A few days ago I heard the fan pulsing on and off and items in the fridge were freezing. The line to the water dispenser and ice maker was frozen. Based on what I read, I replaced my ADCII with a new ADCIV, including the wire harness. Everything seemed fine but then after a few hours I realized the fan was not shutting down. When I turn the fridge temp control to off the fan shuts off and I hear noise from the damper closing. Is it possible I damaged the thermostat when rearranging the wires or possibly put something back wrong. I was very careful about wires taking a photo to assure proper color placement. Any help would be appreciated. Thanks
