I figured out that I had a bad overload relay to the compressor on my fridge. While figuring that out, I also checked the run capacitor, which is fine. As I was going to reinstall the capacitor, I realized that I didn't recall how the wiring harness was attached. The thing can go on either way. Does it matter if I have the wiring harness to the run capacitor reversed from what it was? Thanks for the help!
