Discuss
Refrigerator tripping GFCI outlet
 in
Refrigerator & Freezer Repair
Our refrigerator was previously in our house and worked fine. We moved it to the garage which has gfci outlets.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator tripping GFCI outlet
  #1 (permalink)
Old 11-30-2016, 10:10 AM
Junior Member
jp1061 is on a distinguished road
Default Refrigerator tripping GFCI outlet
Model Number: ASD2624HES   Brand: Amana   Age: 5 - 10 years
Our refrigerator was previously in our house and worked fine. We moved it to the garage which has gfci outlets. The refrigerator will run for around 8 to 10 hours and then trip the gfci outlet. Sometimes it runs less. Once it trips and i reset the outlet, it instantly trips the outlet again unless i plug it into a standard outlet. I have had two separate repair people out from two different companies and they both said the fridge is fine. They suspect that the gfci is just tripping. I changed the gfci and it still does it. One of the repairmen recommended that i change the outlet to a standard outlet and said that a refrigerator shouldn't be on a gfci. From what i have read, this is against code. But i am not sure if it is or what to do. Does this seem possible or could there be an underlying problem that two people have not found?
Related Models
Amana ASD2624HES REF - SXS/I&W
Amana ASD2624HEW REF - SXS/I&W
Amana ASD2625KEB REF - SXS/I&W
Amana ASD2625KEQ REF - SXS/I&W
Amana ASD2625KES REF - SXS/I&W
Amana ASD2625KEW REF - SXS/I&W
Amana ASD2626HEB REF - SXS/I&W
Amana ASD2626HEQ REF - SXS/I&W
Amana ASD2626HES REF - SXS/I&W
Amana ASD2626HEW REF - SXS/I&W
Amana ASD2627KEB REF - SXS/I&W
Amana ASD2627KES REF - SXS/I&W
Amana ASD2627KEW REF - SXS/I&W
Amana ASD2628HEB REF - SXS/I&W
Amana ASD2628HEQ REF - SXS/I&W
Amana ASD2628HES REF - SXS/I&W
Amana ASD2628HEW REF - SXS/I&W
Amana ASD262RHRB REF - SXS
Amana ASD262RHRQ REF - SXS
Amana ASD262RHRS REF - SXS
Amana ASD262RHRW REF - SXS
Amana ASE526K REF - SXS/I&W
Amana ASE526M REF - SXS/I&W
Amana ASE7000 COMMERCIAL MICROWAVES
Amana ASE70002 COMMERCIAL MICROWAVES
Amana ASE9000 COMMERCIAL MICROWAVES
Amana ASE90002 COMMERCIAL MICROWAVES
Amana ASE90002 AMANA COMMERCIAL MICROWAVES (COMMERCIAL MICROWAVES)
General Electric ASF05LAS1 Room air conditioner
General Electric ASF24DAS1 Room air conditioner
General Electric ASF24DBS1 Room air conditioner
General Electric ASH06LBS1 Room air conditioner
General Electric ASH06LCS1 Room air conditioner
General Electric ASH06LKS1 Room air conditioner
General Electric ASH06LLS1 ROOM AIR CONDITIONER
General Electric ASH08FAS1 Room air conditioner
General Electric ASH08FCS1 Room air conditioner
General Electric ASH08FDS1 Room air conditioner
General Electric ASH08FKS1 Room air conditioner
General Electric ASH10AAS1 Room air conditioner
General Electric ASH10ABS1 Room air conditioner
General Electric ASH10ACM1 Room air conditioner
General Electric ASH10AKS1 Room air conditioner
General Electric ASH12AAS1 Room air conditioner
General Electric ASH12ACS1 Room air conditioner
General Electric ASH12ADM1 Room air conditioner
General Electric ASH12ALS1 ROOM AIR CONDITIONER
General Electric ASH18DAS1 Room air conditioner
General Electric ASH18DBS1 Room air conditioner
General Electric ASH18DDS1 Room air conditioner
General Electric ASH18DES1 Room air conditioner
General Electric ASH18DKS1 Room air conditioner
General Electric ASH24DAD1 Room air conditioner
General Electric ASL05LAS1 Room air conditioner
General Electric ASL06LAM1 Room air conditioner
General Electric ASL06LBS1 Room air conditioner
General Electric ASL06LCS1 Room air conditioner
General Electric ASL08FKS1 ROOM AIR CONDITIONER
General Electric ASL08FLS1 ROOM AIR CONDITIONER
Frigidaire ASL140BK2 Frg(v4) / Top Mount Refrigerator
Frigidaire ASL140WK2 Frg(v5) / Top Mount Refrigerator
General Electric ASL24DAS1 Room air conditioner
General Electric ASM05LBS1 Room air conditioner
General Electric ASM05LKS1 Room air conditioner
General Electric ASM05LLS1 ROOM AIR CONDITIONER
General Electric ASM06LAS1 Room air conditioner
General Electric ASM06LBS1 Room air conditioner
General Electric ASM06LCS1 Room air conditioner
General Electric ASM06LKS1 Room air conditioner
