I have a Frigidaire refrigerator dghf2360pf7a with variable speed compressor the compressor will not run everything else works I did the diagnostic test on main board to see if correct ac and dc voltage was going to compressor inverter board. the service data sheet said it should be 10-15 vac 1-5 vdc I was not getting the correct voltage to inverter. I got a new main board but still not getting correct voltage . I used the system diagnostic mode to try to get compressor to run it still would not run. what you think.
