Hi, I could not find a ice maker directory. Please accept my apologies if this is not suitable for this group. I have a marvel 30imt ice maker. It was laud for sometime back and yesterday stopped making ice. Water was flowing over plate but inside was hot. All the ice melted. When I put my hand closer to circulation pump, looked like circulation pump got hot. Water is leaking on plate, but since it was hot inside could not make it. Do you think for some reason circulation pump is overloaded? Should I change the pump right away? Or do you think some maintenance would work? Other opinions what can cause this? Appreciate your help... Thanks..
