Discuss
Whirlpool Freezer - Gray Putty Square & Copper Tubing?
 in
Refrigerator & Freezer Repair
Whirlpool Upright Freezer, Model # WZF34X16DW Greetings. I purchased this new freezer in December 2016. Within a week, I started
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool Freezer - Gray Putty Square & Copper Tubing?
  #1 (permalink)
Old 02-06-2017, 07:09 PM
Junior Member
deputyjvs is on a distinguished road
Default Whirlpool Freezer - Gray Putty Square & Copper Tubing?
Model Number: WZF34X16DW   Brand: Whirlpool   Age: Less than 1 year
Greetings. I purchased this new freezer in December 2016. Within a week, I started hearing a loud buzzing coming from the back when the freezer was running. When I pulled off the cardboard cover from the lower back, I noticed the sound was coming from two copper pieces touching and vibrating as the compressor was running. The two pieces are located to the right of the compressor, consisting of a thicker horizontal copper tube coming out of the right side of compressor, and a thin vertical spiral tube coming out of the bottom end of a fat vertical cigar shaped copper tube (I believe it is the UV Dye Dryer), which sit just behind the right hand grill openings on the cardboard backing. The spiral tubing was touching the compressor tubing, vibrating, and making a loud noise. I also noticed that a square piece of gray putty like material (with plastic backing), about 2" x 2", was laying on the metal bottom of the freezer unattached to anything, laying just under these tubes. Part of the putty square was disrupted and looked like it had been wrapped around something. In holding it up, it seemed to be about the size to wrap and stick around half of the fat cigar shaped vertical copper tube (dryer), with the remainder of the putty square being long enough to go between the two pieces of copper tubing that were touching (the putty side touching the spiral tubing, and the plastic backing side touching the compressor tubing). Can you please confirm what that putty square is for, if that is where it goes, and how to properly reattach it, if possible? Should those tubes be touching? Does this need to already be fixed under warranty after only a week? Thanks for your advice!
Related Models
General Electric WZRE5260F0GG Washer
General Electric WZRE5260F2GG Washer
General Electric WZSE5310T0WW Washer
General Electric WZSE5310T1WW Washer
Roper X05002F00 AIR CONDITIONER
Roper X05002F01 AIR CONDITIONERS
Roper X05002F02 AIR CONDITIONERS
Roper X05002G0 AIR CONDITIONERS
Roper X05002V0 Air-conditioner/heat pump
Roper X05002W00 Air-conditioner/heat pump
Roper X05002W01 Air-conditioner/heat pump
Roper X05002X00 Air-conditioner/heat pump
Roper X05002X01 Air-conditioner/heat pump
Roper X05002X02 Air-conditioner/heat pump
Roper X05002X03 Air-conditioner/heat pump
Whirlpool X05002X04 Air-conditioner/heat pump
Roper X05002X05 AIR CONDITIONER
Roper X05002X06 AIR CONDITIONER
Roper X05002X07 AIR CONDITIONER
Roper X07002F00 AIR CONDITIONER
Roper X07002G0 AIR CONDITIONER
Roper X07002W00 Air-conditioner/heat pump
Roper X07002X00 Air-conditioner/heat pump
Roper X07002X01 AIR CONDITIONER
Roper X07502V0 Air-conditioner/heat pump
Roper X10002D00 AIR CONDITIONER
Roper X10002F00 ROOM AIR CONDITIONER
Roper X10002G0 AIR CONDITIONER
Roper X10002V1 Air-conditioner/heat pump
Roper X10002W00 Air-conditioner/heat pump
Roper X10002W01 Air-conditioner/heat pump
Roper X10002W02 Air-conditioner/heat pump
Roper X10002W03 Air-conditioner/heat pump
Roper X10002W04 AIR CONDITIONER
Roper X12002D00 AIR CONDITIONER
Roper X12002F00 AIR CONDITIONER
Roper X12002G0 AIR CONDITIONERS
Roper X12002V0 Air-conditioner/heat pump
Roper X12002V01 Air-conditioner/heat pump
Roper X12002V02 Air-conditioner/heat pump
Roper X12002V03 Air-conditioner/heat pump
Roper X12002V04 AIR CONDITIONER
Roper X18004A0 AIR CONDITIONER
Roper X18004D00 AIR CONDITIONER
Roper X18004D01 AIR CONDITIONER
Roper X18004D02 AIR CONDITIONERS
Roper X18004G0 AIR CONDITIONERS
Roper X18004V0 Air-conditioner/heat pump
Roper X24004A0 AIR CONDITIONER
Roper X24004A1 AIR CONDITIONER
