| » Compressor running continously |
Model Number: mbf1956kew Brand: Maytag Age: 1 - 5 years
The compressor is running contiously. Had to replace defrost heater and thermostat because it was not defrosting. It's now defrosting corrrectly but the compressor is not stopping even when forcing a defrost cycle. Not sure if this was the cause of the defrost heater failure.
Related Models |
Replacement parts for MAYTAG MBF1956KEW | AppliancePartsPros.com Here is the tech sheet which you may already have http://www.servicematters.com/maytag...s/16026956.pdf Try to run the diagnostic tests on the tech sheet. It does sound like your control board is toast as it should shut the compressor off when in defrost.
__________________
Quote:
Thank you. I ran the defrost test before replacing the defrost thermostat and heater and it did not defrost. After replacing both the thermostat and heater the defrosting ran correctly. I ran test 2 (Compressor/Condenser Fan Test) under service mode and it did not stop the compressor - fan neither before or after replacing the thermostat and heater. Do you know if test 2 is suppose to stop and activate the compressor - fan when keying F/O? . Last edited by maytagmbf1956 : 11-02-2009 at 08:09 PM. |
| Display Modes | |
| Drain Pump Continously Running | cjm3001 | Dishwasher Repair | 9 | 09-30-2009 08:55 PM |
| compressor not running | lou6421 | Refrigerator & Freezer Repair | 0 | 08-20-2009 04:02 PM |
| compressor not running | ryanwayne | Refrigerator & Freezer Repair | 0 | 01-27-2009 01:36 PM |
| Compressor not running | Larchway | Refrigerator & Freezer Repair | 4 | 07-29-2008 03:59 AM |
| Compressor not running | julimarie | Refrigerator & Freezer Repair | 3 | 12-25-2007 03:41 AM |
