Unit not on and needs to have the thermostat for both fridg & freezer adjusted daily. I have to slide the thermostat off and then back on to have it start up. I believe it was back in September I replaced a fan with a broken blade that I purchased from Appliance Parts Pros. I watched an installation video and all went fine and worked well. A few weeks ago I noticed the freezer was not on, I adjusted the thermostat and it popped back on. Then it started happening to both fridge & freezer with a daily frequency and now it happens several times a day. Can you help me determine what the problem is?