Roper X24004A2 AIR CONDITIONER
Roper X24004F00 AIR CONDITIONER
Roper X24004F01 AIR CONDITIONER
Roper X24004G0 AIR CONDITIONERS
Thermador X272XB OVEN
Thermador X272XP OVEN
Thermador X272XS OVEN
Thermador X272XW OVEN
Thermador X301XB OVEN
Thermador X301XP OVEN
Thermador X301XS OVEN
Thermador X301XW OVEN
Thermador X302XB OVEN
Thermador X302XP OVEN
Thermador X302XS OVEN
Thermador X302XW OVEN
Maytag X3448XTALT RANGE- S/C F/S GAS
Maytag X3448XTWLT RANGE- S/C F/S GAS
Maytag X3488VVDLT RANGE- S/C F/S GAS
Maytag X3488VVVLT RANGE- S/C F/S GAS
Maytag X3488XVALT RANGE- S/C F/S GAS
Maytag X8210RA SURFACE UNIT- GAS
Maytag X8210RW SURFACE UNIT- GAS
Maytag X8241RA SURFACE UNIT- GAS
Maytag X8241RV SURFACE UNIT- GAS
Maytag X8261RB SURFACE UNIT- GAS
Maytag X8261RV SURFACE UNIT- GAS
Maytag X8610RA SURFACE UNIT- ELE
Maytag X8610RT SURFACE UNIT- ELE
Maytag X8610RV SURFACE UNIT- ELE
Maytag X8670RB SURFACE UNIT- ELE
Maytag X8670RV SURFACE UNIT- ELE
Maytag X9112VUV WALLOVEN- STD GAS
Maytag X9112XUB WALLOVEN- STD GAS
Maytag X9875VVV WALLOVEN- S/C ELE
Maytag X9875XVB WALLOVEN- S/C ELE
Whirlpool XAMC891MQ0 PEDESTAL
Whirlpool XAMC891MQ1 PEDESTAL
Whirlpool XAMC891MQ2 PEDESTAL
Whirlpool XAMC892MQ0 PEDESTAL
Whirlpool XAMC892MQ1 PEDESTAL
Whirlpool XAMC892MQ2 PEDESTAL
Whirlpool XAMC893ML0 PEDESTAL
Whirlpool XAMC893ML1 PEDESTAL
Whirlpool XAMC893ML2 PEDESTAL
Maytag XAV13PRBWW MANUAL, PARTS (WASHER)
Amana XBR301 ELE CARTRIDGE
Amana XBR301WW ELE CARTRIDGE
Frigidaire XF22CW0
Frigidaire XF22CW1
Frigidaire XFEF3000LWA ELECTRIC RANGE
Frigidaire XFEF3000LWB ELECTRIC RANGE
Frigidaire XFEF3005LQA ELECTRIC RANGE
Frigidaire XFEF3005LQB ELECTRIC RANGE
Frigidaire XFEF3005LQC ELECTRIC RANGE
Frigidaire XFEF3005LQD ELECTRIC RANGE
Frigidaire XFEF3005LWA ELECTRIC RANGE
Frigidaire XFEF3005LWB ELECTRIC RANGE
Frigidaire XFEF3005LWC ELECTRIC RANGE
Frigidaire XFEF3005LWD ELECTRIC RANGE
Frigidaire XFGF3000LWA GAS RANGE
Frigidaire XFGF3000LWB GAS RANGE
Frigidaire XFGF3005LQA GAS RANGE
Frigidaire XFGF3005LQB GAS RANGE
Frigidaire XFGF3005LWA GAS RANGE
Frigidaire XFGF3005LWB GAS RANGE
Frigidaire XFLF3005LQB GAS RANGE
Frigidaire XFLF3005LWB GAS RANGE
Frigidaire XFUT1826MW0 REFRIGERATOR
Frigidaire XFUT1826MW1 REFRIGERATOR
  #2 (permalink)
Old 02-06-2017, 09:55 PM
Senior Member
PNWDrew is on a distinguished road
Default
If the various tubes are touching they will make noise. The insulation you found was probably between them as you noted. Just separate the offending tubes, that's what the tech would do. If you can easily see where that mastic was affixed use it, otherwise it's not important. It probably did wrap around the drier where you say to reduce the noise and may or may not reattach to it. I wouldn't worry about it, if you've stopped the noise you're ok.
If that has an actual UV dye drier on it it's been worked on. From the factory they do not usually include UV dye in the driers. Does it say UV on it? With an arrow pointing toward the thin (capillary tube) end? Or is that just a term you picked up somewhere? We'd use UV driers to find leaks as they distribute a UV fluorescent die through the sealed system.
  #3 (permalink)
Old 02-07-2017, 12:26 AM
Junior Member
Default
Thank you for the feedback! Yes, I was able to get the rattling to stop. As for the UV dye dryer, it was just a term that I picked up on the Internet to try and not call it the cigar shaped tube. The parts manual just has it listed as a dryer, and this is a brand new freezer out of the box, so it has not been worked on. Again, thank you for the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Oven - Gray, plastic-smelling smoke pahodges Oven Repair (including Ranges and Cooktops) 9 05-03-2018 12:40 AM
Copper tube to freezer compressor leaking M. Boothe Refrigerator & Freezer Repair 0 11-22-2016 01:32 PM
Pieces of gray plastic in filter of Whirlpool Front load washer bjames Washer Repair 0 12-23-2014 08:39 PM
Kenmore freezer broken copper tube-freon leak lisafelixmojica Refrigerator & Freezer Repair 3 01-07-2012 07:48 AM
any tricks to popping panel clips with putty knife? sparky110 Dryer Repair 2 06-03-2009 06:38 PM
