Discuss
Compressor Problem
 in
Refrigerator & Freezer Repair
The compressor runs the same with or without the Run Capacitor, is this normal? The compressor in this unit is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Compressor Problem
  #1 (permalink)
Old 05-03-2017, 08:03 AM
Junior Member
teton is on a distinguished road
Question Compressor Problem
Model Number: W8RXEGMWB01   Brand: Whirlpool   Age: 5 - 10 years
The compressor runs the same with or without the Run Capacitor, is this normal? The compressor in this unit is a EMBRACO EGX 70HLC the data sheet with this unit states "Refrigerant Charge Must Be Applied To HIGH SIDE ONLY". Everything I have read says you add coolant to the suction side, what is correct?
Related Models
Whirlpool W8RXEGMWB01 REFRIGERATOR
Whirlpool W8RXEGMWD00 REFRIGERATOR
Whirlpool W8RXEGMWD01 REFRIGERATOR
Whirlpool W8RXEGMWL00 REFRIGERATOR
Whirlpool W8RXEGMWL01 REFRIGERATOR
Whirlpool W8RXEGMWQ00 REFRIGERATOR
Whirlpool W8RXEGMWQ01 REFRIGERATOR
Whirlpool W8RXEGMWS00 REFRIGERATOR
Whirlpool W8RXEGMWS01 REFRIGERATOR
Whirlpool W8RXNGFWB00 REFRIGERATOR
Whirlpool W8RXNGFWB01 REFRIGERATOR
Whirlpool W8RXNGFWD00 REFRIGERATOR
Whirlpool W8RXNGFWL00 REFRIGERATOR
Whirlpool W8RXNGFWL01 REFRIGERATOR
Whirlpool W8RXNGFWQ00 REFRIGERATOR
Whirlpool W8RXNGFWQ01 REFRIGERATOR
Whirlpool W8RXNGFWS00 REFRIGERATOR
Whirlpool W8RXNGFWS01 REFRIGERATOR
Whirlpool W8RXNGMWB00 REFRIGERATOR
Whirlpool W8RXNGMWB01 REFRIGERATOR
Whirlpool W8RXNGMWD00 REFRIGERATOR
Whirlpool W8RXNGMWD01 REFRIGERATOR
Whirlpool W8RXNGMWD02 REFRIGERATOR
Whirlpool W8RXNGMWL00 REFRIGERATOR
Whirlpool W8RXNGMWL01 REFRIGERATOR
Whirlpool W8RXNGMWQ00 REFRIGERATOR
Whirlpool W8RXNGMWQ01 REFRIGERATOR
Whirlpool W8RXNGMWQ02 REFRIGERATOR
Whirlpool W8RXNGMWS00 REFRIGERATOR
Whirlpool W8RXNGMWS01 REFRIGERATOR
Whirlpool W8TXEGFYB00 REFRIGERATOR
Whirlpool W8TXEGFYQ00 REFRIGERATOR
Whirlpool W8TXEWFVB00 REFRIGERATOR
Whirlpool W8TXEWFVB01 REFRIGERATOR
Whirlpool W8TXEWFVQ00 REFRIGERATOR
Whirlpool W8TXEWFVQ01 REFRIGERATOR
Whirlpool W8TXEWFYB00 REFRIGERATOR
Whirlpool W8TXEWFYB02 REFRIGERATOR
Whirlpool W8TXEWFYQ00 REFRIGERATOR
Whirlpool W8TXEWFYQ02 REFRIGERATOR
Whirlpool W8TXNGFWB00 REFRIGERATOR
Whirlpool W8TXNGFWB01 REFRIGERATOR
Whirlpool W8TXNGFWQ00 REFRIGERATOR
Whirlpool W8TXNGFWQ01 REFRIGERATOR
Whirlpool W8TXNGFWT00 REFRIGERATOR
Whirlpool W8TXNGFWT01 REFRIGERATOR
Whirlpool W8TXNGMWB00 REFRIGERATOR
Whirlpool W8TXNGMWB01 REFRIGERATOR
Whirlpool W8TXNGMWQ00 REFRIGERATOR
Whirlpool W8TXNGMWQ01 REFRIGERATOR
Whirlpool W8TXNGMWQ02 REFRIGERATOR
Whirlpool W8TXNWFWB00 REFRIGERATOR
Whirlpool W8TXNWFWB01 REFRIGERATOR
Whirlpool W8TXNWFWQ00 REFRIGERATOR
Whirlpool W8TXNWFWQ01 REFRIGERATOR
Whirlpool W8TXNWFWT00 REFRIGERATOR
Whirlpool W8TXNWFWT01 REFRIGERATOR
