Discuss
Whirlpool freezer quit again
 in
Refrigerator & Freezer Repair
Hello everyone, I have trolled your boards in the past but never posted, now I need to post. Bought this
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Whirlpool freezer quit again
  #1 (permalink)
Old 01-28-2017, 03:45 PM
Junior Member
atonguis is on a distinguished road
Default Whirlpool freezer quit again
Model Number: WZF56R16DW   Brand: Whirlpool   Age: Less than 1 year
Bought this freezer from big box store, they dropped it off and set it up on a Friday and left, 30 minutes later I pushed that temp button inside and the whole unit went off never to come back to life again. Called whirlpool on Monday and two weeks later a tech came out and said it would be 3 weeks for a part but he didn't know which part ??????? Called manager at store and he had a new one brought out 3 days later. 1 year later, I touched that damn button again and poof everything goes off, but the light works ( I knew I shouldn't have pushed that damn button) Whats up with these dang things that they go out when you push that temp button? Being the weekend, I had to put a jumper wire in there to get the damn thing to run because I am not losing 2k worth of meat and seafood. Can that board be bought?
Thanks,
AL
Related Models
General Electric WZRE5260F0GG Washer
General Electric WZRE5260F2GG Washer
General Electric WZSE5310T0WW Washer
General Electric WZSE5310T1WW Washer
Roper X05002F00 AIR CONDITIONER
Roper X05002F01 AIR CONDITIONERS
Roper X05002F02 AIR CONDITIONERS
Roper X05002G0 AIR CONDITIONERS
Roper X05002V0 Air-conditioner/heat pump
Roper X05002W00 Air-conditioner/heat pump
Roper X05002W01 Air-conditioner/heat pump
Roper X05002X00 Air-conditioner/heat pump
Roper X05002X01 Air-conditioner/heat pump
Roper X05002X02 Air-conditioner/heat pump
Roper X05002X03 Air-conditioner/heat pump
Whirlpool X05002X04 Air-conditioner/heat pump
Roper X05002X05 AIR CONDITIONER
Roper X05002X06 AIR CONDITIONER
Roper X05002X07 AIR CONDITIONER
Roper X07002F00 AIR CONDITIONER
Roper X07002G0 AIR CONDITIONER
Roper X07002W00 Air-conditioner/heat pump
Roper X07002X00 Air-conditioner/heat pump
Roper X07002X01 AIR CONDITIONER
Roper X07502V0 Air-conditioner/heat pump
Roper X10002D00 AIR CONDITIONER
Roper X10002F00 ROOM AIR CONDITIONER
Roper X10002G0 AIR CONDITIONER
Roper X10002V1 Air-conditioner/heat pump
Roper X10002W00 Air-conditioner/heat pump
Roper X10002W01 Air-conditioner/heat pump
Roper X10002W02 Air-conditioner/heat pump
Roper X10002W03 Air-conditioner/heat pump
Roper X10002W04 AIR CONDITIONER
Roper X12002D00 AIR CONDITIONER
Roper X12002F00 AIR CONDITIONER
Roper X12002G0 AIR CONDITIONERS
Roper X12002V0 Air-conditioner/heat pump
Roper X12002V01 Air-conditioner/heat pump
Roper X12002V02 Air-conditioner/heat pump
Roper X12002V03 Air-conditioner/heat pump
Roper X12002V04 AIR CONDITIONER
Roper X18004A0 AIR CONDITIONER
Roper X18004D00 AIR CONDITIONER
Roper X18004D01 AIR CONDITIONER
Roper X18004D02 AIR CONDITIONERS
Roper X18004G0 AIR CONDITIONERS
Roper X18004V0 Air-conditioner/heat pump
Roper X24004A0 AIR CONDITIONER
Roper X24004A1 AIR CONDITIONER
Roper X24004A2 AIR CONDITIONER
Roper X24004F00 AIR CONDITIONER
Roper X24004F01 AIR CONDITIONER
Roper X24004G0 AIR CONDITIONERS
Thermador X272XB OVEN
Thermador X272XP OVEN
Thermador X272XS OVEN
Thermador X272XW OVEN
Thermador X301XB OVEN
Thermador X301XP OVEN
Thermador X301XS OVEN
Thermador X301XW OVEN
Thermador X302XB OVEN
Thermador X302XP OVEN
Thermador X302XS OVEN