General Electric ASM06LLS1 ROOM AIR CONDITIONER
General Electric ASM08AAS1 Room air conditioner
General Electric ASM08FAS1 Room air conditioner
General Electric ASM08FBS1 Room air conditioner
General Electric ASM08FCS1 Room air conditioner
General Electric ASM08LKS1 Room air conditioner
General Electric ASM08LLS1 ROOM AIR CONDITIONER
General Electric ASM10AAS1 Room air conditioner
General Electric ASM10ABS1 Room air conditioner
General Electric ASM10ACS1 Room air conditioner
General Electric ASM10AKS1 Room air conditioner
General Electric ASM10ALS1 ROOM AIR CONDITIONER
General Electric ASM12AAS1 Room air conditioner
General Electric ASM12ABS1 Room air conditioner
General Electric ASM12ACS1 Room air conditioner
General Electric ASM12AKS1 Room air conditioner
General Electric ASM12ALS1 ROOM AIR CONDITIONER
General Electric ASM12DAS1 Room air conditioner
General Electric ASM12DBS1 Room air conditioner
Frigidaire ASM140BK2 Frg(v1) / Top Mount Refrigerator
Frigidaire ASM140HK2 Frg(v2) / Top Mount Refrigerator
Frigidaire ASM140K1 Gib(v3) / Refrigerator
Frigidaire ASM140WK1 Frg(v1) / Refrigerator
Frigidaire ASM140WK2 Frg(v3) / Top Mount Refrigerator
Frigidaire ASM140WKB1 Frg(v3) / Refrigerator
Frigidaire ASM140WKD1 Kel(v15) / Refrigerator
Frigidaire ASM140WKH1 Frg(v2) / Refrigerator
Frigidaire ASM140WKJ1 Kel(v14) / Refrigerator
Frigidaire ASM140WKW1 Frg(v1) / Refrigerator
Frigidaire ASM140WKY1 Gib(v8) / Refrigerator
General Electric ASM14AAD1 Room air conditioner
General Electric ASM14ABD1 Room air conditioner
General Electric ASM14AKS1 Room air conditioner
General Electric ASM14ALS1 ROOM AIR CONDITIONER
General Electric ASM16DAS1 Room air conditioner
General Electric ASM16DBS1 Room air conditioner
General Electric ASM18DAS1 Room air conditioner
General Electric ASM18DBS1 Room air conditioner
General Electric ASM18DKS1 Room air conditioner
General Electric ASM22DAD1 Room air conditioner
General Electric ASM22DBD1 Room air conditioner
General Electric ASM24DAD1 Room air conditioner
General Electric ASM24DBD1 Room air conditioner
General Electric ASM24DCS1 Room air conditioner
General Electric ASM24DDS1 Room air conditioner
  #2 (permalink)
Old 11-30-2016, 03:38 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
I've seen this before. I couldn't find an answer That I was 100% sure of.
I'm pretty sure it trips during defrost and my theory goes like this. Either the element or wiring gets just damp enough that it causes the GFI to trip.
The one I worked on, only had problems on a GFI circuit. On a standard plugin it worked just fine.
There was no voltage to the shell and it tested normally in every way.
  #3 (permalink)
Old 12-02-2016, 08:52 AM
Junior Member
Default
Thank you for the reply. That was the first repair persons theory as well. He said that it was just getting damp and causing it to trip. I put it on a standard outlet and it ran for 6 hours and didn't have any issues. I unplugged it when i left just to be safe. Do you think it would be safe to assume that if it runs for that long, it will be OK if i left it plugged in?
  #4 (permalink)
Old 12-02-2016, 08:59 AM
Junior Member
Default
Sorry, i think i replied wrong and i wasn't sure if you would be notified.
  #5 (permalink)
Old 07-03-2018, 08:07 PM
Junior Member
Realtor-curt is on a distinguished road
Default
I know this thread is a bit dated, however my guess is that your ice maker is turned on in the freezer. And since it's in your garage, I'm guessing you aren't running a water line to it. Thus the ice maker is trying to draw water and failing thus sending the out of sync current to the gfi/gfci. If you disable the ice maker I'm guessing it will work again without tripping
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool refrigerator tripping GFCI okclm Refrigerator & Freezer Repair 7 08-07-2015 07:40 PM
GE Fridge keeps tripping the GFCI kwik68 Refrigerator & Freezer Repair 0 09-15-2012 07:24 AM
Frigidaire Gallery Gas Dryer - Tripping GFCI cmoore64 Dryer Repair 2 08-07-2012 04:51 PM
Refrigerator tripping GFCI bpbsol Refrigerator & Freezer Repair 1 05-23-2011 04:28 AM
Refrigerator tripping gfci breaker bluefitness Refrigerator & Freezer Repair 1 06-04-2009 12:05 PM
