Discuss
Need help troubleshooting refer issue, please
 in
Refrigerator & Freezer Repair
Recently, our refrigerator with bottom freezer stopped cooling properly. With the thermostat set on its default position of 4, the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Need help troubleshooting refer issue, please
  #1 (permalink)
Old 03-06-2017, 05:05 AM
Junior Member
Jackie_Treehorn is on a distinguished road
Default Need help troubleshooting refer issue, please
Model Number: KBRS22KGBL4   Brand: Kitchen Aid   Age: More than 10 years
Recently, our refrigerator with bottom freezer stopped cooling properly. With the thermostat set on its default position of 4, the freezer unit temperature raised to above 35 degrees and the fresh food section raised to above 50 degrees.
After doing all of the items below, I've since plugged the unit back in to monitor its status. The unit is empty currently except for two gallons of water in the fresh food section and two gallons of water in the freezer section. The unit will not operate properly at the default temperature settings as it has for years. It's cool, but not cold. In the default temperature setting the fresh food area is about 57 degrees. The freezer is about 20 degrees. If I turn the thermostat to 7, the coldest setting, the unit will in fact, cool both sections to their proper temperatures. Fresh food about 37 degrees. Freezer to about 2 degrees. FYI. I'm taking the temperatures in the fresh food section using a quality meat thermometer sticking it into the jugs of water. I'm using an outdoor thermometer sensor in the freezer section.
Here are some of the things I've done since:
Thoroughly cleaned the condenser coils under the unit. It was dirty to be sure, but now they are perfectly clean. I took the whole unit outside and used an air compressor to clean everything.
Checked to make sure all of the fans are operating. They are. The compressor fan is running fine as well as the condenser fan in the freezer section.
Pulled the rear panel off from the inside of the freezer to inspect the evaporator coils to confirm they are free of ice. They are free of any ice buildup even after running the unit for days now on thermostat setting 7.
I've also checked the compressor windings with a multimeter and other parts associated with starting the compressor. They seem to be just fine as the compressor is starting and running just fine.
So here I am asking what to do next. Thermostat? Thermistor? Coolant system leak?
Thanks appliance parts pros for this forum! Love it.
Related Models
Whirlpool KBRS22KGBL4 BOTTOM MOUNT REFERIGERATOR
Whirlpool KBRS22KGBT13 REFRIGERATOR
Whirlpool KBRS22KGBT3 REFRIGERATOR
Whirlpool KBRS22KGBT4 BOTTOM MOUNT REFERIGERATOR
Whirlpool KBRS22KGWH0 BOTTOM MOUNT REFRIGERATOR
Whirlpool KBRS22KGWH1 BOTTOM MOUNT REFRIGERATOR
Whirlpool KBRS22KGWH13 REFRIGERATOR
Whirlpool KBRS22KGWH2 REFRIGERATOR
Whirlpool KBRS22KGWH3 REFRIGERATOR
Whirlpool KBRS22KGWH4 BOTTOM MOUNT REFERIGERATOR
Whirlpool KBRS22KKBL00 REFRIGERATOR
Whirlpool KBRS22KKBT00 REFRIGERATOR
Whirlpool KBRS22KKWH00 REFRIGERATOR
Whirlpool KBRS22KTBL00 REFRIGERATOR
Whirlpool KBRS22KTBL01 REFRIGERATOR
Whirlpool KBRS22KTBL11 Refrigerator
Whirlpool KBRS22KTSS00 REFRIGERATOR
Whirlpool KBRS22KTSS01 REFRIGERATOR
Whirlpool KBRS22KTSS11 Refrigerator
Whirlpool KBRS22KTWH00 REFRIGERATOR
Whirlpool KBRS22KTWH01 REFRIGERATOR
Whirlpool KBRS22KTWH11 Refrigerator
Whirlpool KBRS22KVBL00 REFRIGERATOR
Whirlpool KBRS22KVBL1 REFRIGERATOR
Whirlpool KBRS22KVBL2 REFRIGERATOR
Whirlpool KBRS22KVSS00 REFRIGERATOR
Whirlpool KBRS22KVSS1 REFRIGERATOR
Whirlpool KBRS22KVSS2 REFRIGERATOR
Whirlpool KBRS22KVSS3 REFRIGERATOR
Whirlpool KBRS22KVSS4 REFRIGERATOR
Whirlpool KBRS22KVWH00 REFRIGERATOR
Whirlpool KBRS22KVWH1 REFRIGERATOR
Whirlpool KBRS22KVWH2 REFRIGERATOR
Whirlpool KBRS22KWAL00 REFRIGERATOR
Whirlpool KBRS22KWBL4 REFRIGERATOR
KitchenAid KBRS22KWBL5 REFRIGERATOR
Whirlpool KBRS22KWMS4 REFRIGERATOR
KitchenAid KBRS22KWMS5 REFRIGERATOR
Whirlpool KBRS22KWWH00 REFRIGERATOR
Whirlpool KBRS22KWWH01 Refrigerator
Whirlpool KBRS22KWWH02 Refrigerator
Whirlpool KBRS22KWWH03 Refrigerator
Whirlpool KBRS22KWWH4 REFRIGERATOR
KitchenAid KBRS22KWWH5 REFRIGERATOR
Whirlpool KBRS36FKB00 BUILT-IN REFRIGERATOR
Whirlpool KBRS36FKB01 BUILT IN REFRIGERATOR
Whirlpool KBRS36FKB02 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRS36FKT00 BUILT-IN REFRIGERATOR
Whirlpool KBRS36FKT01 BUILT IN REFRIGERATOR
Whirlpool KBRS36FKT02 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRS36FKW00 BUILT-IN REFRIGERATOR
Whirlpool KBRS36FKW01 BUILT IN REFRIGERATOR
Whirlpool KBRS36FKW02 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRS36FKX00 BUILT-IN REFRIGERATOR
