Discuss
Whirlpool side by side front left leak water shut off
 in
Refrigerator & Freezer Repair
I have a 3 year old whirlpool side by side. It has been leaking a moderate sized puddle from the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool side by side front left leak water shut off
  #1 (permalink)
Old 02-01-2017, 01:41 PM
Junior Member
pnw86 is on a distinguished road
Default Whirlpool side by side front left leak water shut off
Brand: Whirlpool   Age: 1 - 5 years
I have a 3 year old whirlpool side by side. It has been leaking a moderate sized puddle from the front left. I have shut off the water supply completely and put hot water through the defrost drain tube to clear it. Water filter was removed/bypassed, we do not use the front water dispenser or ice, and ice maker is also in the off position. No ice or water is found on the freezer floor. About one month with no problems, then I came home to a leak again today. I again poured hot water through the defrost drain tube. Some water did spill in this area as it is difficult to get it into the tube without spilling unless the freezer is taken more apart. I noticed this did cause a puddle on the floor under the freezer as well. Unsure if the drain pan is perfect or cracked, but I don't understand why it would hold water without leaks for a month and then leak. It currently has water in it from clearing the drain tube and appears to be holding it without a leak. Have not removed it to inspect it. Drain tube may have a little gunk in it but I did clean this out with a pipe cleaner a month ago. No dust or dirt in area...house is only 3 years old and keep clean. Any suggestions? Very frustrated by this....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sears Whirlpool side by side water dispenser wont shut off sometimes retiredfornow Refrigerator & Freezer Repair 1 12-28-2012 07:06 PM
Whirlpool Gold Side by Side Water Leak frankla10 Refrigerator & Freezer Repair 1 10-16-2012 04:07 PM
whirlpool side by side refrigerator water dispenser leak alpsobe Refrigerator & Freezer Repair 0 08-12-2012 02:43 PM
water leak at inlet assembly/gasket on left side Jerryreamer2 Dishwasher Repair 0 09-02-2010 08:21 AM
Water leak on front side of ice maker after fill trentrb211 Refrigerator & Freezer Repair 0 10-22-2007 11:53 AM
