Discuss
Which terminal to use fridge temperature control
 in
Refrigerator & Freezer Repair
I recently replaced the adaptive defrost control in my fridge for an unrelated issue. The replacement kit is 5303918476 which
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Which terminal to use fridge temperature control
  #1 (permalink)
Old 03-02-2017, 07:42 PM
Junior Member
ehsiandad is on a distinguished road
Default Which terminal to use fridge temperature control
Model Number: GLRS267ZAB5   Brand: Frigidaire   Age: More than 10 years
I recently replaced the adaptive defrost control in my fridge for an unrelated issue. The replacement kit is 5303918476 which is an updated part for the original control. Following the instructions I reconnected everything (leaving the one damper switch disconnected. The confusion I am having is that the temperature control dial for the fridge side has 4 terminals on it but the the new wiring harness that came with the new control kit only has 3 wire/connectors. One is green/yellow, another is white/purple wire and last is black. I"m pretty sure I've got the black and green/yellow wire connected to the correct terminals as I switched the wiring connectors one at a time, but with the remaining purple/white wire, I'm not sure which one to connect to. Reason I'm asking is because after I put everything back together, the first time, the fridge side was only getting down to about 14C, which seems to be a bit too warm and there was no air flow coming the damper outlet (yes the evaporator fan is working). I'm trying to figure out if I connected to the wrong terminal.
I've google and youtubed this and can't find any mention of this scenario.
Related Models
Frigidaire GLRS267ZAB5 Frigidaire/refrigerator
Frigidaire GLRS267ZAB6 Frigidaire/refrigerator
Frigidaire GLRS267ZAQ0 Frigidaire efrigerator
Frigidaire GLRS267ZAQ1 Frigidaire efrigerator
Frigidaire GLRS267ZAQ2 Frigidaire/refrigerator
Frigidaire GLRS267ZAQ3 Frigidaire/refrigerator
Frigidaire GLRS267ZAQ4 Frigidaire/refrigerator
Frigidaire GLRS267ZAQ5 Frigidaire/refrigerator
Frigidaire GLRS267ZAQ6 Frigidaire/refrigerator
Frigidaire GLRS267ZAW0 Frigidaire efrigerator
Frigidaire GLRS267ZAW1 Frigidaire efrigerator
Frigidaire GLRS267ZAW2 Frigidaire/refrigerator
Frigidaire GLRS267ZAW3 Frigidaire/refrigerator
Frigidaire GLRS267ZAW4 Frigidaire/refrigerator
Frigidaire GLRS267ZAW5 Frigidaire/refrigerator
Frigidaire GLRS267ZAW6 Frigidaire/refrigerator
Frigidaire GLRS267ZCB0 Frigidair/refrigerator
Frigidaire GLRS267ZCB1 Frigidaire/refrigerator
Frigidaire GLRS267ZCB2 Frigidaire/refrigerator
Frigidaire GLRS267ZCB3 Frigidaire/refrigerator
Frigidaire GLRS267ZCQ0 Frigidair/refrigerator
Frigidaire GLRS267ZCQ1 Frigidaire/refrigerator
Frigidaire GLRS267ZCQ2 Frigidaire/refrigerator
Frigidaire GLRS267ZCQ3 Frigidaire/refrigerator
Frigidaire GLRS267ZCW0 Frigidair/refrigerator
Frigidaire GLRS267ZCW1 Frigidaire/refrigerator
Frigidaire GLRS267ZCW2 Frigidaire/refrigerator
Frigidaire GLRS267ZCW3 Frigidaire/refrigerator
Frigidaire GLRS267ZDB0 Frigidaire/refrigerator
Frigidaire GLRS267ZDB1 Frigidaire/refrigerator
Frigidaire GLRS267ZDB2 Frigidaire/refrigerator
Frigidaire GLRS267ZDB3 Frigidaire/refrigerator
Frigidaire GLRS267ZDB4 Frigidaire/refrigerator
Frigidaire GLRS267ZDB5 Frigidaire/refrigerator
Frigidaire GLRS267ZDQ0 Frigidaire/refrigerator
Frigidaire GLRS267ZDQ1 Frigidaire/refrigerator
Frigidaire GLRS267ZDQ2 Frigidaire/refrigerator
Frigidaire GLRS267ZDQ3 Frigidaire/refrigerator
Frigidaire GLRS267ZDQ4 Frigidaire/refrigerator
Frigidaire GLRS267ZDQ5 Frigidaire/refrigerator
Frigidaire GLRS267ZDW0 Frigidaire/refrigerator
Frigidaire GLRS267ZDW1 Frigidaire/refrigerator
Frigidaire GLRS267ZDW2 Frigidaire/refrigerator
Frigidaire GLRS267ZDW3 Frigidaire/refrigerator
Frigidaire GLRS267ZDW4 Frigidaire/refrigerator
Frigidaire GLRS267ZDW5 Frigidaire/refrigerator
