Discuss
freezer is cold but refrigerator is not
 in
Refrigerator & Freezer Repair
Hi, I have read the sticky note and think that I can follow the steps to get a more accurate
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer is cold but refrigerator is not
  #1 (permalink)
Old 01-18-2017, 08:40 PM
Junior Member
kamp is on a distinguished road
Default freezer is cold but refrigerator is not
Model Number: 253.6580250A   Brand: Kenmore   Age: 5 - 10 years
Hi, I have read the sticky note and think that I can follow the steps to get a more accurate diagnostic of my problem, though I think I should check to see if it is worth fixing in any scenario. My top freezer Kenmore is about 10 years old, and last week it started to have the problem where the apparatus (I think it is called the evaporator?) behind the panel in the freezer froze up, and therefore the freezer was cold but the fridge part was not. I let it defrost and it was ok again, but the same thing would happen in about two days. I have attached a picture of what i see when I opened up the back panel in the freezer.
I understand the Kenmore has lived to its life expectancy and it is probably time to get a new one. I am hoping to get your opinions on whether I should investigate further or it is not worth it to bother at all. Many thanks and have a blessed day to all!
Related Models
Frigidaire 2530A GAS RANGE
Frigidaire 2530B GAS RANGE
Frigidaire 2530C GAS RANGE
Frigidaire 2530D GAS RANGE
Frigidaire 2530E GAS RANGE
Kenmore 25310301000 CHEST FREEZER
Kenmore 25310301001 CHEST FREEZER
Kenmore 25310311000 CHEST FREEZER
Kenmore 25310311001 CHEST FREEZER
Kenmore 25310311002 FREEZER
Kenmore 25310911990 FREEZER
Kenmore 25310911991 CHEST FREEZER
Kenmore 25310911992 CHEST FREEZER
Kenmore 25311301100 FREEZER
Kenmore 25311301101 FREEZER
Kenmore 25311311100 CHEST FREEZER
Kenmore 25311312100 FREEZER
Kenmore 25311312101 FREEZER
Kenmore 25311312102 SEARS/FREEZER
Kenmore 25311321100 CHEST FREEZER
Kenmore 25311321101 FREEZER
Kenmore 25311351100 FREEZER
Kenmore 25311351101 CHEST FREEZER
Kenmore 25311351102 FREEZER
Kenmore 25311511100 CHEST FREEZER
Kenmore 25311511101 FREEZER
Kenmore 25311521100 FREEZER
Kenmore 25311521102 CHEST FREEZER
Kenmore 25311521103 FREEZER
Kenmore 25311531100 FREEZER
Kenmore 25311531101 FREEZER
Kenmore 25311531102 FREEZER
Kenmore 25311531103 FREEZER
Kenmore 25311541100 CHEST FREEZER
Kenmore 25311541102 FREEZER
Kenmore 25311711100 FREEZER
Kenmore 25311711101 CHEST FREEZER
Kenmore 25311711102 FREEZER
Kenmore 25311821100 FREEZER
Kenmore 25311821101 FREEZER
Kenmore 25311911100 FREEZER
Kenmore 25311911101 FREEZER
Kenmore 25312021100 FREEZER
Kenmore 25312021101 FREEZER
Kenmore 25312021102 FREEZER
Kenmore 25312541100 FREEZER
Kenmore 25312541102 SEARS/FREEZER
Kenmore 25312551100 FREEZER
Kenmore 25313009100 FREEZER
Kenmore 25313051100 FREEZER
Kenmore 25313051101 FREEZER
Kenmore 25313051102 FREEZER
Kenmore 25313051103 FREEZER
Kenmore 25313312101 FREEZER
Kenmore 25313351100 FREEZER
Kenmore 25313500100 FREEZER
Kenmore 25313500101 FREEZER
Kenmore 25313500102 FREEZER
Kenmore 25313500103 FREEZER
Kenmore 25313511100 CHEST FREEZER
Kenmore 25313511101 FREEZER
Kenmore 25313511102 FREEZER
Kenmore 25313541101 FREEZER
Kenmore 25313541102 FREEZER
Kenmore 25313551100 FREEZER
Kenmore 25313551101 FREEZER
Kenmore 25313711100 FREEZER
Kenmore 25313711101 FREEZER
Kenmore 25313711102 FREEZER
Kenmore 25313712100 FREEZER
Kenmore 25313712101 FREEZER
Kenmore 25313911100 FREEZER
Kenmore 25313911101 FREEZER
Kenmore 25313911102 FREEZER
Kenmore 25314092101 FREEZER
Kenmore 25314092102 FREEZER
Kenmore 25314092103 FREEZER
Kenmore 25314342100 FREEZER
Kenmore 25314342101 FREEZER
Kenmore 25314342102 FREEZER
Kenmore 25314352100 FREEZER
Kenmore 25314352101 FREEZER
Kenmore 25314352102 FREEZER
Kenmore 25314502100 FREEZER
Kenmore 25314502101 FREEZER
Kenmore 25314502102 FREEZER
Kenmore 25314502103 FREEZER
Kenmore 25314502104 FREEZER
Kenmore 25314502105 FREEZER
Kenmore 25314512100 FREEZER
Kenmore 25314512101 FREEZER
