Hi
I have Whirlpool Refrigerator GX5SHDXVB01 icemaker trouble.
I have tested the water inlet valve by jumpering 110V directly to it and extending the water line to a sink. Good flow.
I have bench tested the module by jumpering 110V to it. It appears to work normally, but I also tried the icemaker in place with another , known to be good module. No good.
I tested each wire in the harness for continuity. All Good.
I metered the freezer connector-white/black, white/green, black/green, brown/black, white/brown and brown/green. I don't seem to get any voltage reading.
Any help you might provide would be apprecited.
Tim
