Discuss
Kenmore water dispenser and ice maker not working, detailed steps attempted
 in
Refrigerator & Freezer Repair
2 days ago, my fridge/freezer was making a persistent knocking noise. At this time, the ice maker had not been
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Kenmore water dispenser and ice maker not working, detailed steps attempted
  #1 (permalink)
Old 03-06-2017, 07:06 PM
Junior Member
fridgepuncher is on a distinguished road
Default Kenmore water dispenser and ice maker not working, detailed steps attempted
Model Number: 253.70313214   Brand: Kenmore   Age: 1 - 5 years
2 days ago, my fridge/freezer was making a persistent knocking noise. At this time, the ice maker had not been working for maybe a week (this happens intermittently). I unpluged the fridge for a few minutes, knocking noise persisted. At this time, my water dispenser was at least working. Then I tried to do the defrost cycle hoping to regain function of the icemaker and stop the knocking by holding I believe fridge and freezer temps down at the same time. This activated a cycle that stopped the knocking noise (also my water dispenser automatically activated so I must have triggered a service mode). However, since that time, the water dispenser does not work. Triggering the actuator turns on the light and it tried to dispense water (after shutting off the water at the valve and turning it back on, I can hear the water flow when triggering the door actuator).
Steps I have tried so far
  • Changing the OEM filter (it was an old filter) using a coral filter but it fits fine.
  • Removing the front left hinge and running warm water through the door water line to unfreeze it. The water flows out the water dispenser nozzle fine when I manually add wam water
  • checking/blowing into every line to see if there's an obstruction. All lines seem to have water EXCEPT the yellow/white line that goes to the door.
  • checking the valve water pressure and inlet hose for leaks (both good)
  • checking the inlet valve for leaks and the connectors for continuity (all test between 200-450 ohms resistance
When I checked the water filter was secure, the new filter was filling with water and made a pressurized sound when disconnecting it, meaning I'm getting water to the filter at least.
At this point I'm running out of potential fixes. I am wondering if I entered some diagnostic mode by accident that is preventing me dispensing water or getting ice now.
Questions for everyone
Does anyone have the tech sheet for this model?
Could anyone point me to which color water hoses may be causing the issue?
Does anyone have any tips I could try?
I would be really grateful!!! Thanks in advance!
Dan the frustrated but hopeful homeowner
Related Models
Frigidaire 2530A GAS RANGE
Frigidaire 2530B GAS RANGE
Frigidaire 2530C GAS RANGE
Frigidaire 2530D GAS RANGE
Frigidaire 2530E GAS RANGE
Kenmore 25310301000 CHEST FREEZER
Kenmore 25310301001 CHEST FREEZER
Kenmore 25310311000 CHEST FREEZER
Kenmore 25310311001 CHEST FREEZER
Kenmore 25310311002 FREEZER
Kenmore 25310911990 FREEZER
Kenmore 25310911991 CHEST FREEZER
Kenmore 25310911992 CHEST FREEZER
Kenmore 25311301100 FREEZER
Kenmore 25311301101 FREEZER
Kenmore 25311311100 CHEST FREEZER
Kenmore 25311312100 FREEZER
Kenmore 25311312101 FREEZER
Kenmore 25311312102 SEARS/FREEZER
Kenmore 25311321100 CHEST FREEZER
Kenmore 25311321101 FREEZER
Kenmore 25311351100 FREEZER
Kenmore 25311351101 CHEST FREEZER
