Discuss
Refrigerator temp touch pad moves to 5
 in
Refrigerator & Freezer Repair
After manually defrosting seemed to have fixed problem of warm refrigerator compartment and blocked drain tube due to freezer ice
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator temp touch pad moves to 5
  #1 (permalink)
Old 05-01-2017, 04:14 PM
Junior Member
rms7 is on a distinguished road
Default Refrigerator temp touch pad moves to 5
Model Number: LTC22350WH   Brand: -other-   Age: 1 - 5 years
After manually defrosting seemed to have fixed problem of warm refrigerator compartment and blocked drain tube due to freezer ice buildup. plugging in refrigerator and set cooling touch pad to 3. after a while the setting jumps to 5 (coldest) and cannot be adjusted. temp in refrigerator compartment is 32 to 34. if i unplug it for a minute, it will be automatically reset to 3 but returns to 5 after half a day. at this point the touch pad will not respond and stays at 5. any idea what part has failed? thanks.
Related Models
Amana LTC85AW WASHER- HORIZONTAL AXIS
Whirlpool LTE5243BN0 WASHER / DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BN1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BW0 WASHER / DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BW1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243BW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ3 LAUNDRY CENTER
Whirlpool LTE5243DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQ9 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DQA WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT2 LAUNDRY SYSTEM
Whirlpool LTE5243DT3 LAUNDRY CENTER
Whirlpool LTE5243DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DT7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5243DZ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE5500W1 ELECTRIC DRYER
Whirlpool LTE6234AN0 WASHER/DRYER
Whirlpool LTE6234AN1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AN2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AN3 COMBINATION UNITS
Whirlpool LTE6234AW0 WASHER/DRYER
Whirlpool LTE6234AW1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AW2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234AW3 COMBINATION UNITS
Whirlpool LTE6234DQ0
Whirlpool LTE6234DQ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT2 LAUNDRY CENTER
Whirlpool LTE6234DT3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DZ0
Whirlpool LTE6234DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6234DZ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE6243AN2 LAUNDRY CENTER
Whirlpool LTE6243AW2 LAUNDRY CENTER
Whirlpool LTE7245AN0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTE7245AW0 WASHER/DRYER LAUNDRY SYSTEM
Frigidaire LTF1670DS0 Frigidaire/washer
Admiral LTF1812ARB REF - TOP MOUNT
Admiral LTF1812ARW REF - TOP MOUNT
Admiral LTF1812ARZ REF - TOP MOUNT
Admiral LTF2112ARB REF - TOP MOUNT
Admiral LTF2112ARW REF - TOP MOUNT
Admiral LTF2112ARZ REF - TOP MOUNT
Frigidaire LTF2140ES0 Frigidaire/washer
Frigidaire LTF2140ES1 Frigidaire/washer
Frigidaire LTF2140ES2 Frigidaire/washer
Frigidaire LTF2140ES3 Frigidaire/washer
Frigidaire LTF2140FS0 Frigidaire/washer
Frigidaire LTF2140FS1 WASHER
Frigidaire LTF2140FS2 WASHER
Frigidaire LTF2940EE0 Frigidaire/washer
Frigidaire LTF2940ES0 Frigidaire/washer
Frigidaire LTF2940ES1 Frigidaire/washer
Frigidaire LTF2940ES2 Frigidaire/washer
Frigidaire LTF2940ES3 Frigidaire/washer
Frigidaire LTF2940FE0 Frigidaire/washer
Frigidaire LTF2940FE1 WASHER
Frigidaire LTF2940FS1 WASHER
Frigidaire LTF530DS0 Frigidaire/washer
Frigidaire LTF530DS1 Frigidaire/washer
Frigidaire LTF530FS0 Frigidaire/washer
Frigidaire LTF530FS1 WASHER
Frigidaire LTF6000ES0 Frigidaire/washer
Frigidaire LTF6000ES1 Frigidaire/washer
Frigidaire LTF6000FS0 Frigidaire/washer
Frigidaire LTF6700FS0 WASHER
Frigidaire LTF7000EG0 Frigidaire/washer
Frigidaire LTF7000ES0 Frigidaire/washer
Frigidaire LTF7000ES1 Frigidaire/washer
Frigidaire LTF7000FG0 Frigidaire/washer
Frigidaire LTF8000FE0 WASHER
Whirlpool LTG5243BN0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BN1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BN2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243BW2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ3 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQ9 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DQA WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT3 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT6 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT7 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DT8 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ0 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ1 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG5243DZ2 WASHER-DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN0 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234AN1 COMBINATION UNITS
Whirlpool LTG6234AN2 WASHER/DRYER LAUNDRY SYSTEM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
both touch pad do not work, ice,water, light and inside temp setting pad RINTERN Refrigerator & Freezer Repair 0 09-05-2011 07:46 PM
Hot to the touch refrigerator drjbaldwin Refrigerator & Freezer Repair 1 06-17-2011 08:41 AM
Upper arm moves very slow, lower arm moves slow bhcon Dishwasher Repair 0 08-14-2010 01:12 AM
Oven Temp Touch Pad Keys stopped working 4Given Oven Repair (including Ranges and Cooktops) 0 03-30-2010 11:41 AM
Time and Temp touch pads mbrown5495 Oven Repair (including Ranges and Cooktops) 3 01-22-2009 04:47 PM
