Discuss
GE Ice Maker/Not making Ice
 in
Refrigerator & Freezer Repair
I First checked the fill tube and line for ice blockage. I tested the inlet control valves ohms and it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE Ice Maker/Not making Ice
  #1 (permalink)
Old 02-11-2017, 11:26 AM
Junior Member
m500sesp is on a distinguished road
Default GE Ice Maker/Not making Ice
Model Number: TFX22CRDA CC   Brand: GE   Age: More than 10 years
  • I First checked the fill tube and line for ice blockage.
  • I tested the inlet control valves ohms and it was getting continuity.
  • The water valve for the water dispenser, in the door, works just fine.
  • So I figured the ice maker valve portion of the Water Inlet Valve was bad mechanically, regardless of the continuity or not.
  • I replaced the water inlet valve....Same result.
  • I then switched the wires from the water dispenser over to the ice maker valve. Hit the dispenser button...and the ice maker valve opened and spit water out.
  • So at this point I'm not sure what to test or how to test. It has the older style mechanical gears that does not have the holes where you can put in the jumper wire.
  • I did also try advancing the gear to initiate the cycle..Does not spit out any water.
Also it would help if I knew the timing of the rotation of the ice maker so I could put a voltmeter on the wires to try and see if it is sending a signal to the valve to open. Or however you would test that.
Thanks,
Sam
Related Models
General Electric TFX22CRDAAA Refrigerator
General Electric TFX22CRDABB Refrigerator
General Electric TFX22CRDACC Refrigerator
General Electric TFX22CRDAWW Refrigerator
General Electric TFX22CRXAAA Refrigerator
General Electric TFX22CRXABB Refrigerator
General Electric TFX22CRXAWW Refrigerator
General Electric TFX22CRXDAA Refrigerator
General Electric TFX22CRXDBB Refrigerator
General Electric TFX22CRXDWW Refrigerator
General Electric TFX22CRXFAA Refrigerator
General Electric TFX22CRXFBB Refrigerator
General Electric TFX22CRXFWW Refrigerator
General Electric TFX22DFB Refrigerator
General Electric TFX22DGB Refrigerator
General Electric TFX22DHB Refrigerator
General Electric TFX22DHE Refrigerator
General Electric TFX22DJB Refrigerator
General Electric TFX22DJC Refrigerator
General Electric TFX22DJE Refrigerator
General Electric TFX22DJF Refrigerator
General Electric TFX22DKB Refrigerator
General Electric TFX22DKC Refrigerator
General Electric TFX22DKD Refrigerator
General Electric TFX22DLB Refrigerator
General Electric TFX22DLC Refrigerator
General Electric TFX22DLG Refrigerator
General Electric TFX22GRBAWW Refrigerator
General Electric TFX22GRBBWW Refrigerator
General Electric TFX22GRBCWW Refrigerator
General Electric TFX22GRBEWW Refrigerator
General Electric TFX22GRBGWW Refrigerator
General Electric TFX22JABAAA Refrigerator
General Electric TFX22JABAWW Refrigerator
General Electric TFX22JABBAA Refrigerator
General Electric TFX22JABBWW Refrigerator
General Electric TFX22JABCAA Refrigerator
General Electric TFX22JABCWW Refrigerator
General Electric TFX22JABEAA Refrigerator
General Electric TFX22JABEWW Refrigerator
General Electric TFX22JABGAA Refrigerator
General Electric TFX22JABGWW Refrigerator
General Electric TFX22JAXAAA Refrigerator
General Electric TFX22JAXAWW Refrigerator
General Electric TFX22JAYAAA Refrigerator
General Electric TFX22JAYAWW Refrigerator
General Electric TFX22JAYFAA Refrigerator
General Electric TFX22JAYFWW Refrigerator
General Electric TFX22JRBAAA Refrigerator
General Electric TFX22JRBAWW Refrigerator
General Electric TFX22JRBBAA Refrigerator
General Electric TFX22JRBBWW Refrigerator
General Electric TFX22JRSAAD Refrigerator
