Discuss
Samsung Air Conditioner Capacitor Replacement
 in
Refrigerator & Freezer Repair
I believe there is an issue with the capacitor on my 10,000 btu samsung window air conditioner. I recently tried
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Samsung Air Conditioner Capacitor Replacement
  #1 (permalink)
Old 03-08-2017, 06:52 PM
Junior Member
kewarren6 is on a distinguished road
Default Samsung Air Conditioner Capacitor Replacement
Brand: Samsung   Age: 1 - 5 years
I believe there is an issue with the capacitor on my 10,000 btu samsung window air conditioner. I recently tried running it with a generator and accidentally had it plugged in before the generator was started and ever since then it hasn't worked properly. At first the AC would turn on but only the fan would run (no compressor) and the touch sensitive buttons on the display were not working. I tried unplugging and plugging back in and now there's no display at all, but I still get the small "beep" that happens when it's plugged in. Based on my research I believe it needs a new capacitor. I've researched online what i believe to be the correct replacement but not I'm not sure if it will work because some of the letters are different. The important numbers (voltage,etc) are a match but after doing some research I cannot find what the other numbers/letters mean. Attached is a picture of the current capacitor and also a picture of what I intend on using for the replacement. The current one reads SH CBB65 c p2 whereas the new one reads CBB65A-1. What is the meaning of the SH C p 2 and the a-1? I cannot find this anywhere online. Your help is greatly appreciated!
File Type: jpg Screen Shot 2017-03-08 at 6.39.14 PM.jpg (15.4 KB, 5 views)
  #2 (permalink)
Old 03-09-2017, 10:20 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
That capacitor would work, but I don't think its your problem.
I'd say that something blew on your control board. That's why have no display. Without a functioning control board the compressor will never start.
BTW The capacitor is either a "run" or a "start" capacitor and if your board was working, what you would hear is the relay clicking and a pretty loud hum as the compressor tried to start. Or started and then bogged down and stopped again if the capacitor was bad.
  #3 (permalink)
Old 03-09-2017, 01:39 PM
Junior Member
kewarren69 is on a distinguished road
Default
Thanks for the reply, I had to create a new profile because for some reason the other one wouldn't let me log in. If something blew on the control board, would it make sense that sporadically the display will turn on (displaying 75) but none of the buttons function to change settings. In addition to the display turning on, only the fan is running with no compressor. This is what happens only sometimes I attempted to plug in, while other times when I plugged it in only the beep would occur and no display at all. If it is something on the control board, how would I go about testing which part it is? Thanks!!
  #4 (permalink)
Old 03-09-2017, 02:08 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
Unless you are really good at repairing electronics or if the damage was easily visible, it would be pretty hard to repair it.
Probably the generator surged the control board and damaged it somehow. It could be a half fried chip that looks normal or it could be a damaged capacitor or diode that shows signs of being shorted or burnt.
When you plug it in its randomly activating things but there is no part sensing keyboard commands. For most people its time for s new AC or control board.
If you should happen to did in farther and can post high res pics of the back of the board, it would be interesting and maybe helpful to see them.
Oh, and a model number would help too.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
microwave capacitor replacement N8RM8R Microwave Repair 0 01-31-2011 12:30 PM
how to wire capacitor Air conditioner buckeye75 Heating, Ventilation, and Air Conditioning (HVAC) 1 07-03-2010 03:35 PM
Samsung Window Air Conditioner lumjack Refrigerator & Freezer Repair 0 05-12-2010 06:11 AM
replacement filter for air conditioner pafried Heating, Ventilation, and Air Conditioning (HVAC) 0 07-28-2009 12:57 PM
Removal and replacement of capacitor on Fridge Deborah3691 Refrigerator & Freezer Repair 0 08-07-2008 06:52 PM
