Over 10 years ago, got this freezer from an owner who said it had just stopped working. We took it home, plugged it in, and it worked. Moved with it to another state, and it has been working another 10-1/2 years, used as a storage freezer, so we aren't into it much. Then last week it just stopped. One day the ice cream was OK, a couple of days later some frozen raspberries were dripping into the bottom of the cabinet. The High-Temp Alarm was off, but one The "On" light was lit and it seemed to be getting power OK; another appliance on the same power outlet was working fine. No drip/puddle under the freezer (until the in-cabinet puddle spilled out). Cleaned it out, and reset the dial from "Coldest" (~7) down to "4". Motor still did not come on. Unplugged it for ~1/2 hr., then plugged it back in, still no motor. Any suggestions as to likely cause?