General Electric TFX22JRSAWH Refrigerator
General Electric TFX22JRSBAD Refrigerator
General Electric TFX22JRSBWH Refrigerator
General Electric TFX22JRSMAD Refrigerator
General Electric TFX22JRSMWH Refrigerator
General Electric TFX22JRXAAA Refrigerator
General Electric TFX22JRXAWW Refrigerator
General Electric TFX22JRZAAA Refrigerator
General Electric TFX22JRZAWW Refrigerator
General Electric TFX22JRZBAA Refrigerator
General Electric TFX22JRZBWW Refrigerator
General Electric TFX22JWXAAA Refrigerator
General Electric TFX22JWXAWW Refrigerator
General Electric TFX22JWXDAA Refrigerator
General Electric TFX22JWXDWW Refrigerator
General Electric TFX22JWYAAA Refrigerator
General Electric TFX22JWYAWW Refrigerator
General Electric TFX22JWYDAA Refrigerator
General Electric TFX22JWYDWW Refrigerator
General Electric TFX22JWYFAA Refrigerator
General Electric TFX22JWYFWW Refrigerator
General Electric TFX22KHB Refrigerator
General Electric TFX22KHE Refrigerator
General Electric TFX22KJB Refrigerator
General Electric TFX22KJC Refrigerator
General Electric TFX22KJE Refrigerator
General Electric TFX22KJF Refrigerator
General Electric TFX22KKB Refrigerator
General Electric TFX22KKC Refrigerator
General Electric TFX22KKD Refrigerator
General Electric TFX22KLB Refrigerator
General Electric TFX22KLC Refrigerator
General Electric TFX22KLG Refrigerator
General Electric TFX22KLJ Refrigerator
General Electric TFX22KLK Refrigerator
General Electric TFX22KLL Refrigerator
General Electric TFX22KLP Refrigerator
General Electric TFX22KLR Refrigerator
General Electric TFX22KPDAAA Refrigerator
General Electric TFX22KPDAWW Refrigerator
General Electric TFX22KRCBAA Refrigerator
General Electric TFX22KRCBWW Refrigerator
General Electric TFX22KRCCAA Refrigerator
General Electric TFX22KRCCWW Refrigerator
General Electric TFX22KRCEAA Refrigerator
General Electric TFX22KRCEWW Refrigerator
General Electric TFX22KRCGAA Refrigerator
General Electric TFX22KRCGWW Refrigerator
General Electric TFX22KRDAAA Refrigerator
General Electric TFX22KRDAWW Refrigerator
General Electric TFX22NWZAWH Refrigerator
General Electric TFX22NWZBWH Refrigerator
General Electric TFX22PLB Refrigerator
General Electric TFX22PLJ Refrigerator
General Electric TFX22PLK Refrigerator
General Electric TFX22PLL Refrigerator
General Electric TFX22PMB Refrigerator
General Electric TFX22PMC Refrigerator
General Electric TFX22PMD Refrigerator
General Electric TFX22PME Refrigerator
General Electric TFX22PPBAAA Refrigerator
General Electric TFX22PPBABB Refrigerator
General Electric TFX22PPBAWW Refrigerator
General Electric TFX22PPBBAA Refrigerator
General Electric TFX22PPBBBB Refrigerator
General Electric TFX22PPBBWW Refrigerator
General Electric TFX22PPBCAA Refrigerator
  #2 (permalink)
Old 02-11-2017, 07:37 PM
Senior Member
PNWDrew is on a distinguished road
Default
Does it cycle the ejector arm and bale? As if it was harvesting a load and checking to see if the bin was full?
It probably looks like this:?
You've mentioned that you saw the gears. I'm not trying to doubt what you've tried but just covering all bases. Unless it has been changed it should have the jumper holes, they did from the factory. I've actually never seen an older one that didn't and some still do. If you pull the white front cover off are there 2 gears there? A little and a big?
If so, the little gear may have a slot in the middle. Stick a slothead screwdriver in it and turn gently counter clockwise a few degrees. It should proceed into a harvest cycle from there. If not turn it a little more. It will not try to fill until the end of the cycle. And you may hear the usual hum as the valve opens.
