Cee3PeeOh
#1 Posted : Tuesday, January 3, 2017 11:04:32 AM(UTC)
Cee3PeeOh
Frigidaire refrigerator FFHS2611LW4 ice maker overflows ice.
In fact the thing works too well. The wire signal arm apparently isn't adjusted correctly because the bucket overflows with ice if I leave it alone and don't babysit it by flipping the arm up when the bucket is full, it overflows ice.
The wire signal arm is not bent or misshapen in any way.
The manual, file:///C:/Users/install/Downloads/1106338L.pdf does show a more ice / less ice feature :
Quote:
To increase ice production for special occasions, such as parties, push the Touch Pad for 3-5 seconds
to activate this feature. A green light will appear above the Touch Pad. Push the Touch Pad again for
3-5 seconds to deactivate. EXTRA ICE should produce 25 percent to 50 percent more ice every 24
hours.
My refrigerator does not have that touchpad.
Any thoughts?
ThatGuy
#2 Posted : Tuesday, January 3, 2017 12:03:25 PM(UTC)
ThatGuy
Groups: Expert
United States
Is this the icemaker you have?
Parts for Frigidaire FFHS2611LW4 / : Ice Maker Parts - AppliancePartsPros.com
The "wire signal arm" can be called the shut off arm or bail sometimes. It should look like this.......
Frigidaire 5304469377 Shut-Off Arm - AppliancePartsPros.com
Does it rise up when the icemaker goes through its harvest cycle? It should raise up and end up on top of the "new" ice the icemaker just made.
It could be bent inside the icemaker or you could have a switch that is weak. It must work somewhat because you said it will shut off the IM when the arm is manually moved to the up position.
One more thing there are two basic sizes of these bails or shut off arms. A shorter one for regular refrigerators and a longer one for side by sides. (the ice bin is deeper and farther away on SbyS refrigerators.)
Cee3PeeOh
#3 Posted : Tuesday, January 3, 2017 4:22:28 PM(UTC)
Cee3PeeOh
[COLOR="DarkOrange"]That looks like it but the front square cover has no buttons it is just a plastic cover.[/COLOR]
[COLOR="DarkOrange"]I used that term because it was called that in the manual.[/COLOR]
[COLOR="DarkOrange"]Yes the bail lifts on the new ice but goes no where near where it shuts off the IM. It also lowers parallel against the side of the IM which makes me believe it is adjusted correctly. If it was bent into any other shape it wouldn't stop and rest comfortably against the IM when cycling.[/COLOR]
[COLOR="DarkOrange"]Yes it does shut off the IM when I lift it. It "feels" normal having just a bit of resistance then snaps/clicks into place and is easily unsnapped into the on position.[/COLOR]
[COLOR="DarkOrange"]We bought the thing new so I'm assuming it is the correct one for side by sides.[/COLOR]