Whirlpool W8TXNWMWB00 REFRIGERATOR
Whirlpool W8TXNWMWB01 REFRIGERATOR
Whirlpool W8TXNWMWQ00 REFRIGERATOR
Whirlpool W8TXNWMWQ01 REFRIGERATOR
Whirlpool W8TYNWFWB00 REFRIGERATOR
Whirlpool W8TYNWFWQ00 REFRIGERATOR
Whirlpool W9RXEMFWB00 REFRIGERATOR
Whirlpool W9RXEMFWB01 REFRIGERATOR
Whirlpool W9RXEMFWQ00 REFRIGERATOR
Whirlpool W9RXEMFWQ01 REFRIGERATOR
Whirlpool W9RXEMFWS00 REFRIGERATOR
Whirlpool W9RXEMFWS01 REFRIGERATOR
Whirlpool W9RXEMMWB00 REFRIGERATOR
Whirlpool W9RXEMMWB01 REFRIGERATOR
Whirlpool W9RXEMMWQ00 REFRIGERATOR
Whirlpool W9RXEMMWQ01 REFRIGERATOR
Whirlpool W9RXEMMWS00 REFRIGERATOR
Whirlpool W9RXEMMWS01 REFRIGERATOR
Whirlpool W9RXNMFWB00 REFRIGERATOR
Whirlpool W9RXNMFWB01 REFRIGERATOR
Whirlpool W9RXNMFWB02 REFRIGERATOR
Whirlpool W9RXNMFWQ00 REFRIGERATOR
Whirlpool W9RXNMFWQ01 REFRIGERATOR
Whirlpool W9RXNMFWQ02 REFRIGERATOR
Whirlpool W9RXNMFWS00 REFRIGERATOR
Whirlpool W9RXNMFWS01 REFRIGERATOR
Whirlpool W9RXNMFWS02 REFRIGERATOR
Whirlpool W9RXXMFWB00 REFRIGERATOR
Whirlpool W9RXXMFWB01 REFRIGERATOR
Whirlpool W9RXXMFWL00 REFRIGERATOR
Whirlpool W9RXXMFWQ00 REFRIGERATOR
Whirlpool W9RXXMFWQ01 REFRIGERATOR
Whirlpool W9RXXMFWS00 REFRIGERATOR
Whirlpool W9TXNMFWB00 REFRIGERATOR
Whirlpool W9TXNMFWB01 REFRIGERATOR
Whirlpool W9TXNMFWQ00 REFRIGERATOR
Whirlpool W9TXNMFWQ01 REFRIGERATOR
Whirlpool W9TXNMFWS00 REFRIGERATOR
Whirlpool W9TXNMFWS01 REFRIGERATOR
Whirlpool W9TXNMFWT00 REFRIGERATOR
Frigidaire WA24F4DTFB Gib(v4) / Top Load Washer
Frigidaire WA24F4WTFA Gib(v2) / Automatic Washer
Frigidaire WA24F4WTFB Gib(v3) / Top Load Washer
Frigidaire WA24P2DTFB Gib(v2) / Top Load Washer
Frigidaire WA24P2DVFA Gib(v2) / Top Load Washer
Frigidaire WA24P2WSFA Gib(v1)
Frigidaire WA24P2WSFB Gib(v2)
Frigidaire WA24P2WTFA Gib(v1) / Automatic Washer
Frigidaire WA24P2WTFB Gib(v1) / Top Load Washer
Frigidaire WA24P2WVFA Gib(v1) / Top Load Washer
Frigidaire WA24P2WVMB Gib(v1) / 24 " Washer
Frigidaire WA24P2WYMA Gib(v1) / 24 " Washer
Frigidaire WA24P2WYMB Gib(v1) / 24 " Washer
Frigidaire WA24P2WYMC Gib(v1) / 24 " Washer
Frigidaire WA27F2WAFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F2WAFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F2WXFA Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F2WXFB Gib(v2) / 27 " Top Load Washer
Frigidaire WA27F4WAFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27F4WAFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27F4WXFA Gib(v1) / 27 " Top Load Washer
Frigidaire WA27F4WXFB Gib(v1) / 27 " Top Load Washer
Frigidaire WA27M4WAFA Gib(v2) / 27 " Top Load Washer
  #2 (permalink)
Old 05-03-2017, 09:24 PM
Senior Member
PNWDrew is on a distinguished road
Default
The run cap helps get it started, if there is low head pressure it is not always needed to get comp moving.
