This model can be set as a refrigerator or freezer. I have it set up as a refrigerator. Fridge seems to run fine at times, then sometimes starts cooling and doesn't stop until it is into freezing temperatures. It is set up as a refrigerator set at 37F. It also will get too warm. Sounds like maybe a bad thermostat. The thermostat on Parts for Electrolux FGVU21F8QFB: System Parts - AppliancePartsPros.com AppliancepartsPros diagram for this model, Part Number AP4354656, seems like it is for the defrost. I do not see any other thermostat. Would this be the part I need to replace?