Kenmore 25314512102 FREEZER
Kenmore 25314512103 FREEZER
Kenmore 25314512104 FREEZER
Kenmore 25314542100 FREEZER
Kenmore 25314542101 FREEZER
Kenmore 25314542102 FREEZER
Kenmore 25314542103 FREEZER
Kenmore 25314542104 FREEZER
Kenmore 25314542105 FREEZER
Kenmore 25314552100 FREEZER
Kenmore 25314552101 FREEZER
Kenmore 25314552102 FREEZER
Kenmore 25314582100 FREEZER
Kenmore 25314592100 FREEZER
Kenmore 25314592101 FREEZER
Kenmore 25314592102 FREEZER
Kenmore 25314702100 FREEZER
Kenmore 25314702101 FREEZER
Kenmore 25314702102 FREEZER
Kenmore 25314702103 FREEZER
Kenmore 25314702104 FREEZER
Kenmore 25314712100 FREEZER
Kenmore 25314712101 FREEZER
Kenmore 25314712102 FREEZER
Kenmore 25314712103 FREEZER
Kenmore 25314772100 FREEZER
Kenmore 25314772101 FREEZER
Kenmore 25314772102 FREEZER
Kenmore 25314772103 FREEZER
  #2 (permalink)
Old 01-19-2017, 12:12 AM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Your refrigerator probably has a defrost problem.
There are three main parts in a defrost system.
The defrost timer
Frigidaire 215846602 Defrost Timer - AppliancePartsPros.com
The defrost thermostat.
Frigidaire 5303918202 Defrost Thermostat - AppliancePartsPros.com
And the defrost element.
Frigidaire 240356221 Heater-Defrost - AppliancePartsPros.com
The timer is like a clock with switches, it sends power to the compressor for X number of hours. Then it goes into a defrost part of the cycle for about 30 minutes. After the frost is melted and the time is up, the timer transfers power back to the compressor. If somehow the coil area should get too warm the defrost thermostat will shut down the defrost until the timer runs out.
This refrigerate/defrost cycle repeats all day and every day as long as the refrigerator is powered up.
One of these parts or the wiring in between has failed in yours.
  #3 (permalink)
Old 01-19-2017, 03:26 AM
Junior Member
Default
Many thanks! So where do I go from here? Just follow the instruction in the sticky note to see which part it is? The part seems cheap enough-Should I attempt to replace the part myself?
One way or the other, it is not a problem with the sealed system is it (I heard that sealed system problem also produces frost similar to that).
  #4 (permalink)
Old 01-19-2017, 05:07 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
Is that all the frost that collects? Is it only frosting about half the coils?
If that is all it ever frosts, its probably low on freon.
Usually the coils should have a pretty uniform frost pattern all the way across and from the top to bottom.
  #5 (permalink)
Old 01-19-2017, 09:54 AM
Junior Member
Default
sorry if this message appears twice. yes that is the pattern i see every time I open up the back panel
freon is a separate issue from the defrosting system right? Where should I start in diagnosing the problem? I mean I know there is probably no easy way to find out but I just want to know where to start. Many thanks!
  #6 (permalink)
Old 01-19-2017, 07:19 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
The compressor and coils are referred to as the "sealed system".
If you have a leak, that means its going to need freon to work correctly. But even if you add freon, it will just leak out again. Unless you can find the leak and seal it. That kind of thing can get costly.
To just check the freon pressure, you would need to put a tap/access valve on a low side line and you would need a gauge set for the type of freon your refrigerator has.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer cold but not freezing, refrigerator not cold enough tyltea1st@charter.net Refrigerator & Freezer Repair 1 06-06-2014 03:04 AM
Refrigerator cold, Freezer cold but not freezing. rdtraverse Refrigerator & Freezer Repair 0 07-02-2013 05:49 PM
Refrigerator/freezer not staying cold, then too cold wendymay Refrigerator & Freezer Repair 0 03-31-2011 06:40 PM
Freezer cold but not freezing, Refrigerator cool but not cold sixboyzdad Refrigerator & Freezer Repair 1 06-09-2010 09:00 PM
