Xref and strange problems
Refrigerator & Freezer Repair
1st.. I am trying to find the exact (or closest) Frigidaire model number for my Kenmore French Door fridge (253.70313211)
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Xref and strange problems
  #1 (permalink)
Old 02-27-2017, 10:09 AM
Junior Member
barryware is on a distinguished road
Default Xref and strange problems
Model Number: 253.70313211   Brand: Kenmore   Age: 1 - 5 years
In diagnosing a problem, I found what I will call a strange design (flaw??).
The fridge quit dispensing water. You could hear the valves click and buzz but no water came out.
I performed the normal diagnosis.. I rang out the water valve coils with an ohm meter, no problem.. I checked the signal at the valve(s), no problem. So.. One would think it was a bad valve (mechanically).
Then I noticed that it also quite making ice. The ice maker is in the fresh food compartment. You can hear it drop the ice, then a few seconds later you can hear the fill valve(s) click and buzz.. No water to the ice maker.
One valve (water dispenser) goes bad.. OK.. Two at once (water dispenser & ice maker fill), pretty rare so I did some more digging.
The valve assembly has a total of four valves.. One main valve (main water supply => to filter), a yellow valve (water dispense), a green valve (fresh food ice maker), and a blue valve (freezer compartment ice maker). I do not have an ice maker in the freezer compartment.
The water line from the filter goes into the fridge from the back next to the blue freezer ice maker line (not equipped), then comes out. I am going to call this a loop.. In to the back of the fridge above the freezer, it seems to loop and come right back out. This line connects to the supply port for the other three valves.
I understand why the blue line is there even though not used.. I do not understand why the line from the filter goes in, seems to loop, then comes out and goes down to supply the other three valves.
Long story short, this line seems to have frozen and the plugged / frozen section would not allow water to go to the other valves.
I got everything working by bypassing the in and out loop. I'm sure if I had a place to put the contents of the fridge, I could have emptied it out, turned it off for a few hours and the line would have thawed out.
My boggle: What is this in/out for? I can see no reason it exists. What would make it freeze after 3 years of running with no problems?
Related Models
Frigidaire 2530A GAS RANGE
Frigidaire 2530B GAS RANGE
Frigidaire 2530C GAS RANGE
Frigidaire 2530D GAS RANGE
Frigidaire 2530E GAS RANGE
Kenmore 25310301000 CHEST FREEZER
Kenmore 25310301001 CHEST FREEZER
Kenmore 25310311000 CHEST FREEZER
Kenmore 25310311001 CHEST FREEZER
Kenmore 25310311002 FREEZER
Kenmore 25310911990 FREEZER
Kenmore 25310911991 CHEST FREEZER
Kenmore 25310911992 CHEST FREEZER
Kenmore 25311301100 FREEZER
Kenmore 25311301101 FREEZER
Kenmore 25311311100 CHEST FREEZER
Kenmore 25311312100 FREEZER
Kenmore 25311312101 FREEZER
Kenmore 25311312102 SEARS/FREEZER
Kenmore 25311321100 CHEST FREEZER
Kenmore 25311321101 FREEZER
Kenmore 25311351100 FREEZER
Kenmore 25311351101 CHEST FREEZER
Kenmore 25311351102 FREEZER
Kenmore 25311511100 CHEST FREEZER
Kenmore 25311511101 FREEZER
Kenmore 25311521100 FREEZER
Kenmore 25311521102 CHEST FREEZER
Kenmore 25311521103 FREEZER
Kenmore 25311531100 FREEZER
Kenmore 25311531101 FREEZER
Kenmore 25311531102 FREEZER
Kenmore 25311531103 FREEZER
Kenmore 25311541100 CHEST FREEZER
Kenmore 25311541102 FREEZER
Kenmore 25311711100 FREEZER
Kenmore 25311711101 CHEST FREEZER
Kenmore 25311711102 FREEZER
Kenmore 25311821100 FREEZER
Kenmore 25311821101 FREEZER
Kenmore 25311911100 FREEZER
Kenmore 25311911101 FREEZER
Kenmore 25312021100 FREEZER
Kenmore 25312021101 FREEZER
Kenmore 25312021102 FREEZER
Kenmore 25312541100 FREEZER
Kenmore 25312541102 SEARS/FREEZER
Kenmore 25312551100 FREEZER
Kenmore 25313009100 FREEZER
Kenmore 25313051100 FREEZER
Kenmore 25313051101 FREEZER
Kenmore 25313051102 FREEZER
Kenmore 25313051103 FREEZER
Kenmore 25313312101 FREEZER
Kenmore 25313351100 FREEZER
Kenmore 25313500100 FREEZER
Kenmore 25313500101 FREEZER
Kenmore 25313500102 FREEZER
Kenmore 25313500103 FREEZER
Kenmore 25313511100 CHEST FREEZER
Kenmore 25313511101 FREEZER
Kenmore 25313511102 FREEZER
Kenmore 25313541101 FREEZER
Kenmore 25313541102 FREEZER
Kenmore 25313551100 FREEZER
Kenmore 25313551101 FREEZER
Kenmore 25313711100 FREEZER
Kenmore 25313711101 FREEZER
Kenmore 25313711102 FREEZER
Kenmore 25313712100 FREEZER
Kenmore 25313712101 FREEZER
Kenmore 25313911100 FREEZER
Kenmore 25313911101 FREEZER
Kenmore 25313911102 FREEZER
Kenmore 25314092101 FREEZER
Kenmore 25314092102 FREEZER
Kenmore 25314092103 FREEZER
Kenmore 25314342100 FREEZER
Kenmore 25314342101 FREEZER
Kenmore 25314342102 FREEZER
Kenmore 25314352100 FREEZER
Kenmore 25314352101 FREEZER
Kenmore 25314352102 FREEZER
Kenmore 25314502100 FREEZER
Kenmore 25314502101 FREEZER
Kenmore 25314502102 FREEZER
Kenmore 25314502103 FREEZER
Kenmore 25314502104 FREEZER
Kenmore 25314502105 FREEZER
Kenmore 25314512100 FREEZER
Kenmore 25314512101 FREEZER
Kenmore 25314512102 FREEZER
Kenmore 25314512103 FREEZER
Kenmore 25314512104 FREEZER
Kenmore 25314542100 FREEZER
Kenmore 25314542101 FREEZER
Kenmore 25314542102 FREEZER
Kenmore 25314542103 FREEZER
Kenmore 25314542104 FREEZER
Kenmore 25314542105 FREEZER
Kenmore 25314552100 FREEZER
Kenmore 25314552101 FREEZER
Kenmore 25314552102 FREEZER
Kenmore 25314582100 FREEZER
Kenmore 25314592100 FREEZER
Kenmore 25314592101 FREEZER
Kenmore 25314592102 FREEZER
Kenmore 25314702100 FREEZER
Kenmore 25314702101 FREEZER
Kenmore 25314702102 FREEZER
Kenmore 25314702103 FREEZER
Kenmore 25314702104 FREEZER
Kenmore 25314712100 FREEZER
Kenmore 25314712101 FREEZER
Kenmore 25314712102 FREEZER
Kenmore 25314712103 FREEZER
Kenmore 25314772100 FREEZER
Kenmore 25314772101 FREEZER
Kenmore 25314772102 FREEZER
Kenmore 25314772103 FREEZER
  #2 (permalink)
Old 02-28-2017, 11:45 AM
Junior Member
Incase anyone cares or this may help others..
Even though the water and ice were working.. The wife pointed out to me water dripping down the interior back wall underneath the ice maker.
Keep in mind, the ice maker is in the fresh food compartment. It is its own little freezer.. Has its own small evaporator, defrost heater, etc..
I took it all apart.. 1st, the frozen in / out tube is some sort of reservoir. I get it.. So the water is cold when you fill your glass.. To me, makes no sense if you follow the water path.. Your glass is 1/2 full before the cold(er) water hits.
The defrost drain for the ice maker evaporator is frozen solid.. Problem is that being a fridge, everything is insulated. It will take a day or two ~ 3 for it to thaw.
I have no idea what may have caused the drain to freeze.. While apart, everything tests OK with a VOM (heater, defrost thermostat, etc.)
Maybe we left a door open and did not realize it?
How would a Pro thaw the drain? I have a heat gun.. That didn't do much as the drain seems to be frozen for several inches (down the back of the fridge, behind a non-removable outside panel). Caution must be taken. I'm sure the refrigerant lines are close if not part of the drain.
I can't imagine a Pro leaving with the fridge apart and saying he will be back in 2 ~ 3 days..
Any tips would be appreciated.
  #3 (permalink)
Old 03-01-2017, 10:14 PM
Senior Member
PNWDrew is on a distinguished road
Some of us would tell you to unplug it and come back in a few days. Depens on depth of problem and how busy we are.
If I'm nice I use a steamer to thaw things out, it is faster than a heat gun and less messy than hot water. You'll still have water to control but less at least.
Defrost drains clog or freeze for no reason, foreign matter, frost, etc... there may even be a seal kit for your machine's ice room because of a frosting issue. It's a constant issue in brands with an upper ice room. Once you get that drain flowing check the bottom end near compressor for any reaon it would not be draining properly.
Warning, the handle comes apart very easily right where you hold it, you do not want to be holding it there if that happens. Tape it or something.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE DW acting strange C@TCH Dishwasher Repair 11 04-24-2013 03:16 PM
Strange Washer dirtyhat62 Washer Repair 2 04-16-2009 07:41 PM
strange noise pygoodman Refrigerator & Freezer Repair 1 04-27-2008 04:46 PM
Strange Problem cdkoshivas Washer Repair 1 04-23-2008 02:30 AM
strange code spatera Washer Repair 0 01-04-2008 03:22 PM
