The ice chute door arm is melting to the solenoid plunger at the point they connect? I just replaced the ice chute door assembly and installed a new solenoid and it only lasted about a week. The old parts I took out had the same problem. Appears solenoid is getting to hot for some reason and melting the little arm. Any ideas would be helpful.
Thanks,
Charlie
