:10 AM
Need help with GE mini fridge Feanux Refrigerator & Freezer Repair 3 07-31-2009 07:14 AM
Mini Fridge not cooling. unchained5150 Refrigerator & Freezer Repair 0 06-03-2008 01:15 PM
Fridge Thermostat Testing Tony.C Refrigerator & Freezer Repair 2 08-07-2007 01:31 PM
