Freezer, Fan is very loud But Not freezing. Only freezes on the very bottom of Freezer. Rest of Freezer is just cool I tested for continuity: Defrost Thermostat - good Defrost Heater- Good Fan Motor- good Temperature Controlknob- good What next?? I turned timer till came on. I could hear The fan motor , but fan wasn't turning I took back off & nudged the fan blades. They started going, but very loud (like the blade was hitting something) I can't visibly see that it's hitting anything. What should I try next?
