The ice dispenser is perfect, but the water just runs down the water dispenser palette and around the glass. It is easy to think that a hose is not connected well to the normal water output spout. AND it is easy to believe that the front panel might come off in a way to look at that. But I see no way to get the front panel off. It could be a 'click' off, but I put a little pressure under an edge and am fearful of breaking it. Thanks for any help.
