Before I replaced the defrost timer and heat element the unit was working, but the evaporator coils were freezing up. I replaced the defrost timer and the unit started working, but the coils were still freezing up, replaced the defrost heater, now it will not work unless you change the temp setting.
Where did I screw up????:cool:
