Register | FAQ's | New Posts | Today's Posts | Extras |
» Amana Freezer Freezing Up |
![]() Model Number: SX26VE Brand: Amana Age: Less than 1 year
![]() Need some help. I have attached a pic but do to upload size I had to resize. Two days ago freezer started to unthaw so I took it apart and saw what's in the picture but worse. I unplugged it and defrosted it with heat gun. Plugged it and and worked. Froze ice cubes and such but checked it today and it started to do it again. Any ideas? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() That is a defrost problem.
You have a bad part. There are three basic parts in a defrost system. The defrost heater, the defrost thermostat, and the defrost timer. The defrost heater could be bad, but more likely its the thermostat or timer. This is the defrost thermostat. If you check it when its got frost on it, it should be "closed", in other words very low or zero ohm reading so it completes the circuit to the heating element so it can heat up. Whirlpool R0161088 Thermostat, Defrost - AppliancePartsPros.com This is the defrost timer. Its basically a clock with electrical contacts. It sends power to the compressor for a certain number of hours (6, 8, or 12) depending on the refrigerator design. Then it switches to defrost for 20 to 30 minutes (also depends on design). Whirlpool R0131577 Defrost Timer Kit - AppliancePartsPros.com You can test the defrost system by manually turning the defrost timer with a large straight screwdriver. It will click along until you hear a slightly louder click and then the element should start heating. If it doesn't it might be the defrost thermostat or defrost heating element. Like all clocks it can stop turning or run slower with age. |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Amana, bottom freezer not freezing | Sparkey 3 | Refrigerator & Freezer Repair | 1 | 09-06-2012 04:12 AM |
Amana fridge w/btm freezer - freezer not freezing, fans running | JonnyB | Refrigerator & Freezer Repair | 5 | 07-30-2012 10:58 AM |
amana bottom freezer not freezing | graygoose54@yahoo.com | Refrigerator & Freezer Repair | 0 | 08-02-2011 08:09 AM |
Amana Refridgerator - freezer not freezing | VTRI | Refrigerator & Freezer Repair | 0 | 07-25-2010 07:33 PM |
Amana freezer not freezing | hazimalac | Refrigerator & Freezer Repair | 3 | 07-14-2009 11:21 PM |