Kenmore 25311351102 FREEZER
Kenmore 25311511100 CHEST FREEZER
Kenmore 25311511101 FREEZER
Kenmore 25311521100 FREEZER
Kenmore 25311521102 CHEST FREEZER
Kenmore 25311521103 FREEZER
Kenmore 25311531100 FREEZER
Kenmore 25311531101 FREEZER
Kenmore 25311531102 FREEZER
Kenmore 25311531103 FREEZER
Kenmore 25311541100 CHEST FREEZER
Kenmore 25311541102 FREEZER
Kenmore 25311711100 FREEZER
Kenmore 25311711101 CHEST FREEZER
Kenmore 25311711102 FREEZER
Kenmore 25311821100 FREEZER
Kenmore 25311821101 FREEZER
Kenmore 25311911100 FREEZER
Kenmore 25311911101 FREEZER
Kenmore 25312021100 FREEZER
Kenmore 25312021101 FREEZER
Kenmore 25312021102 FREEZER
Kenmore 25312541100 FREEZER
Kenmore 25312541102 SEARS/FREEZER
Kenmore 25312551100 FREEZER
Kenmore 25313009100 FREEZER
Kenmore 25313051100 FREEZER
Kenmore 25313051101 FREEZER
Kenmore 25313051102 FREEZER
Kenmore 25313051103 FREEZER
Kenmore 25313312101 FREEZER
Kenmore 25313351100 FREEZER
Kenmore 25313500100 FREEZER
Kenmore 25313500101 FREEZER
Kenmore 25313500102 FREEZER
Kenmore 25313500103 FREEZER
Kenmore 25313511100 CHEST FREEZER
Kenmore 25313511101 FREEZER
Kenmore 25313511102 FREEZER
Kenmore 25313541101 FREEZER
Kenmore 25313541102 FREEZER
Kenmore 25313551100 FREEZER
Kenmore 25313551101 FREEZER
Kenmore 25313711100 FREEZER
Kenmore 25313711101 FREEZER
Kenmore 25313711102 FREEZER
Kenmore 25313712100 FREEZER
Kenmore 25313712101 FREEZER
Kenmore 25313911100 FREEZER
Kenmore 25313911101 FREEZER
Kenmore 25313911102 FREEZER
Kenmore 25314092101 FREEZER
Kenmore 25314092102 FREEZER
Kenmore 25314092103 FREEZER
Kenmore 25314342100 FREEZER
Kenmore 25314342101 FREEZER
Kenmore 25314342102 FREEZER
Kenmore 25314352100 FREEZER
Kenmore 25314352101 FREEZER
Kenmore 25314352102 FREEZER
Kenmore 25314502100 FREEZER
Kenmore 25314502101 FREEZER
Kenmore 25314502102 FREEZER
Kenmore 25314502103 FREEZER
Kenmore 25314502104 FREEZER
Kenmore 25314502105 FREEZER
Kenmore 25314512100 FREEZER
Kenmore 25314512101 FREEZER
Kenmore 25314512102 FREEZER
Kenmore 25314512103 FREEZER
Kenmore 25314512104 FREEZER
Kenmore 25314542100 FREEZER
Kenmore 25314542101 FREEZER
Kenmore 25314542102 FREEZER
Kenmore 25314542103 FREEZER
Kenmore 25314542104 FREEZER
Kenmore 25314542105 FREEZER
Kenmore 25314552100 FREEZER
Kenmore 25314552101 FREEZER
Kenmore 25314552102 FREEZER
Kenmore 25314582100 FREEZER
Kenmore 25314592100 FREEZER
Kenmore 25314592101 FREEZER
Kenmore 25314592102 FREEZER
Kenmore 25314702100 FREEZER
Kenmore 25314702101 FREEZER
Kenmore 25314702102 FREEZER
Kenmore 25314702103 FREEZER
Kenmore 25314702104 FREEZER
Kenmore 25314712100 FREEZER
Kenmore 25314712101 FREEZER
Kenmore 25314712102 FREEZER
Kenmore 25314712103 FREEZER
Kenmore 25314772100 FREEZER
Kenmore 25314772101 FREEZER
Kenmore 25314772102 FREEZER
Kenmore 25314772103 FREEZER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Samsung RS2545SH dispenser water stopped working! but ice maker is working. patrocle Refrigerator & Freezer Repair 1 06-04-2016 10:51 AM
Kenmore side by side refrigerator Ice maker and water dispenser not working nat2256 Refrigerator & Freezer Repair 0 11-21-2014 03:13 PM
frigidaire water dispenser not working/ice maker and dispenser fine Exjerseygirl Refrigerator & Freezer Repair 0 04-19-2014 11:27 AM
Ice Maker and Water Dispenser not working bmw1987 Refrigerator & Freezer Repair 0 01-26-2013 08:40 AM
Ice Maker not working, water dispenser is working fine Monique Refrigerator & Freezer Repair 43 08-21-2012 09:18 PM