As for adding refrigerant; that depends on who you ask and how they do it. Sweep charge or deep evac. You can add vapor to the low side with running compressor (process tube), or if you're pressing your luck very slowly add liquid to same port. Normally the comp chugs a little as it eats the liquid and it's ok, but it's a large risk I don't take. To add liquid to high side you'll need a tank at higher pressure or a system in deep vacuum with comp off.
I prefer vapor into low side process tube with running compressor and a heated tank. It's slower but easier (I think) on the system. Some guys add liquid to process tube slowly, I figure if I damage a valve in the comp just to save 5 minutes I'm going to be really pissed off.
  #3 (permalink)
Old 05-04-2017, 05:54 AM
Junior Member
Default
Thanks for the info.
  #4 (permalink)
Old 05-08-2017, 08:04 AM
Junior Member
MRDOWNEASTER is on a distinguished road
Default
How Do I Know If I Have Damage A Valve
  #5 (permalink)
Old 05-08-2017, 09:13 PM
Senior Member
Default
Noise and temps of output line/condenser is a good sign but to be more certain you'd need to tap the sealed system and get pressures. There are valves inside the compressor that allow it to build pressure (compress). It is not serviceable, it's hermetically sealed.
But I'm confused, why are you interested in adding refrigerant? It's a sealed system, if it needs refrigerant added it has a leak. Adding some might buy you some time but that's it.
This is not the kind of thing a homeowner can do unless there is already an access valve installed (on high or low side) and they have a supply of virgin refrigerant and a scale to weigh it in at a bare minimum. You should also have gauges, a vacuum pump, a recovery pump and tanks to do it right. If it has been worked on before there will be an access valve on the process tube (low side=short stub on compressor) and the filter-dryer(high side-with the thin capillary tube in one end). Sealed system diagnosis and repair is not a casual task, I work with guys who can't get it right after a decade of trying. I can still make mistakes after 20 years of doing it.
Is the system not cooling or otherwise exhibiting signs of a sealed system issue? I'm not sure what the point of your question was I guess.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Problem switching r12 compressor to r134 compressor barkerw Refrigerator & Freezer Repair 2 08-10-2015 10:26 AM
Compressor Problem Sawfish Refrigerator & Freezer Repair 4 05-29-2013 02:33 PM
compressor/fan problem!? nick c Refrigerator & Freezer Repair 2 04-07-2011 08:45 AM
Compressor Problem? fishguy Refrigerator & Freezer Repair 1 11-28-2009 04:26 AM
compressor problem? khoffman Refrigerator & Freezer Repair 1 07-07-2008 08:23 PM