Whirlpool KBRS36FKX01 BUILT IN REFRIGERATOR
Whirlpool KBRS36FKX02 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRS36FMB00 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRS36FMB01 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRS36FMB02 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRS36FMX00 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRS36FMX01 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRS36FMX02 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRS36FTX00 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRS36FTX02 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRS36MHB01 BUILT-IN REFRIGERATOR
Whirlpool KBRS36MHT01 BUILT-IN REFRIGERATOR
Whirlpool KBRS36MHW00 BUILT-IN REFRIGERATOR
Whirlpool KBRS36MHW01 BUILT-IN REFRIGERATOR
Whirlpool KBRS36MHX00 BUILT-IN REFRIGERATOR
Whirlpool KBRS36MHX01 BUILT-IN REFRIGERATOR
Whirlpool KBRV36FPM01 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRV36FPM02 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRV36FPS01 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBRV36FPS02 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBSS271TSS00 27" BUILT-IN GRILL
Whirlpool KBSS361TSS00 36" BUILT-IN GRILL
Whirlpool KBSU367TSS00 36" BUILT-IN GRILL
Whirlpool KBSU487TSS00 48" BUILT-IN GRILL
Whirlpool KBTU141TSS00 TRASH CAN DRAWER
Whirlpool KBTU141VSS00 TRASH CAN DRAWER
Whirlpool KBUDT4265E04 42" BUILT IN REFRIGERATOR
Whirlpool KBUDT4270A02 42" BUILT IN REFRIGERATOR
Whirlpool KBULT3661A02 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBURT3665E01 36" BOTTOM MOUNT BUILT IN REFRIGERATOR
Whirlpool KBUU142TSS00 UTILITY DRAWER
Whirlpool KBZU122TSS00 BUILT-IN SIDE BURNER
Whirlpool KBZU122VSS00 BUILT-IN SIDE BURNER
Whirlpool KBZU242TSS00 BUILT-IN SIDE BURNER
Whirlpool KC50XBZRZU01 POWER MATE
Whirlpool KC50XBZTZU01 POWER MATE
Whirlpool KC50XCMWZU01 POWER MATE
Whirlpool KC50XCRG0R030 POWER MATE
General Electric KC610AMT1 Room air conditioner
General Electric KC610APT1 Room air conditioner
General Electric KC710AMT1 Room air conditioner
General Electric KC710APT1 Room air conditioner
General Electric KC908FMP1 Room air conditioner
General Electric KC908FNP1 Room air conditioner
Frigidaire KC935JD0 Wwh(v2) / Electric Range
Frigidaire KC935JD1 Wwh(v4) / Electric Range
Frigidaire KC935JD2 Wwh(v6) / Electric Range
Frigidaire KC935JD3 Wwh(v5) / Electric Range
Frigidaire KC935JW0 Wwh(v1) / Electric Range
Frigidaire KC935JW1 Wwh(v3) / Electric Range
Frigidaire KC935JW2 Wwh(v5) / Electric Range
Frigidaire KC935JW3 Wwh(v6) / Electric Range
Frigidaire KC935KDD1 Wwh(v1) / Electric Range
Frigidaire KC935KDD2 Wwh(v3) / Electric Range
Frigidaire KC935KDD3 Wwh(v5) / Electric Range
Frigidaire KC935KDW1 Wwh(v2) / Electric Range
Frigidaire KC935KDW2 Wwh(v4) / Electric Range
Frigidaire KC935KDW3 Wwh(v6) / Electric Range
Whirlpool KCB148P Commercial Blender Pro Line Series
Whirlpool KCB148SGR0 COMMERCIAL BAR BLENDER
Whirlpool KCB348PGR0 Commercial Bar Blender
Whirlpool KCB348SGR0 Commercial Chef's Blender
Whirlpool KCBC150X DISPOSER
Whirlpool KCBC150X0 DISPOSER
Whirlpool KCBC250X DISPOSER
Whirlpool KCBC250X0 DISPOSER
  #2 (permalink)
Old 03-06-2017, 06:21 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
If it seems to work OK set on a higher setting, it could be the thermostat.
Most of the thermostat failures I've seen over the years are more likely to be intermittent operation.
Like running too long, getting too cold.
Not coming back on and warming up too much.
Very seldom do they change temperature range and still work. (Of course the temp range thing might be a sign the thermostat is failing.) But it does happen.
If everything else is working as you say it is, that really only leaves the thermostat. It does control the temperature and the older they are the more likely they are to fail. ( the contacts inside usually burn up)
Here is the part number.
Whirlpool W10752646 Thermostat - AppliancePartsPros.com
  #3 (permalink)
Old 03-06-2017, 07:20 AM
Junior Member
Default
Thanks. I ordered the thermostat. I'll replace it and see if that does the trick.
Is there no thermistor on this unit or is that a part of the thermostat?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Defrost Cycle troubleshooting issue jeffworn Refrigerator & Freezer Repair 0 02-23-2017 04:33 AM
Refer Advantage Refrigerator & Freezer Repair 0 06-07-2015 06:07 AM
Amana warm freezer and refer could jazz board be the issue if all tests good jimholstrom@yahoo.com Refrigerator & Freezer Repair 2 10-25-2014 10:25 AM
GE refer DFShoe Refrigerator & Freezer Repair 0 11-30-2013 01:32 PM
refer randy or Refrigerator & Freezer Repair 0 09-08-2011 06:24 PM
