The freezer door was removed. Upon reinstall, when the freezer door dispenser panel connector located below the freezer door next to the water line disconnect was plugged in the dispenser panel worked for a few minutes and then went blank. The Fresh Food temperature control panel lights also went blank. When the dispenser panel connector is disconnected, the Fresh Food temperature control panel starts working. There are three wires on the dispenser connector (Blue, Black and Red). Not sure what the signals/voltages should be. I can't find a schematic that clearly shows the connector. Could the dispenser control board have failed?:)
