Works fine for a day or two. Check the temp on the door it says its right were it is suppose to be. Freezer at 0 fridge at 37. But you can definitely tell when you open the door that its alot warmer than that.also while its like this the fan in the freezer wont turn on. Upplug it for a bout 10 mins then plug it back in. temp on the door says 12 for the freezer and 42 for the fridge. Then the fan kicks on and starts to cool. Please help. If any more information is needed please let me know and i will do my best to relay it to you.