Frigidaire GLRS64ZEB0 Frigidaire/refrigerator
Frigidaire GLRS64ZEB2 Frigidaire/refrigerator
Frigidaire GLRS64ZEB3 Frigidaire/refrigerator
Frigidaire GLRS64ZEB4 Frigidaire/refrigerator
Frigidaire GLRS64ZEB5 Frigidaire/refrigerator
Frigidaire GLRS64ZEB6 Frigidaire/refrigerator
Frigidaire GLRS64ZEB7 Frigidaire/refrigerator
Frigidaire GLRS64ZEB8 Frigidaire/refrigerator
Frigidaire GLRS64ZEB9 Frigidaire/refrigerator
Frigidaire GLRS64ZEBA Frigidaire/refrigerator
Frigidaire GLRS64ZEQ0 Frigidaire/refrigerator
Frigidaire GLRS64ZEQ2 Frigidaire/refrigerator
Frigidaire GLRS64ZEQ3 Frigidaire/refrigerator
Frigidaire GLRS64ZEQ4 Frigidaire/refrigerator
Frigidaire GLRS64ZEQ5 Frigidaire/refrigerator
Frigidaire GLRS64ZEQ6 Frigidaire/refrigerator
Frigidaire GLRS64ZEQ7 Frigidaire/refrigerator
Frigidaire GLRS64ZEQ8 Frigidaire/refrigerator
Frigidaire GLRS64ZEQ9 Frigidaire/refrigerator
Frigidaire GLRS64ZEQA Frigidaire/refrigerator
Frigidaire GLRS64ZEW0 Frigidaire/refrigerator
Frigidaire GLRS64ZEW2 Frigidaire/refrigerator
Frigidaire GLRS64ZEW3 Frigidaire/refrigerator
Frigidaire GLRS64ZEW4 Frigidaire/refrigerator
Frigidaire GLRS64ZEW5 Frigidaire/refrigerator
Frigidaire GLRS64ZEW6 Frigidaire/refrigerator
Frigidaire GLRS64ZEW7 Frigidaire/refrigerator
Frigidaire GLRS64ZEW8 Frigidaire/refrigerator
Frigidaire GLRS64ZEW9 Frigidaire/refrigerator
Frigidaire GLRS64ZEWA Frigidaire/refrigerator
Frigidaire GLRSF236JB0 Frg(v1) / Refrigerator
Frigidaire GLRSF236JB1 Frg(v1) / Refrigerator
Frigidaire GLRSF236JB2 SIDE BY SIDE REFRIGERATOR
Frigidaire GLRSF236JD0 Frg(v2) / Refrigerator
Frigidaire GLRSF236JD1 Frg(v2) / Refrigerator
Frigidaire GLRSF236JD2 SIDE BY SIDE REFRIGERATOR
Frigidaire GLRSF236JW0 Frg(v3) / Refrigerator
Frigidaire GLRSF236JW1 Frg(v3) / Refrigerator
Frigidaire GLRSF236JW2 SIDE BY SIDE REFRIGERATOR
Frigidaire GLRSF266JB0 Frg(v1) / Refrigerator
Frigidaire GLRSF266JB1 Frg(v1) / Refrigerator
Frigidaire GLRSF266JB2 Frigidaire/refrigerator
Frigidaire GLRSF266JD0 Frg(v2) / Refrigerator
Frigidaire GLRSF266JD1 Frg(v2) / Refrigerator
Frigidaire GLRSF266JD2 Frigidaire/refrigerator
Frigidaire GLRSF266JW0 Frg(v3) / Refrigerator
Frigidaire GLRSF266JW1 Frg(v3) / Refrigerator
Frigidaire GLRSF266JW2 Frigidaire/refrigerator
Frigidaire GLRT13TEB0 Frigidaire/refrigerator
Frigidaire GLRT13TEB1 Frigidaire/refrigerator
Frigidaire GLRT13TEB2 Frigidaire/refrigerator
Frigidaire GLRT13TEB3 Frigidaire/refrigerator
Frigidaire GLRT13TEB4 Frigidaire/refrigerator
Frigidaire GLRT13TEB5 Frigidaire/refrigerator
Frigidaire GLRT13TEB7 Frigidaire/refrigerator
Frigidaire GLRT13TEB8 Frigidaire/refrigerator
Frigidaire GLRT13TEK0 Frigidaire/refrigerator
Frigidaire GLRT13TEK1 Frigidaire/refrigerator
Frigidaire GLRT13TEK2 Frigidaire/refrigerator
Frigidaire GLRT13TEK4 Frigidaire/refrigerator
Frigidaire GLRT13TEK5 Frigidaire/refrigerator
Frigidaire GLRT13TEK6 Frigidaire/refrigerator
Frigidaire GLRT13TEK7 Frigidaire/refrigerator
Frigidaire GLRT13TEK8 Frigidaire/refrigerator
Frigidaire GLRT13TEQ0 Frigidaire/refrigerator
Frigidaire GLRT13TEQ1 Frigidaire/refrigerator
Frigidaire GLRT13TEQ2 Frigidaire/refrigerator
Frigidaire GLRT13TEQ3 Frigidaire/refrigerator
Frigidaire GLRT13TEQ4 Frigidaire/refrigerator
Frigidaire GLRT13TEQ5 Frigidaire/refrigerator
Frigidaire GLRT13TEQ7 Frigidaire/refrigerator
Frigidaire GLRT13TEQ8 Frigidaire/refrigerator
Frigidaire GLRT13TES0 Frigidaire/refrigerator
Frigidaire GLRT13TES1 Frigidaire/refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Temperature control tboytjsmith Refrigerator & Freezer Repair 0 09-20-2013 11:20 PM
Fridge Temperature blackbirdMD Refrigerator & Freezer Repair 8 09-18-2012 05:33 PM
Replacement oven control short a terminal shortcircuit Oven Repair (including Ranges and Cooktops) 3 02-17-2011 01:03 PM
Right terminal on terminal block blown st3 Oven Repair (including Ranges and Cooktops) 1 03-19-2010 01:26 PM