The next computer controlled generation did not have any way to jump the thermostat but would initiate harvest if the bale arm was lifted and returned fully 5-6 times in rapid succession. Try that.
You may have to hold the door switch in to power the IM.
Beneath that white cover should be something like this. This is a whirlpool version but GE were similar. Neither manufactured their own. Yours should have a small gear on top left of the large one.
In this one you cannot turn the gear manually but you can jump the thermostat. It's the holes labeled T and H. You'll need a fairly thin long wire to reach the internal contacts, and it must be insulated where you hold it or you may get shocked. When you make the circuit it'll begin to turn the ejector. Hold that jumper in until you hear a click, after that you can remove it. You may have to hold the door switch in for this too.
As a last resort you can forcefully lift the ejector fingers to the rotate the head and sometimes get it started that way.
Finally is the freezer actually cold enough? The thermostat will not initiate a cycle until 15 degrees or lower. If your ice cream isn't firm it may not be cold enough. Also ejector fingers can get stuck or jammed.
If you can get it to try to harvest you can use your meter to see if it is supplying 120v to the valve at the end of the cycle. Just probe to connector at the valve.
Try all that applies and if not post a pic of what is beneath that front cover. or at least the whole unit.
Good Luck
  #3 (permalink)
Old 02-11-2017, 07:47 PM
Senior Member
Default
I'm going to start at the beginning though you seem to have covered a little of this.
You've mentioned that you saw the gears. Unless it has been changed it should have the jumper holes, they did from the factory. I've actually never seen an older one that didn't and some still do. If you pull the white front cover off are there 2 gears there? A little and a big?
In this one you cannot turn the gear manually but you can jump the thermostat. It's the holes labeled T and H. You'll need a fairly thin long wire to reach the internal contacts, and it must be insulated where you hold it or you may get shocked. When you make the circuit it'll begin to turn the ejector. Hold that jumper in until you hear a click, after that you can remove it. It'll proceed from there. You may have to hold the door switch in for this too.
As a last resort you can forcefully lift the ejector fingers to rotate the head and sometimes get it started that way.
If you can get it to try to harvest you can use your meter to see if it is supplying 120v to the valve at the end of the cycle. Just probe the connector at the valve. A final thought; is the freezer door switch functional? Turns light on and off, fan also?
Good Luck
  #4 (permalink)
Old 02-12-2017, 05:08 AM
Junior Member
Default Picture of the End
Here is a picture of the end. I did read somewhere that you can turn the little gear counter clock wise to initiate a cycle. Which I've done and the mechanical part starts and works correctly. But it does not spray water into the tray.
Thanks,
Sam
  #5 (permalink)
Old 02-12-2017, 09:05 AM
Senior Member
Default
You have a rare one there. So jumping the thermostat is out of the question and you've already forced a cycle by turning the small gear counterclockwise until it runs on it's own.
When you say it "spit" out water do you mean it came out up at the IM? Or did you have the tube disconnected at the valve at that point? Just to be certain I'd switch the valve wiring again and try getting water, if it comes out in the freezer you know the valve and all tubing to the IM is ok. The only thing left is a wiring issue.
I'd guess you have a bad IM module. Maybe a contact inside has burned off.
Not much else you can test unless you want to pull the IM module (the guts) out of there. As for the whole IM it'll hang on 2 screws above the ice mold and out it comes. The replacement is easy.
Stumbled across this and it applies to your IM specifically:
GE Icemaker Repair
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker making grinding noise not making ice Kdsantoro Refrigerator & Freezer Repair 0 06-21-2016 07:48 PM
Ice maker stopped making ice, started making "owl hooting" sound Nerva Refrigerator & Freezer Repair 2 06-17-2015 10:53 AM
Fridge making clicking noise. Ice maker stopped making ice Sandeep Refrigerator & Freezer Repair 0 07-30-2013 06:48 AM
Frigidaire Ice Maker--making noise/not making ice lak Refrigerator & Freezer Repair 1 06-24-2013 03:30 AM
ice maker not making ice swami1999 Refrigerator & Freezer Repair 10 02-06-2010 08:42 AM