Thermador X302XW OVEN
Maytag X3448XTALT RANGE- S/C F/S GAS
Maytag X3448XTWLT RANGE- S/C F/S GAS
Maytag X3488VVDLT RANGE- S/C F/S GAS
Maytag X3488VVVLT RANGE- S/C F/S GAS
Maytag X3488XVALT RANGE- S/C F/S GAS
Maytag X8210RA SURFACE UNIT- GAS
Maytag X8210RW SURFACE UNIT- GAS
Maytag X8241RA SURFACE UNIT- GAS
Maytag X8241RV SURFACE UNIT- GAS
Maytag X8261RB SURFACE UNIT- GAS
Maytag X8261RV SURFACE UNIT- GAS
Maytag X8610RA SURFACE UNIT- ELE
Maytag X8610RT SURFACE UNIT- ELE
Maytag X8610RV SURFACE UNIT- ELE
Maytag X8670RB SURFACE UNIT- ELE
Maytag X8670RV SURFACE UNIT- ELE
Maytag X9112VUV WALLOVEN- STD GAS
Maytag X9112XUB WALLOVEN- STD GAS
Maytag X9875VVV WALLOVEN- S/C ELE
Maytag X9875XVB WALLOVEN- S/C ELE
Whirlpool XAMC891MQ0 PEDESTAL
Whirlpool XAMC891MQ1 PEDESTAL
Whirlpool XAMC891MQ2 PEDESTAL
Whirlpool XAMC892MQ0 PEDESTAL
Whirlpool XAMC892MQ1 PEDESTAL
Whirlpool XAMC892MQ2 PEDESTAL
Whirlpool XAMC893ML0 PEDESTAL
Whirlpool XAMC893ML1 PEDESTAL
Whirlpool XAMC893ML2 PEDESTAL
Maytag XAV13PRBWW MANUAL, PARTS (WASHER)
Amana XBR301 ELE CARTRIDGE
Amana XBR301WW ELE CARTRIDGE
Frigidaire XF22CW0
Frigidaire XF22CW1
Frigidaire XFEF3000LWA ELECTRIC RANGE
Frigidaire XFEF3000LWB ELECTRIC RANGE
Frigidaire XFEF3005LQA ELECTRIC RANGE
Frigidaire XFEF3005LQB ELECTRIC RANGE
Frigidaire XFEF3005LQC ELECTRIC RANGE
Frigidaire XFEF3005LQD ELECTRIC RANGE
Frigidaire XFEF3005LWA ELECTRIC RANGE
Frigidaire XFEF3005LWB ELECTRIC RANGE
Frigidaire XFEF3005LWC ELECTRIC RANGE
Frigidaire XFEF3005LWD ELECTRIC RANGE
Frigidaire XFGF3000LWA GAS RANGE
Frigidaire XFGF3000LWB GAS RANGE
Frigidaire XFGF3005LQA GAS RANGE
Frigidaire XFGF3005LQB GAS RANGE
Frigidaire XFGF3005LWA GAS RANGE
Frigidaire XFGF3005LWB GAS RANGE
Frigidaire XFLF3005LQB GAS RANGE
Frigidaire XFLF3005LWB GAS RANGE
Frigidaire XFUT1826MW0 REFRIGERATOR
Frigidaire XFUT1826MW1 REFRIGERATOR
  #2 (permalink)
Old 01-28-2017, 04:37 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Did you try holding the button in for more than 3 seconds?
  #3 (permalink)
Old 01-28-2017, 05:18 PM
Junior Member
Default
Yes sir I did, I looked up the manual with the first freezer and tried all the settings, nothing works. Did the same with the second freezer and same thing, when I unplug from the wall and plug in it makes this little tune sound and lights flash on the pad but that's it, the light works inside but nothing else, currently have the power wire unplugged from the circuit board inside and a jumper wire shoved in there to make the unit run, but not sure how good this is for the unit.
  #4 (permalink)
Old 01-29-2017, 02:11 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
It sounds like WP has a board problem they need to address. I just read a bunch of reviews saying similar things about this model freezer.
  #5 (permalink)
Old 01-29-2017, 11:20 AM
Junior Member
Default
Where did you read those reviews at ?
  #6 (permalink)
Old 01-29-2017, 03:07 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
I did a Google search. I just typed in the model number and the word "problem" and I found all kinds of things.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer quit running eksjmw Refrigerator & Freezer Repair 1 11-19-2011 03:16 AM
HELP! freezer quit! smithsmith Refrigerator & Freezer Repair 6 10-21-2011 03:10 AM
bottom freezer quit owby Refrigerator & Freezer Repair 1 07-22-2009 04:03 PM
Freezer quit running cyfromnc Refrigerator & Freezer Repair 0 12-30-2008 07:58 AM
Freezer quit...?? Shackdragger Refrigerator & Freezer Repair 1 11-29-2008 10:48 AM
