my freezer keeps losing ability to keep things frozen. Takes about 7-10 days and then the back wall is covered in ice. same problem happened a year and a half ago and I replaced the defrost control board. before I try to replace that same part again, I wanted to see if there was a way I could test to see if that was the problem or if something else was wrong.
